一、硬件
RGB LED 连接方式
二、PWM 配置流程
在 pin_mux.c 中配置引脚复用为 PWM 功能 IOCON_PIO_FUNC1 表示复用为 PWM,
核心代码实现
static void PWM_DRV_InitPwm(void)
uint16_t deadTimeVal;
pwm_signal_param_t pwmSignal[2];
uint32_t pwmSourceClockInHz;
uint32_t pwmFrequencyInHz = APP_DEFAULT_PWM_FREQUENCY;
pwmSourceClockInHz = PWM_SRC_CLK_FREQ;
/* Set deadtime count, we set this to about 650ns */
deadTimeVal = ((uint64_t)pwmSourceClockInHz * 650) / 1000000000;
pwmSignal[0].pwmChannel = kPWM_PwmA;
pwmSignal[0].level = kPWM_HighTrue;
pwmSignal[0].dutyCyclePercent = 50; /* 1 percent dutycycle */
pwmSignal[0].deadtimeValue = deadTimeVal;
pwmSignal[0].faultState = kPWM_PwmFaultState0;
pwmSignal[0].pwmchannelenable = true;
pwmSignal[1].pwmChannel = kPWM_PwmB;
pwmSignal[1].level = kPWM_HighTrue;
pwmSignal[1].dutyCyclePercent = 50;
pwmSignal[1].deadtimeValue = deadTimeVal;
pwmSignal[1].faultState = kPWM_PwmFaultState0;
pwmSignal[1].pwmchannelenable = true;
PWM_SetupPwm(FLEXPWM0, kPWM_Module_0, pwmSignal, 1, kPWM_SignedCenterAligned, pwmFrequencyInHz,
pwmSourceClockInHz);
PWM_SetupPwm(FLEXPWM1, kPWM_Module_2, pwmSignal, 2, kPWM_SignedCenterAligned, pwmFrequencyInHz,
pwm_config_t pwmConfig;
pwm_fault_param_t faultConfig;
uint32_t pwmVal1 = 2;
uint32_t pwmVal2 = 4;
uint32_t pwmVal3 = 5;
pwmConfig.enableDebugMode = false;
pwmConfig.reloadSelect = kPWM_LocalReload;
pwmConfig.clockSource = kPWM_BusClock;
pwmConfig.prescale = kPWM_Prescale_Divide_1;
pwmConfig.initializationControl = kPWM_Initialize_LocalSync;
pwmConfig.forceTrigger = kPWM_Force_Local;
pwmConfig.reloadFrequency = kPWM_LoadEveryOportunity;
pwmConfig.reloadLogic = kPWM_ReloadImmediate;
pwmConfig.pairOperation = kPWM_Independent;
PWM_GetDefaultConfig(&pwmConfig);
#ifndef BOARD_INIT_DEBUG_CONSOLE_PERIPHERAL
/* Init FSL debug console. */
BOARD_InitDebugConsole();
#endif
#ifdef DEMO_PWM_CLOCK_DEVIDER
pwmConfig.prescale = DEMO_PWM_CLOCK_DEVIDER;
#endif
/* Use full cycle reload */
pwmConfig.reloadLogic = kPWM_ReloadPwmFullCycle;
/* PWM A & PWM B form a complementary PWM pair */
pwmConfig.pairOperation = kPWM_ComplementaryPwmA;
pwmConfig.enableDebugMode = true;
/* Initialize submodule 0 */
if (PWM_Init(FLEXPWM0, kPWM_Module_0, &pwmConfig) == kStatus_Fail)
PRINTF("PWM initialization failed\n");
return 1;
if (PWM_Init(FLEXPWM1, kPWM_Module_2, &pwmConfig) == kStatus_Fail)
return 1;
/* Initialize submodule 1, make it use same counter clock as submodule 0. */
pwmConfig.clockSource = kPWM_Submodule0Clock;
pwmConfig.initializationControl = kPWM_Initialize_MasterSync;
PWM_FaultDefaultConfig(&faultConfig);
#ifdef DEMO_PWM_FAULT_LEVEL
faultConfig.faultLevel = DEMO_PWM_FAULT_LEVEL;
#endif
/* Sets up the PWM fault protection */
PWM_SetupFaults(FLEXPWM0, kPWM_Fault_0, &faultConfig);
PWM_SetupFaults(FLEXPWM0, kPWM_Fault_1, &faultConfig);
PWM_SetupFaults(FLEXPWM0, kPWM_Fault_2, &faultConfig);
PWM_SetupFaults(FLEXPWM0, kPWM_Fault_3, &faultConfig);
PWM_SetupFaults(FLEXPWM1, kPWM_Fault_0, &faultConfig);
PWM_SetupFaults(FLEXPWM1, kPWM_Fault_1, &faultConfig);
PWM_SetupFaults(FLEXPWM1, kPWM_Fault_2, &faultConfig);
PWM_SetupFaults(FLEXPWM1, kPWM_Fault_3, &faultConfig);
/* Set PWM fault disable mapping for submodule 0/1/2 */
PWM_SetupFaultDisableMap(FLEXPWM0, kPWM_Module_0, kPWM_PwmA, kPWM_faultchannel_0,
kPWM_FaultDisable_0 | kPWM_FaultDisable_1 | kPWM_FaultDisable_2 | kPWM_FaultDisable_3);
PWM_SetupFaultDisableMap(FLEXPWM1, kPWM_Module_2, kPWM_PwmA, kPWM_faultchannel_0,
PWM_SetupFaultDisableMap(FLEXPWM1, kPWM_Module_2, kPWM_PwmB, kPWM_faultchannel_0,
PWM_DRV_InitPwm();
/* Set the load okay bit for all submodules to load registers from their buffer */
PWM_SetPwmLdok(FLEXPWM0, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2, true);
PWM_SetPwmLdok(FLEXPWM1, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2, true);
/* Start the PWM generation from Submodules 0, 1 and 2 */
PWM_StartTimer(FLEXPWM0, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2);
PWM_StartTimer(FLEXPWM1, kPWM_Control_Module_0 | kPWM_Control_Module_1 | kPWM_Control_Module_2);
int flag1 = 1;
int flag2 = 1;
int flag3 = 1;
/* Enter an infinite loop, just incrementing a counter. */
while(1) {
/* Delay at least 100 PWM periods. */
SDK_DelayAtLeastUs((1000000U / APP_DEFAULT_PWM_FREQUENCY) * 100, SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY);
pwmVal1 += flag1 * 2;
pwmVal2 += flag2 * 4;
pwmVal3 += flag3 * 5;
/* Reset the duty cycle percentage */
if (pwmVal1 == 100)
flag1 = -1;
if (pwmVal1 == 0)
flag1 = 1;
if (pwmVal2 == 100)
flag2 = -1;
if (pwmVal2 == 0)
flag2 = 1;
if (pwmVal3 == 100)
flag3 = -1;
if (pwmVal3 == 0)
flag3 = 1;
/* Update duty cycles for all 3 PWM signals */
PWM_UpdatePwmDutycycle(FLEXPWM0, kPWM_Module_0, kPWM_PwmA, kPWM_SignedCenterAligned, pwmVal1);
PWM_UpdatePwmDutycycle(FLEXPWM1, kPWM_Module_2, kPWM_PwmA, kPWM_SignedCenterAligned, pwmVal2);
PWM_UpdatePwmDutycycle(FLEXPWM1, kPWM_Module_2, kPWM_PwmB, kPWM_SignedCenterAligned, pwmVal3);
}三.PWM脚定义
进入引脚定义页面,对RGB灯的三个引脚进行定义,定义为FlexPWM模式。
PWM输出引脚包括PWM种类PWM0/PWM1、PWM通道A/B及PWM的子模块,P3_13引脚的路由信号相关参数如下。
四.实现效果
