电子产品世界 » 论坛首页 » 企业专区 » TI » 【MSP焕新大作战】课程三+任务三
【MSP焕新大作战】课程三+任务三
2024-07-14 17:10:22     打赏
通过数码管显示温度数据,并设置蜂鸣器报警
进入syscfg进行初始化GPIO管脚和定时器,分别配置
PA27==>HC595_DAT,
PA26==>HC595_SLK,
PA13==>HC595_RLK,
PA1 ==>DS18B20_DQ
PA15==>GPIO_BEEP
在代码中编写HC595驱动函数:
uint16_t tempval =456;
uint8_t TimerCnt = 0 ;
unsigned char Disp_DX[16] ={ 0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8, 0x80, 0x90, 0x8C, 0xBF, 0xC6, 0xA1, 0x86, 0xFF };
unsigned char Disp_PX[8] = {1,2,3,4,5,6,7,8};
#define HC595_DAT(x)				((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_DAT_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_DAT_PIN)))
#define HC595_CLK(x)				((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_SLK_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_SLK_PIN)))
#define HC595_RCK(x)				((x)?(DL_GPIO_setPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_RLK_PIN)) : (DL_GPIO_clearPins(GPIOA_HC595_PORT,GPIOA_HC595_HC595_RLK_PIN)))
void Display_0ut()
	HC595_RCK(0);
	delay_cycles(32);
	HC595_RCK(1);
	delay_cycles(32);
void HC595_WriteData(unsigned char data)
	unsigned char i;
	for(i=0;i<8;i++)
		if(data & 0x80)
			HC595_DAT(1);
		else
			HC595_DAT(0);
		data <<= 1;
		HC595_CLK(0);
		delay_cycles(32);
		HC595_CLK(1);
		delay_cycles(32);
void HC595_Send_Data(uint8_t dis_num,uint8_t dis_bit)
	HC595_WriteData(dis_num);
	HC595_WriteData(1<<dis_bit);
	Display_0ut();
void Disp_Data(uint16_t u16DataH)
    uint16_t templ,tempH;
    uint8_t num_q,num_b,num_s,num_g;
    tempH = u16DataH;
    num_q = tempH/1000;
    num_b = tempH/100%10;
    num_s = tempH/10%10;
    num_g = tempH%10;
    HC595_Send_Data(Disp_DX[num_q],7);
    HC595_Send_Data(Disp_DX[num_b],6);
    HC595_Send_Data(Disp_DX[num_s],5);
    HC595_Send_Data(Disp_DX[num_g],4);
设置蜂鸣器驱动宏定义:
#define BeepON  DL_GPIO_clearPins(GPIOA_HC595_PORT, GPIOA_HC595_GPIO_BEEP_PIN);
#define BeepOFF DL_GPIO_setPins(GPIOA_HC595_PORT, GPIOA_HC595_GPIO_BEEP_PIN);
新建.c文件和.h文件编写DS18B20驱动函数:
ds18b20.c文件内容
#define DS18B20_DQ_OUTH 		DL_GPIO_setPins(GPIOA_HC595_PORT, GPIOA_HC595_DS18B20_DQ_PIN)
#define DS18B20_DQ_OUTL 			DL_GPIO_clearPins(GPIOA_HC595_PORT, GPIOA_HC595_DS18B20_DQ_PIN)
#define DS18B20_DQ_READ 			DL_GPIO_readPins(GPIOA_HC595_PORT, GPIOA_HC595_DS18B20_DQ_PIN)
#define DS18B20_DQ_IN 				DL_GPIO_initDigitalInput(GPIOA_HC595_DS18B20_DQ_IOMUX);DL_GPIO_disableOutput(GPIOA_HC595_PORT, GPIOA_HC595_DS18B20_DQ_PIN)
#define DS18B20_DQ_OUT 			DL_GPIO_initDigitalOutput(GPIOA_HC595_DS18B20_DQ_IOMUX);DL_GPIO_enableOutput(GPIOA_HC595_PORT, GPIOA_HC595_DS18B20_DQ_PIN)
#define delay_us_cycle   32
/* 延时函数 */
void inline delay_us(uint16_t us)
    do{
        delay_cycles(delay_us_cycle);
    }while (us --);
/* 复位芯片 */
static void DS18B20_Rst(void)
    DS18B20_DQ_OUT;
    DS18B20_DQ_OUTL;    /* 拉低DQ,复位 */
    delay_us(750);      /* 拉低750us */
    DS18B20_DQ_OUTH;    /* DQ=1, 释放复位 */
    delay_us(15);       /* 延迟15US */
/* 检查总线上是否存在温度芯片 */
uint8_t DS18B20_Check(void)
  uint8_t retry = 0;
  DS18B20_DQ_IN;
  while (DS18B20_DQ_READ && retry < 200)
    retry++;
    delay_us(1);
  if (retry >= 200)
    return 1;
  else
    retry = 0;
  while (!DS18B20_DQ_READ && retry < 240)
    retry++;
    delay_us(1);
  if (retry >= 240)
    return 1;
  return 0;
/* 芯片初始化 */
uint8_t DS18B20_Init(void)
  DS18B20_Rst();
  return DS18B20_Check();
/* 读取单bit数据 */
uint8_t DS18B20_Read_Bit(void) // read one bit
  DS18B20_DQ_OUT;
  uint8_t data;
  DS18B20_DQ_OUTL;
  delay_cycles(2 * 32);
  DS18B20_DQ_OUTH;
  delay_cycles(12 * 32);
  DS18B20_DQ_IN;
  if (DS18B20_DQ_READ)
    data = 1;
  else
    data = 0;
  delay_cycles(50 * 32);
  return data;
/* 读取一字节数据 */
uint8_t DS18B20_Read_Byte(void) // read one byte
  uint8_t i, j, dat;
  dat = 0;
  for (i = 1; i <= 8; i++)
    j = DS18B20_Read_Bit();
    dat = (j << 7) | (dat >> 1);
  return dat;
/* 写入一字节数据 */
void DS18B20_Write_Byte(uint8_t dat)
  uint8_t j;
  uint8_t testb;
  DS18B20_DQ_OUT;
  for (j = 1; j <= 8; j++)
    testb = dat & 0x01;
    dat = dat >> 1;
    if (testb)
      DS18B20_DQ_OUTL; // Write 1
    //   delay_cycles(2 * 32);
      delay_us(2);
      DS18B20_DQ_OUTH;
    //   delay_cycles(60 * 32);
      delay_us(60);
    else
      DS18B20_DQ_OUTL; // Write 0
      delay_us(60);
      DS18B20_DQ_OUTH;
      delay_us(12);
/* 启动芯片 */
void DS18B20_Start(void) // ds1820 start convert
  DS18B20_Rst();
  DS18B20_Check();
  DS18B20_Write_Byte(0xcc); // skip rom
  DS18B20_Write_Byte(0x44); // convert
float DS18B20_Get_Temp(void)
  uint8_t temp;
  uint8_t TL, TH;
  int16_t tem;
  float fValue = 0.0;
  DS18B20_Start(); // ds1820 start convert
  DS18B20_Rst();
  DS18B20_Check();
  DS18B20_Write_Byte(0xbe); // convert
  TL = DS18B20_Read_Byte(); // LSB
  TH = DS18B20_Read_Byte(); // MSB
  if (TH > 7)
    TH = ~TH;
    TL = ~TL;
    temp = 0; // 温度为负
  else
    temp = 1; // 温度为正
  tem = TH;   // 获得高八位
  tem <<= 8;
  tem += TL;                // 获得底八位
  fValue = (float)tem * 0.0625; // 转换
  if (temp)
    return fValue; // 返回温度值
  else
    return -fValue;
在中断函数中调用温度读取,并进行温度判断:
void TIMER_0_INST_IRQHandler(void)
	 switch(DL_TimerG_getPendingInterrupt(TIMER_0_INST))
	    case DL_TIMER_IIDX_ZERO:
	        TimerCnt++;
	        if(TimerCnt >=100)
	            TimerCnt=0;
	            tempval = DS18B20_Get_Temp();//温度数据一秒读取一次
	            if(tempval > 30)
	            	BeepON;
	            else
	            	BeepOFF;
	        break;
	    default:
	        break;
在主函数中调用温度显示函数:
extern uint16_t tempval;
int main(void)
    SYSCFG_DL_init();
    NVIC_EnableIRQ(TIMER_0_INST_INT_IRQN);
    while (1)
    	Disp_Data(tempval);
由于传入的参数是无符号整型,所以没有小数,实际效果:
