我用Fluted.exe烧录bin文件屏幕提示:
C:\Documents and Settings\Administrator\桌面\Programmer>c:\jtag\Allowio "FluteD a -f bios.bin -v -s 0" /a AllowIO for PortTalk V2.0 Copyright 2002 Craig Peacock http://www.beyondlogic.org Granting exclusive access to all I/O Ports Executing FluteD a -f bios.bin -v -s 0 with a Flash Programming Tool via IEEE114 9.1 BSR (Version 0.8a) Designed By David Geng April, 2000
FCD File:./default.fcd Data File:bios.bin
[Setup FCD File]
[Setup Scan Chain] Parse BSDL file s3c44b0x.bsd ... Get BSDL ERROR ! - s3c44b0x.bsdFailed *** STOP *** ProcessID of 908 PortTalk Device Driver has set IOPM for ProcessID 908.
什么原因,我用的是s3c44b0x+29lv160,s3c44b0x.bsd 是我从三星上下到的
