电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 开箱帖
共3条 1/1 1 跳转至页
开箱帖
2026-09-30 23:01:16     打赏
很荣幸能够有资格参加 Let's do 2026 年第 3 期活动。期待了很久的快递终于到了,先拆箱看一下。
NUCLEO-H533RE
板子上部为stlink,通过Type-c口进行供电,有一个用户按键,一个用户LED。
下部为芯片及其引出脚,can fd收发器等。
加速度传感器
LIS3DH支持i2c,spi,ADC三种通信方式,内置温度传感器。
步进电机及驱动板
28BYJ-48 减速步进电机和 ULN2003 驱动板如图所示。
蜂鸣器模块
蜂鸣器模块如图所示
环境配置
下载CUBEMX2
选择好型号新建工程先点个灯。
选择PA5,配置为输出模式。
生成CMake项目
对VScode进行配置,下载stm插件,过VSCodde打开工程。
先写个闪烁小灯代码
      HAL_Delay(100);      HAL_GPIO_TogglePin(HAL_GPIOA, HAL_GPIO_PIN_5);
对步进电机进行测试。
将PC2,PC3,PC10,PC12设置为GPIO输出模式。
运行驱动代码。
驱动程序
void MOTO_RUN(uint16_t wait){    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_SET);//A+    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_RESET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_SET);//A+B+    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_SET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_RESET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_RESET);//B+    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_SET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_RESET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_RESET);//A-B+    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_SET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_SET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_RESET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_RESET);//A-    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_SET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_RESET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_RESET);//A-B-    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_SET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_SET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_RESET);//B-    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_SET);    HAL_Delay(wait);
    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_2, HAL_GPIO_PIN_SET);//A+B-    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_3, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_10, HAL_GPIO_PIN_RESET);    HAL_GPIO_WritePin(HAL_GPIOC, HAL_GPIO_PIN_12, HAL_GPIO_PIN_SET);    HAL_Delay(wait);
运行代码。
MOTO_RUN(0);
对加速度检测模块进行测试
打开I2C1,打开USART2,运行驱动程序。
驱动程序
void LIS3DHTR_Read(uint8_t reg, uint8_t *value, uint8_t len){  uint16_t iic_addre = 0x19;
  HAL_I2C_MASTER_MemRead(mx_i2c1_i2c_gethandle(), iic_addre << 1,                        reg, 1, value, len, 100);}
void LIS3DHTR_Write(uint8_t reg, uint8_t value){  uint16_t iic_addre = 0x19;  HAL_I2C_MASTER_MemWrite(mx_i2c1_i2c_gethandle(), iic_addre << 1,                          reg, 1, &value, 1, 100);}
void LIS3DHTR_Init(void){
  uint8_t LIS3DHTR_CTRL_REG1 = 0x20;  uint8_t LIS3DHTR_CTRL_REG4 = 0x23;  uint8_t LIS3DHTR_TEMP_CFG_REG = 0x1F;
  LIS3DHTR_Write(LIS3DHTR_CTRL_REG1, 0x47);  LIS3DHTR_Write(LIS3DHTR_CTRL_REG4, 0x80);  LIS3DHTR_Write(LIS3DHTR_TEMP_CFG_REG, 0xC0);
void LIS3DHTR_Read_XYZ(int16_t *acc){  uint8_t acc_buf[6] = {0};  LIS3DHTR_Read(0x28 | 0x80, acc_buf, 6);   // 自动递增读 6 字节
  acc[0] = (int16_t)(acc_buf[1] << 8 | acc_buf[0]);  acc[1] = (int16_t)(acc_buf[3] << 8 | acc_buf[2]);  acc[2] = (int16_t)(acc_buf[5] << 8 | acc_buf[4]);
运行代码
    LIS3DHTR_Init();
    while (1) {      uint8_t id = 0;      uint8_t buf[2] = {0};      uint8_t sub_addr = 0x0C | 0x80;      int16_t acc[3] = {0};
      LIS3DHTR_Read(0x0F, &id, 1);      LIS3DHTR_Read(sub_addr, buf, 2);      LIS3DHTR_Read_XYZ(acc);
      int16_t raw = (int16_t)(buf[0] | (buf[1] << 8));      int16_t temperature = (raw / 256) + 25;
      printf("id: %xrn", id);      printf("temperature: %drn", temperature);      printf("acc_x: %f.3 ,", acc[0]/ 16);      printf("acc_y: %f.3 ,", acc[1]/ 16);      printf("acc_z: %f.3rn", acc[2]/ 16);          }
经过测试,板子都正常,后续决定先研究一下项目,学习一下边缘AI相关的知识。再对项目做一个整体规划,就可以开始了。
关键词: 开箱
2026-10-03 21:22:12     打赏
再接再厉,期待楼主的继续大作。
话说,楼主想做什么样子的边缘AI呀?
2026-10-03 21:47:40     打赏
这开箱基本上把驱动接口做完了,感觉剩下的基本上就是采集数据,训练模型和部署了
共3条 1/1 1 跳转至页
