电子产品世界 » 论坛首页 » 活动中心 » 有奖活动 » SWM221CBT7显示开发板驱动TFT显示屏
共11条 1/2 1 2 跳转至
2025-11-13 20:53:37     打赏
相对于OLED屏来讲,TFT显示屏在屏幕规格大小及显示内容方面都更胜一筹。为此,可在SWM221CBT7显示开发板上尝试对TFT显示屏的驱动。
为便于后续对硬件驱动方式的支持,这里是选取相应的SPI引脚以模拟的方式来实现,具体的引脚连接关系为:
CS-----PB4
RST-----PA2
DC-----PB5
SDI-----PB12
SCK-----PB11
BL-----PB13
开发板为支持LCD屏显示所提供的引脚资源如图1所示:
1  LCD屏所用引脚资源
为将所用引脚配置为输出模式,其配置函数为:
void SPI_CONFIG()
GPIO_Init(GPIOB, PIN4, 1, 0, 0, 0);
GPIO_Init(GPIOB, PIN5, 1, 0, 0, 0);
GPIO_Init(GPIOB, PIN11, 1, 0, 0, 0);
GPIO_Init(GPIOB, PIN12, 1, 0, 0, 0);
GPIO_Init(GPIOB, PIN13, 1, 0, 0, 0);
GPIO_Init(GPIOA, PIN2, 1, 0, 0, 0);
为便于控制高低电平的输出,所定义的语句为:
#define LCD_CS_High()   GPIO_SetBit(GPIOB, PIN4)
#define LCD_CS_Low()    GPIO_ClrBit(GPIOB, PIN4)
#define LCD_REST_High() GPIO_SetBit(GPIOA, PIN2)
#define LCD_REST_Low()  GPIO_ClrBit(GPIOA, PIN2)
#define LCD_DC_High()   GPIO_SetBit(GPIOB, PIN5)
#define LCD_DC_Low()    GPIO_ClrBit(GPIOB, PIN5)
#define LCD_SDI_High()  GPIO_SetBit(GPIOB, PIN12)
#define LCD_SDI_Low()   GPIO_ClrBit(GPIOB, PIN12)
#define LCD_SCK_High()  GPIO_SetBit(GPIOB, PIN11)
#define LCD_SCK_Low()   GPIO_ClrBit(GPIOB, PIN11)
#define LCD_LED_High()  GPIO_SetBit(GPIOB, PIN13)
#define LCD_LED_Low()   GPIO_ClrBit(GPIOB, PIN13)
模拟SPI方式发送字节数据的函数为:
void LCD_Writ_Bus(unsigned char com)
     unsigned char uci;
      for(uci=0;uci<8;uci++)
         if(com & 0x80)
             LCD_SDI_High();
         else
             LCD_SDI_Low();
          com = com << 1;
          delay_1us(1);
          LCD_SCK_Low();
           LCD_SCK_High();
对所用显示屏的初始化函数为:
void tft_Init(void)
{   // ili9220B
    LCD_REST_Low();
    Delay_ms(20);
    LCD_REST_High();
    Delay_ms(20);
    LCD_CS_Low();
    LCD_WR_REG(0xCB);
    LCD_WR_DATA8(0x39);
    LCD_WR_DATA8(0x2C);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x34);
    LCD_WR_DATA8(0x02);
    LCD_WR_REG(0xCF);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0XC1);
    LCD_WR_DATA8(0X30);
    LCD_WR_REG(0xE8);
    LCD_WR_DATA8(0x85);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x78);
    LCD_WR_REG(0xEA);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0xED);
    LCD_WR_DATA8(0x64);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0X12);
    LCD_WR_DATA8(0X81);
    LCD_WR_REG(0xF7);
    LCD_WR_DATA8(0x20);
    LCD_WR_REG(0xC0);
    LCD_WR_DATA8(0x23);
    LCD_WR_REG(0xC1);
    LCD_WR_DATA8(0x10);
    LCD_WR_REG(0xC5);
    LCD_WR_DATA8(0x3e);
    LCD_WR_DATA8(0x28);
    LCD_WR_REG(0xC7);
    LCD_WR_DATA8(0x86);
    LCD_WR_REG(0x36);
    LCD_WR_DATA8(0x48);
    LCD_WR_REG(0x3A);
    LCD_WR_DATA8(0x55);
    LCD_WR_REG(0xB1);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x18);
    LCD_WR_REG(0xB6);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x82);
    LCD_WR_DATA8(0x27);
    LCD_WR_REG(0xF2);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0x26);
    LCD_WR_DATA8(0x01);
    LCD_WR_REG(0xE0);
    LCD_WR_DATA8(0x0F);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0x2B);
    LCD_WR_DATA8(0x0C);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x4E);
    LCD_WR_DATA8(0xF1);
    LCD_WR_DATA8(0x37);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x10);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x09);
    LCD_WR_DATA8(0x00);
    LCD_WR_REG(0XE1);
    LCD_WR_DATA8(0x00);
    LCD_WR_DATA8(0x0E);
    LCD_WR_DATA8(0x14);
    LCD_WR_DATA8(0x03);
    LCD_WR_DATA8(0x11);
    LCD_WR_DATA8(0x07);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0xC1);
    LCD_WR_DATA8(0x48);
    LCD_WR_DATA8(0x08);
    LCD_WR_DATA8(0x0F);
    LCD_WR_DATA8(0x0C);
    LCD_WR_DATA8(0x31);
    LCD_WR_DATA8(0x36);
    LCD_WR_DATA8(0x0F);
    LCD_WR_REG(0x11);
    Delay_ms(120);
    LCD_WR_REG(0x29);
    LCD_WR_REG(0x2c);
    LCD_LED_High();
实现指定色彩存储屏幕的函数为:
void LCD_Clear(unsigned int Color)
   char VH,VL;
   unsigned int i,j;
   VH=Color>>8;
   VL=Color;
   Address_set(0,0,LCD_W-1,LCD_H-1);
   for(i=0;i<LCD_W;i++)
        for (j=0;j<LCD_H;j++)
            LCD_WR_DATA8(VH);
            LCD_WR_DATA8(VL);
进行驱动测试的主程序为:
int main(void)
  SystemInit();
  GPIO_Init(GPIOA, PIN2, 0, 1, 0, 0);
  GPIO_Init(GPIOA, PIN5, 1, 0, 0, 0);
  SPI_CONFIG();
  tft_Init();
  LCD_Clear(RED);
  BACK_COLOR=RED;
  POINT_COLOR=WHITE;
  LCD_ShowString(20,60,"SWM221CBT7");
  while(1)
      if(GPIO_GetBit(GPIOA, PIN2) == 1)
            GPIO_SetBit(GPIOA, PIN5);
      else
            GPIO_ClrBit(GPIOA, PIN5);
经程序的编译和下载,其测试效果如图2所示,说明驱动效应,可以在此基础上进一步添加中文显示、图形绘制及图形显示函数等。
2 测试效果
后续会在模拟方式的基础上,来解决硬件驱动的问题,使该开发板的性能进一步展示出来。
关键词: SWM221CBT7
2025-11-14 08:29:18     打赏
谢谢楼主分享
2025-11-14 14:44:40     打赏
2025-11-14 19:41:16     打赏
感谢支持!!!
2025-11-18 07:41:48     打赏
SPI的话,还是用硬件SPI外设更好一些,代码也少
2025-11-18 10:14:15     打赏
我觉得这个实验的意义并不大。
这是复习了SPI协议,还是验证了LCD屏?
2025-11-18 12:04:44     打赏
这主要是向SPI驱动LCD屏作准备
2025-11-18 17:25:30     打赏
gpio 模拟的SPI性能上应该会差些吧
2025-11-18 21:11:39     打赏
gpio 模拟的SPI在速度上会慢一些
2025-11-19 08:05:55     打赏
使用模拟的SPI驱动屏幕把?
共11条 1/2 1 2 跳转至
