电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » 【Freertos】任务管理
共5条 1/1 1 跳转至
【Freertos】任务管理
2025-05-12 20:58:22   被打赏 10 分(兑奖)     打赏
【简介】
            FreeRTOS 中,每个执行线程都被称为任务。每个任务在内核中使用一个TCB( A task control block (TCB))结构进行管理,本地使用的10.3.1版本中对应的定义如下:
 * Task control block.  A task control block (TCB) is allocated for each task,
 * and stores task state information, including a pointer to the task's context
 * (the task's run time environment, including register values)
typedef struct tskTaskControlBlock 			/* The old naming convention is used to prevent breaking kernel aware debuggers. */
	volatile StackType_t	*pxTopOfStack;	/*< Points to the location of the last item placed on the tasks stack.  THIS MUST BE THE FIRST MEMBER OF THE TCB STRUCT. */
	#if ( portUSING_MPU_WRAPPERS == 1 )
		xMPU_SETTINGS	xMPUSettings;		/*< The MPU settings are defined as part of the port layer.  THIS MUST BE THE SECOND MEMBER OF THE TCB STRUCT. */
	#endif
	ListItem_t			xStateListItem;	/*< The list that the state list item of a task is reference from denotes the state of that task (Ready, Blocked, Suspended ). */
	ListItem_t			xEventListItem;		/*< Used to reference a task from an event list. */
	UBaseType_t			uxPriority;			/*< The priority of the task.  0 is the lowest priority. */
	StackType_t			*pxStack;			/*< Points to the start of the stack. */
	char				pcTaskName[ configMAX_TASK_NAME_LEN ];/*< Descriptive name given to the task when created.  Facilitates debugging only. */ /*lint !e971 Unqualified char types are allowed for strings and single characters only. */
	#if ( ( portSTACK_GROWTH > 0 ) || ( configRECORD_STACK_HIGH_ADDRESS == 1 ) )
		StackType_t		*pxEndOfStack;		/*< Points to the highest valid address for the stack. */
	#endif
	#if ( portCRITICAL_NESTING_IN_TCB == 1 )
		UBaseType_t		uxCriticalNesting;	/*< Holds the critical section nesting depth for ports that do not maintain their own count in the port layer. */
	#endif
	#if ( configUSE_TRACE_FACILITY == 1 )
		UBaseType_t		uxTCBNumber;		/*< Stores a number that increments each time a TCB is created.  It allows debuggers to determine when a task has been deleted and then recreated. */
		UBaseType_t		uxTaskNumber;		/*< Stores a number specifically for use by third party trace code. */
	#endif
	#if ( configUSE_MUTEXES == 1 )
		UBaseType_t		uxBasePriority;		/*< The priority last assigned to the task - used by the priority inheritance mechanism. */
		UBaseType_t		uxMutexesHeld;
	#endif
	#if ( configUSE_APPLICATION_TASK_TAG == 1 )
		TaskHookFunction_t pxTaskTag;
	#endif
	#if( configNUM_THREAD_LOCAL_STORAGE_POINTERS > 0 )
		void			*pvThreadLocalStoragePointers[ configNUM_THREAD_LOCAL_STORAGE_POINTERS ];
	#endif
	#if( configGENERATE_RUN_TIME_STATS == 1 )
		uint32_t		ulRunTimeCounter;	/*< Stores the amount of time the task has spent in the Running state. */
	#endif
	#if ( configUSE_NEWLIB_REENTRANT == 1 )
		/* Allocate a Newlib reent structure that is specific to this task.
		Note Newlib support has been included by popular demand, but is not
		used by the FreeRTOS maintainers themselves.  FreeRTOS is not
		responsible for resulting newlib operation.  User must be familiar with
		newlib and must provide system-wide implementations of the necessary
		stubs. Be warned that (at the time of writing) the current newlib design
		implements a system-wide malloc() that must be provided with locks.
		See the third party link http://www.nadler.com/embedded/newlibAndFreeRTOS.html
		for additional information. */
		struct	_reent xNewLib_reent;
	#endif
	#if( configUSE_TASK_NOTIFICATIONS == 1 )
		volatile uint32_t ulNotifiedValue;
		volatile uint8_t ucNotifyState;
	#endif
	/* See the comments in FreeRTOS.h with the definition of
	tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE. */
	#if( tskSTATIC_AND_DYNAMIC_ALLOCATION_POSSIBLE != 0 ) /*lint !e731 !e9029 Macro has been consolidated for readability reasons. */
		uint8_t	ucStaticallyAllocated; 		/*< Set to pdTRUE if the task is a statically allocated to ensure no attempt is made to free the memory. */
	#endif
	#if( INCLUDE_xTaskAbortDelay == 1 )
		uint8_t ucDelayAborted;
	#endif
	#if( configUSE_POSIX_ERRNO == 1 )
		int iTaskErrno;
	#endif
} tskTCB;
TCB 结构体包含任务的name,任务栈的地址及状态和event 管理的链表成员,该成员会将TCB结构挂载道对应的链表中。
任务状态:
应用程序可以包含多个任务。如果运行应用程序的微控制器只有一个核(core),那么在任意给定时间,实际上只会有一个任务被执行。这就意味着一个任务可以有一个或两个状态,即运行状态(Running)和非运行状态,非运行态又可划分为若干状态(Ready/Blocked/Suspended);
就绪状态
如果任务处于非运行状态,但既没有阻塞也没有挂起,则这个任务处于就绪(ready,准备或就绪)状态。处于就绪态的任务能够被运行,但只是”准备(ready)”运行,而当前尚未运行。
挂起状态
“挂起(suspended)”也是非运行状态的子状态。处于挂起状态的任务对调度器而言是不可见的。让一个任务进入挂起状态的唯一办法就是调用 vTaskSuspend() API 函数;而 把 一 个 挂 起 状 态 的 任 务 唤 醒 的 唯 一 途 径 就 是 调 用 vTaskResume() 或vTaskResumeFromISR() API 函数。大多数应用程序中都不会用到挂起状态。
对应的状态转换关系如下:
同一时刻任务只能处于上述状态的一种状态,内核的TCB模块中的如下成员会将任务挂载到对应的任务状态链表中。
FreeRtos 使用了如下的链表来管理任务的状态
pxReadyTasksLists:一个数组,每个优先级对应一个列表,存储处于就绪状态的任务,每个任务ready 时挂在对应优先级的的ready list 上,任务切换时优先从高优先级的链表上查找ready 的任务,从以下代码也可以看出在freertos 下任务优先级数值越大优先级越高。
    #define taskSELECT_HIGHEST_PRIORITY_TASK()                                \
        UBaseType_t uxTopPriority = uxTopReadyPriority;                       \
        /* Find the highest priority queue that contains ready tasks. */      \
        while( listLIST_IS_EMPTY( &( pxReadyTasksLists[ uxTopPriority ] ) ) ) \
            configASSERT( uxTopPriority );                                    \
            --uxTopPriority;                                                  \
        /* listGET_OWNER_OF_NEXT_ENTRY indexes through the list, so the tasks of \
         * the  same priority get an equal share of the processor time. */                    \
        listGET_OWNER_OF_NEXT_ENTRY( pxCurrentTCB, &( pxReadyTasksLists[ uxTopPriority ] ) ); \
        uxTopReadyPriority = uxTopPriority;                                                   \
    } /* taskSELECT_HIGHEST_PRIORITY_TASK */
xDelayedTaskList1 和 xDelayedTaskList2:两个列表用于存储需要延时执行的任务
pxDelayedTaskList 和 pxOverflowDelayedTaskList:指向当前使用的延时任务列表的指针
xPendingReadyList:存储等待加入就绪队列的任务
对应prvInitialiseTaskLists 函数会创建第一个任务的时候调用该接口对任务管理的链表进行初始化,并将创建的TCB加入到链表进行管理工作。
static void prvInitialiseTaskLists( void )
	for( uxPriority = ( UBaseType_t ) 0U; uxPriority < ( UBaseType_t ) configMAX_PRIORITIES; uxPriority++ )
		vListInitialise( &( pxReadyTasksLists[ uxPriority ] ) );
	vListInitialise( &xDelayedTaskList1 );
	vListInitialise( &xDelayedTaskList2 );
	vListInitialise( &xPendingReadyList );
	#if ( INCLUDE_vTaskDelete == 1 )
		vListInitialise( &xTasksWaitingTermination );
	#endif /* INCLUDE_vTaskDelete */
	#if ( INCLUDE_vTaskSuspend == 1 )
		vListInitialise( &xSuspendedTaskList );
	#endif /* INCLUDE_vTaskSuspend */
	/* Start with pxDelayedTaskList using list1 and the pxOverflowDelayedTaskList
	using list2. */
	pxDelayedTaskList = &xDelayedTaskList1;
	pxOverflowDelayedTaskList = &xDelayedTaskList2;
在IAR 下也可以查看任务状体信息也可以查看到对应的任务状态。
在IAR的插件下任务的状态显示和上述的状态介绍稍有点差距,IAR将BLOCKED有细化为如果调用delay函数让出CPU使用权的状态标记为DELAYING状态。
空闲任务:
在FreeRtos中在没有用户任务处于ready 状态时,会运行IDLE任务,在调用 vTaskStartScheduler()启动调度器时,调度器会自动创建一个空闲任务。空闲任务是
一个非常短小的循环——和最早的示例任务十分相似,总是可以运行。空闲任务拥有最低优先级(优先级 0)以保证其不会妨碍具有更高优先级的应用任务进入运行态。运行在最低优先级可以保证一旦有更高优先级的任务进入就绪态,空闲任务就会立即切出运行态。
 * The Idle task.
 * The portTASK_FUNCTION() macro is used to allow port/compiler specific
 * language extensions.  The equivalent prototype for this function is:
 * void prvIdleTask( void *pvParameters );
static portTASK_FUNCTION( prvIdleTask, pvParameters )
	/* Stop warnings. */
	( void ) pvParameters;
	/** THIS IS THE RTOS IDLE TASK - WHICH IS CREATED AUTOMATICALLY WHEN THE
	SCHEDULER IS STARTED. **/
	/* In case a task that has a secure context deletes itself, in which case
	the idle task is responsible for deleting the task's secure context, if
	any. */
	portALLOCATE_SECURE_CONTEXT( configMINIMAL_SECURE_STACK_SIZE );
	for( ;; )
		/* See if any tasks have deleted themselves - if so then the idle task
		is responsible for freeing the deleted task's TCB and stack. */
		prvCheckTasksWaitingTermination();
		#if ( configUSE_PREEMPTION == 0 )
			/* If we are not using preemption we keep forcing a task switch to
			see if any other task has become available.  If we are using
			preemption we don't need to do this as any task becoming available
			will automatically get the processor anyway. */
			taskYIELD();
		#endif /* configUSE_PREEMPTION */
		#if ( ( configUSE_PREEMPTION == 1 ) && ( configIDLE_SHOULD_YIELD == 1 ) )
			/* When using preemption tasks of equal priority will be
			timesliced.  If a task that is sharing the idle priority is ready
			to run then the idle task should yield before the end of the
			timeslice.
			A critical region is not required here as we are just reading from
			the list, and an occasional incorrect value will not matter.  If
			the ready list at the idle priority contains more than one task
			then a task other than the idle task is ready to execute. */
			if( listCURRENT_LIST_LENGTH( &( pxReadyTasksLists[ tskIDLE_PRIORITY ] ) ) > ( UBaseType_t ) 1 )
				taskYIELD();
			else
				mtCOVERAGE_TEST_MARKER();
		#endif /* ( ( configUSE_PREEMPTION == 1 ) && ( configIDLE_SHOULD_YIELD == 1 ) ) */
		#if ( configUSE_IDLE_HOOK == 1 )
			extern void vApplicationIdleHook( void );
			/* Call the user defined function from within the idle task.  This
			allows the application designer to add background functionality
			without the overhead of a separate task.
			NOTE: vApplicationIdleHook() MUST NOT, UNDER ANY CIRCUMSTANCES,
			CALL A FUNCTION THAT MIGHT BLOCK. */
			vApplicationIdleHook();
		#endif /* configUSE_IDLE_HOOK */
上述代码:
29行回进行对删除任务的TCB/STACK 资源的回收
37行如果调度器未开启抢占调度,则会进行一次调度器调度让出CPU使用权,此时没有Ready 的任务会再次进入IDLE任务
54行开启抢占调度,此时有高优先级Ready 状态的任务则会主动让出CPU切换到高优先级的任务运行
72行可以定义用户的IDLE hook 函数添加自定义处理。
空闲任务钩子函数必须遵从以下规则
1. 绝不能阻或挂起。空闲任务只会在其它任务都不运行时才会被执行(除非有应用任务共享空闲任务优先级)。以任何方式阻塞空闲务都可能导致没有任务能够进入运行态!
2. 如果应用程序用到了 vTaskDelete() AP 函数,则空闲钩子函数必须能够尽快返回。因为在任务被删除后,空闲任务负责回收内资源。如果空闲任务一直运行在钩子函数中,则无法进行回收工作。
以下是官方对IDLE hook 的使用说明:
上述IDLE task 的处理中,如果用户定义的和IDLE 任务共享优先级定义相同的优先级,我们可以通过配置 ( configUSE_PREEMPTION == 1 ) && ( configIDLE_SHOULD_YIELD == 1 ) ,在进入IDLE 任务时如果用户定义的和IDLE相同优先级的任务,此时IDLE会主动让出CPU 切换到用户成语中,提高运行效率减少IDLE任务对CPU  的占用。
以下 configIDLE_SHOULD_YIELD == 0 的任务运行状态图
以下是相同场景下 configIDLE_SHOULD_YIELD == 1 的任务运行状态图
2025-05-12 22:02:21     打赏
2025-05-12 22:03:36     打赏
2025-05-12 22:05:30     打赏
2025-08-11 15:55:49     打赏
如何估算任务大概需要开辟多大堆栈?
共5条 1/1 1 跳转至
