电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » pc104的配置
共3条 1/1 1 跳转至页
pc104的配置
2005-05-11 21:51:27     打赏
现有目标板sed586SV,芯片486dx
想在其上运行VXWORKS,开发环境tornado2.0 for x86
软盘启动软盘加载,制作bootrom过程,采用pc486的BSP
#undef INCLUDE_NETWORK
#define DEFAULT_BOOT_LINE "fd=0,0(0,0)zhgw:/fd0/vxWorks h=210.72.135.76 e=210.72.135.77 u=SED586"
#define DEFAULT_BOOT_LINE \ "fd=0,0(0,0)zhgw:/fd0/vxWorks h=210.72.135.76 e=210.72.135.77 u=SED586"
#define INCLUDE_SERIAL #undef WDB_TTY_DEV_NAME #define WDB_TTY_DEV_NAME "/tyCo/0" #undef CONSOLE_TTY #define CONSOLE_TTY NONE #undef WDB_TTY_CHANNEL #define WDB_TTY_CHANNEL 0 #undef WDB_COMM_TYPE #define WDB_COMM_TYPE WDB_COMM_SERIAL #undef WDB_TTY_BAUD #define WDB_TTY_BAUD 9600
#define INCLUDE_DOSFS /* include dosFs file system */ #define INCLUDE_FD /* include floppy disk driver */ #define INCLUDE_LPT /* include parallel port driver */ #define INCLUDE_ATA /* include IDE/EIDE(ATA) hard disk driver */ #define INCLUDE_TIMESTAMP /* include TIMESTAMP timer for Wind View */ #undef INCLUDE_TFFS /* include TrueFFS driver for Flash */ #undef INCLUDE_PCMCIA /* include PCMCIA driver */ #define INCLUDE_DISKONCHIP /* M-SYSTEMS DiskOnChip */ #undef INCLUDE_NETWORK
#define INCLUDE_PC_CONSOLE
上电加载时,vxld 2.0...................................................... 停止不动。打开串口,收不到任何信息
这是说明vxworks引导没成功吧?
问高手,针对于不同的cpu,需要修改什么,怎样才能引导成功?
盼复
[em06][em06][em06][em06] [align=right][color=#000066][此贴子已经被作者于2005-5-16 16:14:08编辑过][/color][/align]
关键词: pc104     配置     INCLUDE     #define
2005-05-12 17:27:00     打赏
没人回,自己顶一下
2005-05-24 01:51:00     打赏
1.你只要修改congfig.h里的
#ifdef cpu=pentium
#endif
2.在tornado下生成bootrom_uncmp
3.在host\x86_win32\bin 运行torvars注册环境变量
4.在pentium 的bsp 下执行 mkboot a: bootrom_uncmp
ok!
[align=right][color=#000066][此贴子已经被作者于2005-5-23 17:57:29编辑过][/color][/align]
共3条 1/1 1 跳转至页
