【简介】
在S32K3系列芯片的RTD的驱动中会有检测超时的逻辑,这个检测的timer可以指定用户自己实现的timer。在S32DS的驱动配置中也可以选择自定义的超时处理。以下是S32DS 的UART驱动配置,可以让用户自己来选择超时检出的timer 处理方法。
以下是os_if 接口中对timer 的接口函数。
/*FUNCTION**********************************************************************
* Function Name : OsIf_Init.
* Description : OsIf initialization.
* @implements OsIf_Init_Activity
*END**************************************************************************/
void OsIf_Init(const void* Config)
#if (STD_ON == OSIF_DEV_ERROR_DETECT)
if (Config != NULL_PTR)
#if defined(USING_OS_AUTOSAROS)
(void)Det_ReportError(OSIF_MODULE_ID, OSIF_DRIVER_INSTANCE, OSIF_SID_INIT, OSIF_E_INIT_FAILED);
#else
OSIF_DEV_ASSERT(FALSE);
#endif /* defined(USING_OS_AUTOSAROS) */
#else
(void)Config;
#endif /* (STD_ON == OSIF_DEV_ERROR_DETECT) */
#if (OSIF_USE_SYSTEM_TIMER == STD_ON)
OsIf_Timer_System_Init();
#endif /* (OSIF_USE_SYSTEM_TIMER == STD_ON) */
#if (OSIF_USE_CUSTOM_TIMER == STD_ON)
OsIf_Timer_Custom_Init();
#endif /* (OSIF_USE_CUSTOM_TIMER == STD_ON) */
* Function Name : OsIf_GetCounter.
* Description : Get counter value.
* @implements OsIf_GetCounter_Activity
uint32 OsIf_GetCounter(OsIf_CounterType SelectedCounter)
uint32 u32Value = 0U;
switch (SelectedCounter)
case OSIF_COUNTER_DUMMY:
u32Value = OsIf_Timer_Dummy_GetCounter();
break;
case OSIF_COUNTER_SYSTEM:
u32Value = OsIf_Timer_System_GetCounter();
break;
case OSIF_COUNTER_CUSTOM:
u32Value = OsIf_Timer_Custom_GetCounter();
break;
default:
/* impossible */
break;
return u32Value;
* Function Name : OsIf_GetElapsed.
* Description : Get elapsed value.
* @implements OsIf_GetElapsed_Activity
uint32 OsIf_GetElapsed(uint32 * const CurrentRef,
u32Value = OsIf_Timer_Dummy_GetElapsed(CurrentRef);
break;
u32Value = OsIf_Timer_System_GetElapsed(CurrentRef);
break;
u32Value = OsIf_Timer_Custom_GetElapsed(CurrentRef);
break;
default:
/* impossible */
break;
return u32Value;
* Function Name : OsIf_SetTimerFrequency.
* Description : Set timer frequency.
* @implements OsIf_SetTimerFrequency_Activity
/* @implements OsIf_SetTimerFrequency_Activity */
void OsIf_SetTimerFrequency(uint32 Freq,
OsIf_Timer_Dummy_SetTimerFrequency(Freq);
break;
OsIf_Timer_System_SetTimerFrequency(Freq);
break;
OsIf_Timer_Custom_SetTimerFrequency(Freq);
break;
default:
/* impossible */
break;
* Function Name : OsIf_MicrosToTicks.
* Description : Convert micro second to ticks.
* @implements OsIf_MicrosToTicks_Activity
uint32 OsIf_MicrosToTicks(uint32 Micros,
u32Value = OsIf_Timer_Dummy_MicrosToTicks(Micros);
break;
u32Value = OsIf_Timer_System_MicrosToTicks(Micros);
break;
u32Value = OsIf_Timer_Custom_MicrosToTicks(Micros);
break;
default:
/* impossible */
break;
return u32Value;
}以上 os_if 的接口每个接口内都有 OSIF_USE_CUSTOM_TIMER 的分支并且定义好了函数的名称,我们只需要按照口实现对应的接口即可完成cuetom timer 的添加,接口定义说明如下:
/*! * @brief Initialize the custom timer. * * This function initialize the custom timer. */ void OsIf_Timer_Custom_Init(void); /*! * @brief Get counter value from custom timer. * * This function get counter value from custom timer. * * @return Counter value */ uint32 OsIf_Timer_Custom_GetCounter(void); /*! * @brief Get elapsed value from custom timer. * * This function get elapsed value from custom timer. * * @param[in] CurrentRef The pointer to current reference point * @return Elapsed value */ uint32 OsIf_Timer_Custom_GetElapsed(uint32 * const CurrentRef); /*! * @brief Set custom timer frequency. * * This function set custom timer frequency. * * @param[in] Freq Frequency value */ void OsIf_Timer_Custom_SetTimerFrequency(uint32 Freq); /*! * @brief Convert micro second to ticks based on custom timer frequency. * * This function Convert micro second to ticks based on custom timer frequency. * * @param[in] Micros Micro second * @return Ticks */ uint32 OsIf_Timer_Custom_MicrosToTicks(uint32 Micros);
【OsIf_Timer_Custom_Init】
Stm_Ip_Init(0, &STM_0_InitConfig_PB);
Stm_Ip_InitChannel(0,STM_0_ChannelConfig_PB);
Stm_Ip_StartCounting(0,0,1000);
}【OsIf_Timer_Custom_GetCounter】
* Private Variable Definitions *
static uint32 customcounter = 0U;
* Global Function Declarations *
void Custom_Timer_Callback(uint8 channel)
customcounter++;
return customcounter;
}【OsIf_Timer_Custom_GetElapsed】
return (customcounter - *CurrentRef);
}【OsIf_Timer_Custom_SetTimerFrequency】
频率固定不需要动态设定
}【OsIf_Timer_Custom_MicrosToTicks】
* @return Ticks
return Micros;
}在S32DS中开启该配置就可以打开custom timer 的配置项目。
适配好这些 我们就可以在驱动配置超时处理选择CUSTOM timer作为超时检测接口,本地的uart 配置修改为CUSTOM 。
修改后UART 的驱动的超时检测就被更新成我们新修改的时钟配置了。
RTD 添加使用其他的timer 方法也是类似,都是完成timer 的接口配置即可。
