完成训练后,就是在开发板上实现自己的项目了。将脚本生成的项目导入到eclipse里边。
这个生成的项目中已经完成了CNN神经网络推理的实现。现在就是需要额外将摄像头采集到的数据喂给CNN网络即可。参考例程ImgCapture。通过DMA来读取摄像头。
// rps-demo
// Created using ./ai8xize.py --verbose --log --test-dir pytorch --prefix rps-demo --checkpoint-file trained/ai85-rps82-chw.pth.tar --config-file networks/rps-chw.yaml --softmax --embedded-code --device MAX78000 --compact-data --mexpress --timer 0 --display-checkpoint --fifo
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <stdio.h>
#include "mxc_device.h"
#include "mxc_sys.h"
#include "bbfc_regs.h"
#include "fcr_regs.h"
#include "icc.h"
#include "dma.h"
#include "led.h"
#include "tmr.h"
#include "pb.h"
#include "cnn.h"
#include "weights.h"
#include "sampledata.h"
#include "mxc_delay.h"
#include "camera.h"
#define TFT_ENABLE
#define IMAGE_SIZE_X (64)
#define IMAGE_SIZE_Y (64)
#define CAMERA_FREQ (10 * 1000 * 1000)
#define CNN_NUM_OUTPUTS 4 // number of classes
const char classes[CNN_NUM_OUTPUTS][10] = {"Paper", "Rock", "Scissors", "Empty"};
volatile uint32_t cnn_time; // Stopwatch
uint32_t input_0_camera[1024];
uint32_t input_1_camera[1024];
uint32_t input_2_camera[1024];
void fail(void)
printf("\n*** FAIL ***\n\n");
while (1)
void load_input(void)
int i;
const uint32_t* in0 = input_0_camera;
const uint32_t* in1 = input_1_camera;
const uint32_t* in2 = input_2_camera;
for (i = 0; i < 1024; i++)
while (((*((volatile uint32_t*)0x50000004) & 1)) != 0)
; // Wait for FIFO 0
*((volatile uint32_t*)0x50000008) = *in0++; // Write FIFO 0
while (((*((volatile uint32_t*)0x50000004) & 2)) != 0)
; // Wait for FIFO 1
*((volatile uint32_t*)0x5000000c) = *in1++; // Write FIFO 1
while (((*((volatile uint32_t*)0x50000004) & 4)) != 0)
; // Wait for FIFO 2
*((volatile uint32_t*)0x50000010) = *in2++; // Write FIFO 2
// Expected output of layer 6 for rps-demo given the sample input
int check_output(void)
if ((*((volatile uint32_t*)0x50401000)) != 0x00079c32)
return CNN_FAIL; // 0,0,0
if ((*((volatile uint32_t*)0x50401004)) != 0xfffae676)
return CNN_FAIL; // 0,0,1
if ((*((volatile uint32_t*)0x50401008)) != 0xfff657b6)
return CNN_FAIL; // 0,0,2
return CNN_OK;
// Classification layer:
static int32_t ml_data[CNN_NUM_OUTPUTS];
static q15_t ml_softmax[CNN_NUM_OUTPUTS];
void softmax_layer(void)
cnn_unload((uint32_t*)ml_data);
softmax_q17p14_q15((const q31_t*)ml_data, CNN_NUM_OUTPUTS, ml_softmax);
static uint8_t signed_to_unsigned(int8_t val)
uint8_t value;
if (val < 0) {
value = ~val + 1;
return (128 - value);
return val + 128;
int8_t unsigned_to_signed(uint8_t val)
return val - 128;
void process_camera_img(uint32_t* data0, uint32_t* data1, uint32_t* data2)
uint8_t* frame_buffer;
uint32_t imgLen;
uint32_t w, h, x, y;
uint8_t* ptr0;
uint8_t* ptr1;
uint8_t* ptr2;
uint8_t* buffer;
camera_get_image(&frame_buffer, &imgLen, &w, &h);
ptr0 = (uint8_t*)data0;
ptr1 = (uint8_t*)data1;
ptr2 = (uint8_t*)data2;
buffer = frame_buffer;
for (y = 0; y < h; y++)
for (x = 0; x < w; x++, ptr0++, ptr1++, ptr2++)
*ptr0 = (*buffer);
buffer++;
*ptr1 = (*buffer);
buffer++;
*ptr2 = (*buffer);
buffer++;
buffer++; //MSB is zero
void capture_camera_img(void)
camera_start_capture_image();
while (1)
if (camera_is_image_rcv())
return;
void convert_img_unsigned_to_signed(uint32_t* data0, uint32_t* data1, uint32_t* data2)
uint8_t* ptr0;
uint8_t* ptr1;
uint8_t* ptr2;
for (int i = 0; i < 4096; i++)
*ptr0 = unsigned_to_signed(*ptr0);
ptr0++;
*ptr1 = unsigned_to_signed(*ptr1);
ptr1++;
*ptr2 = unsigned_to_signed(*ptr2);
ptr2++;
void convert_img_signed_to_unsigned(uint32_t* data0, uint32_t* data1, uint32_t* data2)
uint8_t* ptr0;
uint8_t* ptr1;
uint8_t* ptr2;
*ptr0 = signed_to_unsigned(*ptr0);
ptr0++;
*ptr1 = signed_to_unsigned(*ptr1);
ptr1++;
*ptr2 = signed_to_unsigned(*ptr2);
ptr2++;
void cnn_wait(void)
while ((*((volatile uint32_t*)0x50100000) & (1 << 12)) != 1 << 12)
CNN_COMPLETE; // Signal that processing is complete
cnn_time = MXC_TMR_SW_Stop(MXC_TMR0);
int main(void)
int i, dma_channel;
int digs, tens;
int ret = 0;
int result[CNN_NUM_OUTPUTS] = {0};
// Wait for PMIC 1.8V to become available, about 180ms after power up.
MXC_Delay(200000);
/* Enable camera power */
Camera_Power(POWER_ON);
printf("\n\nRPS Feather Demo\n");
MXC_ICC_Enable(MXC_ICC0); // Enable cache
// Switch to 100 MHz clock
MXC_SYS_Clock_Select(MXC_SYS_CLOCK_IPO);
SystemCoreClockUpdate();
printf("Waiting...\n");
// DO NOT DELETE THIS LINE:
MXC_Delay(SEC(2)); // Let debugger interrupt if needed
// Enable peripheral, enable CNN interrupt, turn on CNN clock
// CNN clock: 50 MHz div 1
cnn_enable(MXC_S_GCR_PCLKDIV_CNNCLKSEL_PCLK, MXC_S_GCR_PCLKDIV_CNNCLKDIV_DIV1);
// Configure P2.5, turn on the CNN Boost
mxc_gpio_cfg_t gpio_out;
gpio_out.port = MXC_GPIO2;
gpio_out.mask = MXC_GPIO_PIN_5;
gpio_out.pad = MXC_GPIO_PAD_NONE;
gpio_out.func = MXC_GPIO_FUNC_OUT;
MXC_GPIO_Config(&gpio_out);
MXC_GPIO_OutSet(gpio_out.port, gpio_out.mask);
MXC_Delay(1000000);
// Initialize DMA for camera interface
MXC_DMA_Init();
dma_channel = MXC_DMA_AcquireChannel();
// Initialize camera.
printf("Init Camera.\n");
camera_init(CAMERA_FREQ);
ret = camera_setup(IMAGE_SIZE_X, IMAGE_SIZE_Y, PIXFORMAT_RGB888, FIFO_THREE_BYTE, USE_DMA,
dma_channel);
if (ret != STATUS_OK) {
printf("Error returned from setting up camera. Error %d\n", ret);
return -1;
int frame = 0;
while (1)
// Capture a single camera frame.
printf("\nCapture a camera frame %d\n", ++frame);
capture_camera_img();
// Copy the image data to the CNN input arrays.
// printf("Copy camera frame to CNN input buffers.\n");
process_camera_img(input_0_camera, input_1_camera, input_2_camera);
convert_img_unsigned_to_signed(input_0_camera, input_1_camera, input_2_camera);
cnn_init(); // Bring state machine into consistent state
cnn_load_weights(); // Load kernels
cnn_load_bias();
cnn_configure(); // Configure state machine
cnn_start(); // Start CNN processing
load_input(); // Load data input via FIFO
MXC_TMR_SW_Start(MXC_TMR0);
while (cnn_time == 0)
__WFI(); // Wait for CNN
softmax_layer();
printf("Time for CNN: %d us\n\n", cnn_time);
printf("Classification results:\n");
for (i = 0; i < CNN_NUM_OUTPUTS; i++)
digs = (1000 * ml_softmax[i] + 0x4000) >> 15;
tens = digs % 10;
digs = digs / 10;
result[i] = digs;
printf("[%7d] -> Class %d %16s: %d.%d%%\r\n", ml_data[i], i, classes[i], digs, tens);
printf("\n");
MXC_Delay(SEC(2));
return 0;
}将摄像头获得到的数据,喂给CNN网络后,会得出不同手势的概率值。
不过实际测试发现,剪刀、石头识别率还行,到了布总是识别错误。
最后附上视频:https://www.bilibili.com/video/BV1PatjzCEq1/
