前几章我们的I2C驱动是基于内核的,这一次是基于用户态的,还是使用I2C2,接线实物图如下:
探测地址
i2cdetect -y -r 2
源码
oled.c
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <sys/ioctl.h>
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include "oled.h"
#include "codetab.h"
int fd = -1;
static uint8 oled_i2c_write(int fd, uint8 reg, uint8 val)
int retries;
uint8 data[2];
int write_error = 0;
data[0] = reg;
data[1] = val;
ioctl(fd, I2C_SLAVE, OLED_ADDRESS);
for (retries = 5; retries; retries--)
if (write(fd, data, 2) == 2)
return 0;
usleep(1000);
return -1;
void WriteCmd(unsigned char I2C_Command)
oled_i2c_write(fd, OLED_COMMEND_ADDR, I2C_Command);
void WriteDat(unsigned char I2C_Data)
oled_i2c_write(fd, OLED_DATA_ADDR, I2C_Data);
void OLED_Init(void)
fd = open("/dev/i2c-2", O_RDWR); // open file and enable read and write
if (fd < 0)
perror("Can't open /dev/i2c-2 \n"); // open i2c dev file fail
exit(1);
if (ioctl(fd, I2C_SLAVE, OLED_ADDRESS) < 0)
{ //set i2c address
printf("fail to set i2c device slave address!\n");
close(fd);
usleep(100 * 1000);
WriteCmd(0xAE); //display off
WriteCmd(0x20); //Set Memory Addressing Mode
WriteCmd(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
WriteCmd(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
WriteCmd(0xc8); //Set COM Output Scan Direction
WriteCmd(0x00); //---set low column address
WriteCmd(0x10); //---set high column address
WriteCmd(0x40); //--set start line address
WriteCmd(0x81); //--set contrast control register
WriteCmd(0xff); //���ȵ��� 0x00~0xff
WriteCmd(0xa1); //--set segment re-map 0 to 127
WriteCmd(0xa6); //--set normal display
WriteCmd(0xa8); //--set multiplex ratio(1 to 64)
WriteCmd(0x3F); //
WriteCmd(0xa4); //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
WriteCmd(0xd3); //-set display offset
WriteCmd(0x00); //-not offset
WriteCmd(0xd5); //--set display clock divide ratio/oscillator frequency
WriteCmd(0xf0); //--set divide ratio
WriteCmd(0xd9); //--set pre-charge period
WriteCmd(0x22); //
WriteCmd(0xda); //--set com pins hardware configuration
WriteCmd(0x12);
WriteCmd(0xdb); //--set vcomh
WriteCmd(0x20); //0x20,0.77xVcc
WriteCmd(0x8d); //--set DC-DC enable
WriteCmd(0x14); //
WriteCmd(0xaf); //--turn on oled panel*/
void OLED_SetPos(unsigned char x, unsigned char y)
WriteCmd(0xb0+y);
WriteCmd(((x&0xf0)>>4)|0x10);
WriteCmd((x&0x0f)|0x01);
void OLED_Fill(unsigned char fill_Data)//ȫ�����
unsigned char m,n;
for(m=0;m<8;m++)
WriteCmd(0xb0+m); //page0-page1
WriteCmd(0x00); //low column start address
WriteCmd(0x10); //high column start address
for(n=0;n<128;n++)
WriteDat(fill_Data);
void OLED_CLS(void)//����
OLED_Fill(0xff);
void OLED_ON(void)
WriteCmd(0X8D); //���õ�ɱ�
WriteCmd(0X14); //������ɱ�
WriteCmd(0XAF); //OLED����
void OLED_OFF(void)
WriteCmd(0X10); //�رյ�ɱ�
WriteCmd(0XAE); //OLED����
void OLED_ShowStr(unsigned char x, unsigned char y, unsigned char ch[], unsigned char TextSize)
unsigned char c = 0,i = 0,j = 0;
switch(TextSize)
case 1:
while(ch[j] != '\0')
c = ch[j] - 32;
if(x > 126)
x = 0;
y++;
OLED_SetPos(x,y);
for(i=0;i<6;i++)
WriteDat(F6x8[c][i]);
x += 6;
j++;
}break;
case 2:
c = ch[j] - 32;
if(x > 120)
x = 0;
y++;
OLED_SetPos(x,y);
for(i=0;i<8;i++)
WriteDat(F8X16[c*16+i]);
OLED_SetPos(x,y+1);
for(i=0;i<8;i++)
WriteDat(F8X16[c*16+i+8]);
x += 8;
j++;
}break;
void OLED_ShowCN(unsigned char x, unsigned char y, unsigned char N)
unsigned char wm=0;
unsigned int adder=32*N;
OLED_SetPos(x , y);
for(wm = 0;wm < 16;wm++)
WriteDat(F16x16[adder]);
adder += 1;
OLED_SetPos(x,y + 1);
adder += 1;
void OLED_DrawBMP(unsigned char x0,unsigned char y0,unsigned char x1,unsigned char y1,unsigned char BMP[])
unsigned int j=0;
unsigned char x,y;
if(y1%8==0)
y = y1/8;
else
y = y1/8 + 1;
for(y=y0;y<y1;y++)
OLED_SetPos(x0,y);
for(x=x0;x<x1;x++)
WriteDat(BMP[j++]);
}main.c
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <fcntl.h>
#include <sys/select.h>
#include <sys/time.h>
#include <errno.h>
#include "oled.h"
extern int fd;
int main(int argc, char **argv)
OLED_Init();
OLED_Fill(0x00);
OLED_ShowStr(0,0,"pocketbeagle 2",2);
while(1)
close(fd);
return 0;
}编译
gcc oled.c main.c
运行
./a.out
