自己焊了一块板子,44box 的.
编译了 uclinux 后,把 image.ram 加载到板上,功能全部正常,也能 ping 通 192.168.0.128.但当我把 image.rom 用 fluted 直接烧到 flash 里面,uclinux 可以启动,其他功能也正常,但就是 ping 不通 192.168.0.128.请问这个大概是什么问题?从 image.rom 启动 :
/> ping 192.168.0.9 PING 192.168.0.9 (192.168.0.9): 56 data bytes 64 bytes from 192.168.0.9: icmp_seq=0 ttl=64 time=7080.0 ms 64 bytes from 192.168.0.9: icmp_seq=1 ttl=64 time=6070.0 ms 64 bytes from 192.168.0.9: icmp_seq=2 ttl=64 time=6060.0 ms 64 bytes from 192.168.0.9: icmp_seq=3 ttl=64 time=5060.0 ms 64 bytes from 192.168.0.9: icmp_seq=4 ttl=64 time=5050.0 ms 64 bytes from 192.168.0.9: icmp_seq=5 ttl=64 time=4060.0 ms 64 bytes from 192.168.0.9: icmp_seq=6 ttl=64 time=4050.0 ms 64 bytes from 192.168.0.9: icmp_seq=7 ttl=64 time=3050.0 ms 64 bytes from 192.168.0.9: icmp_seq=8 ttl=64 time=3040.0 ms 64 bytes from 192.168.0.9: icmp_seq=9 ttl=64 time=2040.0 ms 64 bytes from 192.168.0.9: icmp_seq=10 ttl=64 time=2030.0 ms 64 bytes from 192.168.0.9: icmp_seq=11 ttl=64 time=1030.0 ms 64 bytes from 192.168.0.9: icmp_seq=12 ttl=64 time=1020.0 ms 64 bytes from 192.168.0.9: icmp_seq=13 ttl=64 time=20.0 ms 64 bytes from 192.168.0.9: icmp_seq=0 ttl=64 time=17170.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=1 ttl=64 time=17160.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=2 ttl=64 time=16160.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=3 ttl=64 time=16150.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=4 ttl=64 time=15150.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=5 ttl=64 time=15150.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=6 ttl=64 time=14150.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=7 ttl=64 time=14140.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=8 ttl=64 time=13140.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=9 ttl=64 time=13130.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=10 ttl=64 time=12130.0 ms (DUP!) 64 bytes from 192.168.0.9: icmp_seq=11 ttl=64 time=12120.0 ms (DUP!)
从 image.ram 启动是正常的 :
/> ping 192.168.0.9 PING 192.168.0.9 (192.168.0.9): 56 data bytes 64 bytes from 192.168.0.9: icmp_seq=0 ttl=64 time=10.0 ms 64 bytes from 192.168.0.9: icmp_seq=1 ttl=64 time=0.0 ms 64 bytes from 192.168.0.9: icmp_seq=2 ttl=64 time=0.0 ms 64 bytes from 192.168.0.9: icmp_seq=3 ttl=64 time=0.0 ms 64 bytes from 192.168.0.9: icmp_seq=4 ttl=64 time=0.0 ms 64 bytes from 192.168.0.9: icmp_seq=5 ttl=64 time=0.0 ms 64 bytes from 192.168.0.9: icmp_seq=6 ttl=64 time=0.0 ms 64 bytes from 192.168.0.9: icmp_seq=7 ttl=64 time=0.0 ms
--- 192.168.0.9 ping statistics --- 13 packets transmitted, 13 packets received, 0% packet loss round-trip min/avg/max = 0.0/0.7/10.0 ms
[em06]
