电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » STM32C0116DK开发探索记(2)
共7条 1/1 1 跳转至页
STM32C0116DK开发探索记(2) 24
2026-06-11 12:34:47     打赏
4.A/D数据采集
在开发板上,没有配置常规的按键,取而代之的则是一个方向键,并以模拟信号的方式来进行识别,其电路见图16所示。
由图可知,该方向键所使用的硬件为PA8,是A/D检测的8#通道。此外,它还给出了各键作用下的电压检测值,以供对比分析,见红色框内的内容。
图16 方向键电路
它之所以这样设计,可有效地解决引脚资源占用过多的问题,也为A/D检测提供了硬件方面的方便。
有了硬件的支持,那软件呢?
对不起,在例程方面没有提供相应的支持。
现在,OLED屏的作用又可以派上用场了,借助它可以观察程序设计的正确性。
经反复的探索和尝试,终于有了可信的结果。
其中,A/D的初始化函数为:
static void MX_ADC1_Init(void)
  LL_ADC_InitTypeDef ADC_InitStruct = {0};
  LL_ADC_REG_InitTypeDef ADC_REG_InitStruct = {0};
  LL_GPIO_InitTypeDef GPIO_InitStruct = {0};
  LL_RCC_SetADCClockSource(LL_RCC_ADC_CLKSOURCE_SYSCLK);
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_ADC);
  LL_IOP_GRP1_EnableClock(LL_IOP_GRP1_PERIPH_GPIOA);
  GPIO_InitStruct.Pin = LL_GPIO_PIN_8;
  GPIO_InitStruct.Mode = LL_GPIO_MODE_ANALOG;
  GPIO_InitStruct.Pull = LL_GPIO_PULL_NO;
  LL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  #define ADC_CHANNEL_CONF_RDY_TIMEOUT_MS ( 1U)
  #if (USE_TIMEOUT == 1)
  uint32_t Timeout ;
  #endif
  ADC_InitStruct.Clock = LL_ADC_CLOCK_SYNC_PCLK_DIV4;
  ADC_InitStruct.Resolution = LL_ADC_RESOLUTION_12B;
  ADC_InitStruct.DataAlignment = LL_ADC_DATA_ALIGN_RIGHT;
  ADC_InitStruct.LowPowerMode = LL_ADC_LP_MODE_NONE;
  LL_ADC_Init(ADC1, &ADC_InitStruct);
  LL_ADC_REG_SetSequencerConfigurable(ADC1, LL_ADC_REG_SEQ_FIXED);
  ADC_REG_InitStruct.TriggerSource = LL_ADC_REG_TRIG_SOFTWARE;
  ADC_REG_InitStruct.SequencerLength = LL_ADC_REG_SEQ_SCAN_DISABLE;
  ADC_REG_InitStruct.SequencerDiscont = LL_ADC_REG_SEQ_DISCONT_DISABLE;
  ADC_REG_InitStruct.ContinuousMode = LL_ADC_REG_CONV_SINGLE;
  ADC_REG_InitStruct.DMATransfer = LL_ADC_REG_DMA_TRANSFER_NONE;
  ADC_REG_InitStruct.Overrun = LL_ADC_REG_OVR_DATA_OVERWRITTEN;
  LL_ADC_REG_Init(ADC1, &ADC_REG_InitStruct);
  LL_ADC_REG_SetSequencerScanDirection(ADC1, LL_ADC_REG_SEQ_SCAN_DIR_FORWARD);
  LL_ADC_SetOverSamplingScope(ADC1, LL_ADC_OVS_DISABLE);
  LL_ADC_SetTriggerFrequencyMode(ADC1, LL_ADC_CLOCK_FREQ_MODE_HIGH);
  LL_ADC_REG_SetSequencerChAdd(ADC1, LL_ADC_CHANNEL_8);  //LL_ADC_CHANNEL_4
  Timeout = ADC_CHANNEL_CONF_RDY_TIMEOUT_MS;
  #endif /* USE_TIMEOUT */
  while (LL_ADC_IsActiveFlag_CCRDY(ADC1) == 0)
     if (LL_SYSTICK_IsActiveCounterFlag())
          if(Timeout-- == 0)
             Error_Handler();
     #endif
  LL_ADC_ClearFlag_CCRDY(ADC1);
  LL_ADC_SetSamplingTimeCommonChannels(ADC1, LL_ADC_SAMPLINGTIME_COMMON_1, LL_ADC_SAMPLINGTIME_79CYCLES_5);
  LL_ADC_DisableIT_EOC(ADC1);
  LL_ADC_DisableIT_EOS(ADC1);
  LL_ADC_EnableInternalRegulator(ADC1);
  uint32_t wait_loop_index;
  wait_loop_index = ((LL_ADC_DELAY_INTERNAL_REGUL_STAB_US * (SystemCoreClock / (100000 * 2))) / 10);
  while(wait_loop_index != 0)
       wait_loop_index--;
  LL_ADC_EnableIT_EOC(ADC1);
  LL_ADC_EnableIT_OVR(ADC1);
激活A/D采集的函数为:
void ADC_Activate(void)
  __IO uint32_t wait_loop_index = 0U;
  __IO uint32_t backup_setting_adc_dma_transfer = 0U;
  uint32_t Timeout = 0U;
  #endif
  if (LL_ADC_IsEnabled(ADC1) == 0)
      wait_loop_index--;
    backup_setting_adc_dma_transfer = LL_ADC_REG_GetDMATransfer(ADC1);
    LL_ADC_REG_SetDMATransfer(ADC1, LL_ADC_REG_DMA_TRANSFER_NONE);
    LL_ADC_StartCalibration(ADC1);
    Timeout = ADC_CALIBRATION_TIMEOUT_MS;
    #endif
    while (LL_ADC_IsCalibrationOnGoing(ADC1) != 0)
        if(Timeout-- == 0)
          Error_Handler();
    #endif
    LL_ADC_REG_SetDMATransfer(ADC1, backup_setting_adc_dma_transfer);
    wait_loop_index = (ADC_DELAY_CALIB_ENABLE_CPU_CYCLES >> 1);
      wait_loop_index--;
    LL_ADC_Enable(ADC1);
    Timeout = ADC_ENABLE_TIMEOUT_MS;
    #endif
    while (LL_ADC_IsActiveFlag_ADRDY(ADC1) == 0)
        if(Timeout-- == 0)
          Error_Handler();
    #endif
实现A/D采集和显示的主程序为:
int main(void)
  LL_APB2_GRP1_EnableClock(LL_APB2_GRP1_PERIPH_SYSCFG);
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_PWR);
  NVIC_SetPriority(SysTick_IRQn, 3);
  SystemClock_Config();
  MX_GPIO_Init();
  OLED_config();
  OLED_Init();
  OLED_Clear();
  OLED_ShowString(0,0," STM32C0116_DK",16);
  OLED_ShowString(0,2," U =        mv",16);
  OLED_ShowString(0,4," A/D= ",16);
  MX_ADC1_Init();
  ADC_Activate();
  while (1)
    ConversionStartPoll_ADC_GrpRegular();
    uhADCxConvertedData = LL_ADC_REG_ReadConversionData32(ADC1);
    uhADCxConvertedData_Voltage_mVolt = __LL_ADC_CALC_DATA_TO_VOLTAGE(VDDA_APPLI, uhADCxConvertedData, LL_ADC_RESOLUTION_12B);
OLED_ShowNum(48,4, uhADCxConvertedData,4,16);
    OLED_ShowNum(48,2, uhADCxConvertedData_Voltage_mVolt,4,16);
    LED_On();
    LL_mDelay(LED_BLINK_SLOW);
    LED_Off();
经程序的编译和下载,其测试结果见图17至图22所示,经与图16的电压输出值的比对,说明其结果正确。
图17 悬空状态
图18 按选取键
图19 按向左键
图20 按向下键
图21 按向上键
图22 按向右键
下面将重点解决串口通信的问题,以实现最终的目标。
2026-06-13 18:22:28   被打赏 5 分(兑奖)     打赏
简化版的拨杆,不过确实在有些地方这种就够用了,比如数独机
2026-06-15 13:39:44   被打赏 5 分(兑奖)     打赏
这种处理,的确是有效利用GPIO少的一种手段。只是同时触发按键时,会是什么情形呢?
2026-06-15 17:07:33   被打赏 5 分(兑奖)     打赏
AD 的按键在车载的方向盘的控制按键识别上用的也是比较多。
2026-06-16 21:34:29     打赏
增加个防抖是不是好点?
2026-06-17 04:40:50   被打赏 5 分(兑奖)     打赏
这个ADC按键我在Eetree的活动中见过一次是四个按键,但是由于它那个板子的底板还是什么设计的不是很规范有时候电压无论哪个按键测量出来的都是4096,不是很友好
2026-06-17 14:04:14   被打赏 5 分(兑奖)     打赏
这种检测按键的方式,检测AD值的时候,会不会有误差的情况呢?
共7条 1/1 1 跳转至页
