板子到手,计划通过arduino实现传感器读数,屏幕显示读数,并将读数通过udp推送到指定的服务器
屏幕库用了
传感器库直接使用厂家的
代码如下:
#include <LovyanGFX.hpp>
#include <M5_DLight.h>
#include <WiFi.h>
#include <WiFiUdp.h> // Include the WiFiUdp library
// WiFi network name and password
const char * networkName = "sun";
const char * networkPswd = "mingdemen10";
// UDP server address and port
const char * udpAddress = "192.168.0.2";
const int udpPort = 3333;
class LGFX : public lgfx::LGFX_Device
lgfx::Panel_ST7789 _panel_instance;
lgfx::Bus_SPI _bus_instance;
lgfx::Light_PWM _light_instance;
public:
LGFX(void)
auto cfg = _bus_instance.config();
cfg.freq_write = 40000000;
cfg.freq_read = 16000000;
cfg.pin_sclk = 36;
cfg.pin_mosi = 35;
cfg.pin_miso = 37;
cfg.pin_dc = 40;
_bus_instance.config(cfg);
_panel_instance.setBus(&_bus_instance);
auto cfg_panel = _panel_instance.config();
cfg_panel.pin_cs = 42;
cfg_panel.pin_rst = 41;
cfg_panel.pin_busy = -1;
cfg_panel.invert = true;
cfg_panel.panel_width = 135;
cfg_panel.panel_height = 240;
cfg_panel.offset_x = 52;
cfg_panel.offset_y = 40;
_panel_instance.config(cfg_panel);
auto cfg_light = _light_instance.config();
cfg_light.pin_bl = 45;
cfg_light.invert = false;
cfg_light.freq = 200;
cfg_light.pwm_channel = 7;
_light_instance.config(cfg_light);
_panel_instance.setLight(&_light_instance);
setPanel(&_panel_instance);
LGFX display;
static LGFX_Sprite sprite(&display);
M5_DLight sensor;
uint16_t lux;
WiFiUDP udp; // Create a WiFiUDP instance
void setup(void)
display.init();
Serial.begin(115200);
display.setRotation(1);
display.setTextSize(2);
display.setTextDatum(lgfx::MC_DATUM);
sprite.createSprite(135, 240);
Serial.println("Sensor begin...");
sensor.begin(&Wire, 17, 18); // HAT DLight
sensor.setMode(CONTINUOUSLY_H_RESOLUTION_MODE);
// Connect to WiFi
Serial.print("Connecting to ");
Serial.println(networkName);
WiFi.begin(networkName, networkPswd);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
udp.begin(udpPort); // Start UDP service
char info[80];
void loop(void)
lux = sensor.getLUX();
sprintf(info, "lux: %d", lux);
sprite.fillSprite(TFT_BLACK);
sprite.drawString(info, 40, 40);
sprite.pushSprite(0, 0);
sprintf(info, "IP: %s", WiFi.localIP().toString().c_str());
display.drawString(info, 60, 100);
// Send UDP packet
char udpInfo[64];
sprintf(udpInfo, "lux: %d", lux); // Format the lux value into a string
udp.beginPacket(udpAddress, udpPort); // Start a packet to the UDP server
udp.println(udpInfo); // Send the lux value as a UDP packet
udp.endPacket(); // Finalize the packet
Serial.println(info);
delay(100);
}效果展示:
功能实现,顺手建模个外壳,保护一下屏幕:
模型地址(记得助力):https://makerworld.com.cn/zh/models/653143
今天就先到这里。
