本篇源自:优秀创作者 lulugl
本文将介绍基于米尔电子MYD-LR3576开发板(米尔基于瑞芯微 RK3576开发板)的创建机器学习环境方案测试。
【前言】
【米尔-瑞芯微RK3576核心板及开发板】具有6TpsNPU以及GPU,因此是学习机器学习的好环境,为此结合《深度学习的数学——使用Python语言》
1、使用vscode 连接远程开发板
2、使用conda新建虚拟环境:
root@myd-lr3576x-debian:/home/myir/pro_learn# conda create --name myenv python=3.9
执行结果如下:
root@myd-lr3576x-debian:/home/myir/pro_learn# conda create --name myenv python=3.9 Channels: - defaults Platform: linux-aarch64 Collecting package metadata (repodata.json): done Solving environment: done ## Package Plan ## environment location: /root/miniconda3/envs/myenv added / updated specs: - python=3.9 The following packages will be downloaded: package | build ---------------------------|----------------- _libgcc_mutex-0.1 | main 2 KB defaults _openmp_mutex-5.1 | 51_gnu 1.4 MB defaults ca-certificates-2024.11.26 | hd43f75c_0 131 KB defaults ld_impl_linux-aarch64-2.40 | h48e3ba3_0 848 KB defaults libffi-3.4.4 | h419075a_1 140 KB defaults libgcc-ng-11.2.0 | h1234567_1 1.3 MB defaults libgomp-11.2.0 | h1234567_1 466 KB defaults libstdcxx-ng-11.2.0 | h1234567_1 779 KB defaults ncurses-6.4 | h419075a_0 1.1 MB defaults openssl-3.0.15 | h998d150_0 5.2 MB defaults pip-24.2 | py39hd43f75c_0 2.2 MB defaults python-3.9.20 | h4bb2201_1 24.7 MB defaults readline-8.2 | h998d150_0 381 KB defaults setuptools-75.1.0 | py39hd43f75c_0 1.6 MB defaults sqlite-3.45.3 | h998d150_0 1.5 MB defaults tk-8.6.14 | h987d8db_0 3.5 MB defaults tzdata-2024b | h04d1e81_0 115 KB defaults wheel-0.44.0 | py39hd43f75c_0 111 KB defaults xz-5.4.6 | h998d150_1 662 KB defaults zlib-1.2.13 | h998d150_1 113 KB defaults ------------------------------------------------------------ Total: 46.2 MB The following NEW packages will be INSTALLED: _libgcc_mutex anaconda/pkgs/main/linux-aarch64::_libgcc_mutex-0.1-main _openmp_mutex anaconda/pkgs/main/linux-aarch64::_openmp_mutex-5.1-51_gnu ca-certificates anaconda/pkgs/main/linux-aarch64::ca-certificates-2024.11.26-hd43f75c_0 ld_impl_linux-aar~ anaconda/pkgs/main/linux-aarch64::ld_impl_linux-aarch64-2.40-h48e3ba3_0 libffi anaconda/pkgs/main/linux-aarch64::libffi-3.4.4-h419075a_1 libgcc-ng anaconda/pkgs/main/linux-aarch64::libgcc-ng-11.2.0-h1234567_1 libgomp anaconda/pkgs/main/linux-aarch64::libgomp-11.2.0-h1234567_1 libstdcxx-ng anaconda/pkgs/main/linux-aarch64::libstdcxx-ng-11.2.0-h1234567_1 ncurses anaconda/pkgs/main/linux-aarch64::ncurses-6.4-h419075a_0 openssl anaconda/pkgs/main/linux-aarch64::openssl-3.0.15-h998d150_0 pip anaconda/pkgs/main/linux-aarch64::pip-24.2-py39hd43f75c_0 python anaconda/pkgs/main/linux-aarch64::python-3.9.20-h4bb2201_1 readline anaconda/pkgs/main/linux-aarch64::readline-8.2-h998d150_0 setuptools anaconda/pkgs/main/linux-aarch64::setuptools-75.1.0-py39hd43f75c_0 sqlite anaconda/pkgs/main/linux-aarch64::sqlite-3.45.3-h998d150_0 tk anaconda/pkgs/main/linux-aarch64::tk-8.6.14-h987d8db_0 tzdata anaconda/pkgs/main/noarch::tzdata-2024b-h04d1e81_0 wheel anaconda/pkgs/main/linux-aarch64::wheel-0.44.0-py39hd43f75c_0 xz anaconda/pkgs/main/linux-aarch64::xz-5.4.6-h998d150_1 zlib anaconda/pkgs/main/linux-aarch64::zlib-1.2.13-h998d150_1 Proceed ([y]/n)? y Downloading and Extracting Packages: Preparing transaction: done Verifying transaction: done Executing transaction: done # # To activate this environment, use # # $ conda activate myenv # # To deactivate an active environment, use # # $ conda deactivate root@myd-lr3576x-debian:/home/myir/pro_learn# 然后再激活环境: root@myd-lr3576x-debian:/home/myir/pro_learn# conda activate myenv (myenv) root@myd-lr3576x-debian:/home/myir/pro_learn#
2、查看python版本号:
(myenv) root@myd-lr3576x-debian:/home/myir/pro_learn# python --version Python 3.9.20
3、使用conda install numpy等来安装组件,安装好后用pip list查看
编写测试代码:
import numpy as np from sklearn.datasets import load_digits from sklearn.neural_network import MLPClassifier d = load_digits() digits = d["data"] labels = d["target"] N = 200 idx = np.argsort(np.random.random(len(labels))) xtest, ytest = digits[idx[:N]], labels[idx[:N]] xtrain, ytrain = digits[idx[N:]], labels[idx[N:]] clf = MLPClassifier(hidden_layer_sizes=(128, )) clf.fit(xtrain, ytrain) score = clf.score(xtest, ytest) pred = clf.predict(xtest) err = np.where(pred != ytest)[0] print("score:", score) print("err:", err) print("actual:", ytest[err]) print("predicted:", pred[err])
在代码中,使用MLPClassifier对象进行建模,训练测试,训练数据集非常快,训练4次后可以达到0.99:
【总结】
米尔的这款开发板,搭载3576这颗强大的芯片,搭建了深度学习的环境,进行了基础的数据集训练,效果非常好!在书中记录训练要几分钟,但是这在这款开发板上测试,只要几秒钟就训练完毕,书中说总体准确率为0.97,但是我在这款开发板上有0.99的良好效果!
