基于peripheral_hr例程开发,
修改main.c
/* main.c - Application main entry point */
* Copyright (c) 2024 Nordic Semiconductor ASA
* Copyright (c) 2015-2016 Intel Corporation
* SPDX-License-Identifier: Apache-2.0
#include <zephyr/device.h>
#include <zephyr/devicetree.h>
#include <zephyr/bluetooth/bluetooth.h>
#include <zephyr/bluetooth/hci.h>
#include <zephyr/bluetooth/conn.h>
#include <zephyr/bluetooth/uuid.h>
#include <zephyr/bluetooth/gatt.h>
#include <zephyr/bluetooth/services/bas.h>
#include <zephyr/bluetooth/services/hrs.h>
#include <zephyr/drivers/sensor.h>
#include "hts.h"
static bool hrf_ntf_enabled;
// DHT20传感器设备指针
static const struct device *dht20_dev;
static const struct bt_data ad[] = {
BT_DATA_BYTES(BT_DATA_FLAGS, (BT_LE_AD_GENERAL | BT_LE_AD_NO_BREDR)),
BT_DATA_BYTES(BT_DATA_UUID16_ALL,
BT_UUID_16_ENCODE(BT_UUID_HRS_VAL),
BT_UUID_16_ENCODE(BT_UUID_BAS_VAL),
BT_UUID_16_ENCODE(BT_UUID_DIS_VAL),
BT_UUID_16_ENCODE(BT_UUID_HTS_VAL)),
#if defined(CONFIG_BT_EXT_ADV)
BT_DATA(BT_DATA_NAME_COMPLETE, CONFIG_BT_DEVICE_NAME, sizeof(CONFIG_BT_DEVICE_NAME) - 1),
#endif /* CONFIG_BT_EXT_ADV */
#if !defined(CONFIG_BT_EXT_ADV)
static const struct bt_data sd[] = {
#endif /* !CONFIG_BT_EXT_ADV */
enum {
STATE_CONNECTED,
STATE_DISCONNECTED,
STATE_BITS,
static ATOMIC_DEFINE(state, STATE_BITS);
static void connected(struct bt_conn *conn, uint8_t err)
if (err) {
printk("Connection failed, err 0x%02x %s\n", err, bt_hci_err_to_str(err));
} else {
printk("Connected\n");
(void)atomic_set_bit(state, STATE_CONNECTED);
static void disconnected(struct bt_conn *conn, uint8_t reason)
printk("Disconnected, reason 0x%02x %s\n", reason, bt_hci_err_to_str(reason));
(void)atomic_set_bit(state, STATE_DISCONNECTED);
BT_CONN_CB_DEFINE(conn_callbacks) = {
.connected = connected,
.disconnected = disconnected,
static void hrs_ntf_changed(bool enabled)
hrf_ntf_enabled = enabled;
printk("HRS notification status changed: %s\n",
enabled ? "enabled" : "disabled");
static struct bt_hrs_cb hrs_cb = {
.ntf_changed = hrs_ntf_changed,
static void auth_cancel(struct bt_conn *conn)
char addr[BT_ADDR_LE_STR_LEN];
bt_addr_le_to_str(bt_conn_get_dst(conn), addr, sizeof(addr));
printk("Pairing cancelled: %s\n", addr);
static struct bt_conn_auth_cb auth_cb_display = {
.cancel = auth_cancel,
static void bas_notify(void)
uint8_t battery_level = bt_bas_get_battery_level();
battery_level--;
if (!battery_level) {
battery_level = 100U;
bt_bas_set_battery_level(battery_level);
static void hrs_notify(void)
static uint8_t heartrate = 90U;
/* Heartrate measurements simulation */
heartrate++;
if (heartrate == 160U) {
heartrate = 90U;
if (hrf_ntf_enabled) {
bt_hrs_notify(heartrate);
// 读取DHT20温湿度数据
static void read_dht20_data(float *temperature, float *humidity)
struct sensor_value temp_val, humidity_val;
int rc;
if (!dht20_dev) {
return;
/* 获取温湿度数据 */
rc = sensor_sample_fetch(dht20_dev);
if (rc < 0) {
printk("Failed to fetch DHT20 sample: %d\n", rc);
return;
/* 获取温度值 */
rc = sensor_channel_get(dht20_dev, SENSOR_CHAN_AMBIENT_TEMP, &temp_val);
if (rc < 0) {
printk("Failed to get temperature: %d\n", rc);
return;
/* 获取湿度值 */
rc = sensor_channel_get(dht20_dev, SENSOR_CHAN_HUMIDITY, &humidity_val);
if (rc < 0) {
printk("Failed to get humidity: %d\n", rc);
return;
*temperature = sensor_value_to_double(&temp_val);
*humidity = sensor_value_to_double(&humidity_val);
/* 打印温湿度数据 */
printk("Temperature: %.2f °C, Humidity: %.2f %%\n", *temperature, *humidity);
#if defined(CONFIG_GPIO)
/* The devicetree node identifier for the "led0" alias. */
#define LED0_NODE DT_ALIAS(led0)
#if DT_NODE_HAS_STATUS_OKAY(LED0_NODE)
#include <zephyr/drivers/gpio.h>
#define HAS_LED 1
static const struct gpio_dt_spec led = GPIO_DT_SPEC_GET(LED0_NODE, gpios);
#define BLINK_ONOFF K_MSEC(500)
static struct k_work_delayable blink_work;
static bool led_is_on;
static void blink_timeout(struct k_work *work)
led_is_on = !led_is_on;
gpio_pin_set(led.port, led.pin, (int)led_is_on);
k_work_schedule(&blink_work, BLINK_ONOFF);
static int blink_setup(void)
int err;
printk("Checking LED device...");
if (!gpio_is_ready_dt(&led)) {
printk("failed.\n");
return -EIO;
printk("done.\n");
printk("Configuring GPIO pin...");
err = gpio_pin_configure_dt(&led, GPIO_OUTPUT_ACTIVE);
if (err) {
return -EIO;
printk("done.\n");
k_work_init_delayable(&blink_work, blink_timeout);
return 0;
static void blink_start(void)
printk("Start blinking LED...\n");
led_is_on = false;
static void blink_stop(void)
struct k_work_sync work_sync;
printk("Stop blinking LED.\n");
k_work_cancel_delayable_sync(&blink_work, &work_sync);
/* Keep LED on */
led_is_on = true;
#endif /* LED0_NODE */
#endif /* CONFIG_GPIO */
int main(void)
int err;
err = bt_enable(NULL);
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return 0;
printk("Bluetooth initialized\n");
bt_conn_auth_cb_register(&auth_cb_display);
bt_hrs_cb_register(&hrs_cb);
hts_init();
/* 初始化DHT20传感器 */
dht20_dev = DEVICE_DT_GET(DT_NODELABEL(dht20_sensor));
if (!device_is_ready(dht20_dev)) {
printk("DHT20 sensor device not ready\n");
dht20_dev = NULL;
} else {
printk("DHT20 sensor initialized successfully\n");
printk("Starting Legacy Advertising (connectable and scannable)\n");
err = bt_le_adv_start(BT_LE_ADV_CONN_FAST_1, ad, ARRAY_SIZE(ad), sd, ARRAY_SIZE(sd));
if (err) {
printk("Advertising failed to start (err %d)\n", err);
return 0;
#else /* CONFIG_BT_EXT_ADV */
struct bt_le_adv_param adv_param = {
.id = BT_ID_DEFAULT,
.sid = 0U,
.secondary_max_skip = 0U,
.options = (BT_LE_ADV_OPT_EXT_ADV | BT_LE_ADV_OPT_CONN | BT_LE_ADV_OPT_CODED),
.interval_min = BT_GAP_ADV_FAST_INT_MIN_2,
.interval_max = BT_GAP_ADV_FAST_INT_MAX_2,
.peer = NULL,
struct bt_le_ext_adv *adv;
printk("Creating a Coded PHY connectable non-scannable advertising set\n");
err = bt_le_ext_adv_create(&adv_param, NULL, &adv);
if (err) {
printk("Failed to create Coded PHY extended advertising set (err %d)\n", err);
printk("Creating a non-Coded PHY connectable non-scannable advertising set\n");
adv_param.options &= ~BT_LE_ADV_OPT_CODED;
if (err) {
printk("Failed to create extended advertising set (err %d)\n", err);
return 0;
printk("Setting extended advertising data\n");
err = bt_le_ext_adv_set_data(adv, ad, ARRAY_SIZE(ad), NULL, 0);
if (err) {
printk("Failed to set extended advertising data (err %d)\n", err);
return 0;
printk("Starting Extended Advertising (connectable non-scannable)\n");
err = bt_le_ext_adv_start(adv, BT_LE_EXT_ADV_START_DEFAULT);
if (err) {
printk("Failed to start extended advertising set (err %d)\n", err);
return 0;
printk("Advertising successfully started\n");
#if defined(HAS_LED)
err = blink_setup();
if (err) {
return 0;
blink_start();
#endif /* HAS_LED */
/* Implement notification. */
while (1) {
float temperature = 25.0f;
float humidity = 50.0f;
k_sleep(K_SECONDS(1));
hrs_notify();
/* Battery level simulation */
bas_notify();
/* 读取DHT20温湿度数据 */
read_dht20_data(&temperature, &humidity);
/* 推送温度数据到HTS服务 */
hts_indicate(temperature);
if (atomic_test_and_clear_bit(state, STATE_CONNECTED)) {
/* Connected callback executed */
blink_stop();
} else if (atomic_test_and_clear_bit(state, STATE_DISCONNECTED)) {
ARRAY_SIZE(sd));
if (err) {
return 0;
printk("Starting Extended Advertising (connectable and non-scannable)\n");
if (err) {
return 0;
blink_start();
return 0;
}src目录增加hts.c
/** @file
* @brief HTS Service implementation
#include <stdio.h>
#include <stddef.h>
#include <string.h>
#include <errno.h>
#include <zephyr/kernel.h>
#include <zephyr/sys/printk.h>
#include <zephyr/sys/byteorder.h>
static uint8_t indicate_enabled;
static uint8_t indicating;
static struct bt_gatt_indicate_params ind_params;
static void htmc_ccc_cfg_changed(const struct bt_gatt_attr *attr,
uint16_t value)
indicate_enabled = (value == BT_GATT_CCC_INDICATE) ? 1 : 0;
printk("HTS indication %s\n", indicate_enabled ? "enabled" : "disabled");
static void indicate_cb(struct bt_conn *conn,
struct bt_gatt_indicate_params *params, uint8_t err)
printk("Temperature indication %s\n", err != 0U ? "fail" : "success");
static void indicate_destroy(struct bt_gatt_indicate_params *params)
indicating = 0U;
/* Health Thermometer Service Declaration */
BT_GATT_SERVICE_DEFINE(hts_svc,
BT_GATT_PRIMARY_SERVICE(BT_UUID_HTS),
BT_GATT_CHARACTERISTIC(BT_UUID_HTS_MEASUREMENT, BT_GATT_CHRC_INDICATE,
BT_GATT_PERM_NONE, NULL, NULL, NULL),
BT_GATT_CCC(htmc_ccc_cfg_changed,
BT_GATT_PERM_READ | BT_GATT_PERM_WRITE),
void hts_init(void)
printk("Health Thermometer Service initialized\n");
void hts_indicate(float temperature)
if (!indicate_enabled) {
return;
if (indicating) {
return;
static uint8_t htm[5];
uint32_t mantissa;
uint8_t exponent;
mantissa = (uint32_t)(temperature * 100);
exponent = (uint8_t)-2;
htm[0] = 0; /* temperature in celsius */
sys_put_le24(mantissa, (uint8_t *)&htm[1]);
htm[4] = exponent;
ind_params.attr = &hts_svc.attrs[2];
ind_params.func = indicate_cb;
ind_params.destroy = indicate_destroy;
ind_params.data = &htm;
ind_params.len = sizeof(htm);
if (bt_gatt_indicate(NULL, &ind_params) == 0) {
indicating = 1U;
}src目录增加hts.h
/** @file
* @brief HTS Service for temperature indication
#ifdef __cplusplus
extern "C" {
#endif
void hts_init(void);
void hts_indicate(float temperature);
#ifdef __cplusplus
#endifperipheral_hr目录增加app.over
// SPDX-License-Identifier: Apache-2.0
&lpi2c1 {
status = "okay";
clock-frequency = <100000>;
dht20_sensor: dht20@38 {
compatible = "aosong,dht20";
reg = <0x38>;
label = "DHT20";
};修改prj.conf
CONFIG_BT=y CONFIG_LOG=y CONFIG_BT_SMP=y CONFIG_BT_PERIPHERAL=y CONFIG_BT_DIS=y CONFIG_BT_DIS_PNP=n CONFIG_BT_BAS=y CONFIG_BT_HRS=y # CONFIG_BT_DEVICE_NAME="Zephyr Heartrate Sensor" CONFIG_BT_DEVICE_NAME="Zephyr Sensor" CONFIG_BT_DEVICE_APPEARANCE=833 CONFIG_CBPRINTF_FP_SUPPORT=y # DHT20传感器支持 CONFIG_SENSOR=y CONFIG_DHT20=y CONFIG_DHT20_CRC=y CONFIG_I2C=y
