电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 44b0求助!
共3条 1/1 1 跳转至页
44b0求助!
2005-05-12 01:20:59     打赏
GET option GET memcfg
;Memory Area ;GCS6 64M 16bit(8MB) DRAM/SDRAM(0xc000000-0xc7fffff) ;APP RAM=0xc000000~0xc7effff ;44BMON RAM=0xc7f0000-0xc7fffff ;STACK =0xc7ffa00
;Interrupt Control INTPND EQU 0x01e00004 INTMOD EQU 0x01e00008 INTMSK EQU 0x01e0000c I_ISPR EQU 0x01e00020 I_CMST EQU 0x01e0001c
;Watchdog timer WTCON EQU 0x01d30000
;Clock Controller PLLCON EQU 0x01d80000 CLKCON EQU 0x01d80004 LOCKTIME EQU 0x01d8000c ;Memory Controller REFRESH EQU 0x01c80024
;BDMA destination register BDIDES0 EQU 0x1f80008 BDIDES1 EQU 0x1f80028
;Pre-defined constants USERMODE EQU 0x10 FIQMODE EQU 0x11 IRQMODE EQU 0x12 SVCMODE EQU 0x13 ABORTMODE EQU 0x17 UNDEFMODE EQU 0x1b MODEMASK EQU 0x1f NOINT EQU 0xc0
;check if tasm.exe is used. GBLL THUMBCODE [ {CONFIG} = 16 THUMBCODE SETL {TRUE} CODE32 | THUMBCODE SETL {FALSE} ]
[ THUMBCODE CODE32 ;for start-up code for Thumb mode ]
MACRO $HandlerLabel HANDLER $HandleLabel
$HandlerLabel sub sp,sp,#4 ;decrement sp(to store jump address) stmfd sp!,{r0} ;PUSH the work register to stack(lr does't push because it return to original address) ldr r0,=$HandleLabel;load the address of HandleXXX to r0 ldr r0,[r0] ;load the contents(service routine start address) of HandleXXX str r0,[sp,#4] ;store the contents(ISR) of HandleXXX to stack ldmfd sp!,{r0,pc} ;POP the work register and pc(jump to ISR) MEND
IMPORT |Image$$RO$$Limit| ; End of ROM code (=start of ROM data) IMPORT |Image$$RW$$Base| ; Base of RAM to initialise IMPORT |Image$$ZI$$Base| ; Base and limit of area IMPORT |Image$$ZI$$Limit| ; to zero initialise
IMPORT Main ; The main entry of mon program AREA Init,CODE,READONLY
ENTRY b ResetHandler ;for debug b HandlerUndef ;handlerUndef b HandlerSWI ;SWI interrupt handler b HandlerPabort ;handlerPAbort b HandlerDabort ;handlerDAbort b . ;handlerReserved b HandlerIRQ b HandlerFIQ ;***IMPORTANT NOTE*** ;If the H/W vectored interrutp mode is enabled, The above two instructions should ;be changed like below, to work-around with H/W bug of S3C44B0X interrupt controller. ; b HandlerIRQ -> subs pc,lr,#4 ; b HandlerIRQ -> subs pc,lr,#4
VECTOR_BRANCH ldr pc,=HandlerEINT0 ;mGA H/W interrupt vector table ldr pc,=HandlerEINT1 ; ldr pc,=HandlerEINT2 ; ldr pc,=HandlerEINT3 ; ldr pc,=HandlerEINT4567 ; ldr pc,=HandlerTICK ;mGA b . b . ldr pc,=HandlerZDMA0 ;mGB ldr pc,=HandlerZDMA1 ; ldr pc,=HandlerBDMA0 ; ldr pc,=HandlerBDMA1 ; ldr pc,=HandlerWDT ; ldr pc,=HandlerUERR01 ;mGB b . b . ldr pc,=HandlerTIMER0 ;mGC ldr pc,=HandlerTIMER1 ; ldr pc,=HandlerTIMER2 ; ldr pc,=HandlerTIMER3 ; ldr pc,=HandlerTIMER4 ; ldr pc,=HandlerTIMER5 ;mGC b . b . ldr pc,=HandlerURXD0 ;mGD ldr pc,=HandlerURXD1 ; ldr pc,=HandlerIIC ; ldr pc,=HandlerSIO ; ldr pc,=HandlerUTXD0 ; ldr pc,=HandlerUTXD1 ;mGD b . b . ldr pc,=HandlerRTC ;mGKA b . ; b . ; b . ; b . ; b . ;mGKA b . b . ldr pc,=HandlerADC ;mGKB b . ; b . ; b . ; b . ; b . ;mGKB b . b . ;0xe0=EnterPWDN ldr pc,=EnterPWDN
LTORG ;声明一个文字池 ;按照宏定义展开 HandlerFIQ HANDLER HandleFIQ HandlerIRQ HANDLER HandleIRQ HandlerUndef HANDLER HandleUndef HandlerSWI HANDLER HandleSWI HandlerDabort HANDLER HandleDabort HandlerPabort HANDLER HandlePabort
HandlerADC HANDLER HandleADC HandlerRTC HANDLER HandleRTC HandlerUTXD1 HANDLER HandleUTXD1 HandlerUTXD0 HANDLER HandleUTXD0 HandlerSIO HANDLER HandleSIO HandlerIIC HANDLER HandleIIC HandlerURXD1 HANDLER HandleURXD1 HandlerURXD0 HANDLER HandleURXD0 HandlerTIMER5 HANDLER HandleTIMER5 HandlerTIMER4 HANDLER HandleTIMER4 HandlerTIMER3 HANDLER HandleTIMER3 HandlerTIMER2 HANDLER HandleTIMER2 HandlerTIMER1 HANDLER HandleTIMER1 HandlerTIMER0 HANDLER HandleTIMER0 HandlerUERR01 HANDLER HandleUERR01 HandlerWDT HANDLER HandleWDT HandlerBDMA1 HANDLER HandleBDMA1 HandlerBDMA0 HANDLER HandleBDMA0 HandlerZDMA1 HANDLER HandleZDMA1 HandlerZDMA0 HANDLER HandleZDMA0 HandlerTICK HANDLER HandleTICK HandlerEINT4567 HANDLER HandleEINT4567 HandlerEINT3 HANDLER HandleEINT3 HandlerEINT2 HANDLER HandleEINT2 HandlerEINT1 HANDLER HandleEINT1 HandlerEINT0 HANDLER HandleEINT0
;One of the following two routines can be used for non-vectored interrupt.
IsrIRQ ;using I_ISPR register. sub sp,sp,#4 ;reserved for PC stmfd sp!,{r8-r9}
;IMPORTANT CAUTION ;if I_ISPC isn't used properly, I_ISPR can be 0 in this routine.
ldr r9,=I_ISPR ldr r9,[r9]
cmp r9, #0x0 ;If the IDLE mode work-around is used, ;r9 may be 0 sometimes. beq %F2
mov r8,#0x0 0 movs r9,r9,lsr #1 bcs %F1 add r8,r8,#4 b %B0
1 ldr r9,=HandleADC add r9,r9,r8 ldr r9,[r9] str r9,[sp,#8] ldmfd sp!,{r8-r9,pc}
2 ldmfd sp!,{r8-r9} add sp,sp,#4 subs pc,lr,#4
;**************************************************** ;* START * ;**************************************************** ResetHandler ldr r0,=WTCON ;watch dog disable ldr r1,=0x0 str r1,[r0]
ldr r0,=INTMSK ldr r1,=0x07ffffff ;all interrupt disable str r1,[r0]
;**************************************************** ;* Set clock control registers * ;**************************************************** ldr r0,=LOCKTIME ldr r1,=0xfff str r1,[r0]
[ PLLONSTART ldr r0,=PLLCON ;temporary setting of PLL ldr r1,=((M_DIV<<12)+(P_DIV<<4)+S_DIV) ;Fin=10MHz,Fout=40MHz str r1,[r0] ]
ldr r0,=CLKCON ldr r1,=0x7ff8 ;All unit block CLK enable str r1,[r0]
;**************************************** ;* change BDMACON reset value for BDMA * ;**************************************** ldr r0,=BDIDES0 ldr r1,=0x40000000 ;BDIDESn reset value should be 0x40000000 str r1,[r0]
ldr r0,=BDIDES1 ldr r1,=0x40000000 ;BDIDESn reset value should be 0x40000000 str r1,[r0]
;**************************************************** ;* Set memory control registers * ;**************************************************** ldr r0,=SMRDATA ldmia r0,{r1-r13} ldr r0,=0x01c80000 ;BWSCON Address stmia r0,{r1-r13}
;**************************************************** ;* Initialize stacks * ;**************************************************** ldr sp, =SVCStack ;Why? bl InitStacks
;**************************************************** ;* Setup IRQ handler * ;**************************************************** ldr r0,=HandleIRQ ;This routine is needed ldr r1,=IsrIRQ ;if there isn't 'subs pc,lr,#4' at 0x18, 0x1c str r1,[r0]
;******************************************************** ;* Copy and paste RW data/zero initialized data * ;******************************************************** LDR r0, =|Image$$RO$$Limit| ; Get pointer to ROM data LDR r1, =|Image$$RW$$Base| ; and RAM copy LDR r3, =|Image$$ZI$$Base| ;Zero init base => top of initialised data CMP r0, r1 ; Check that they are different BEQ %F1 0 CMP r1, r3 ; Copy init data LDRCC r2, [r0], #4 ;--> LDRCC r2, [r0] + ADD r0, r0, #4 STRCC r2, [r1], #4 ;--> STRCC r2, [r1] + ADD r1, r1, #4 BCC %B0 1 LDR r1, =|Image$$ZI$$Limit| ; Top of zero init segment MOV r2, #0 2 CMP r3, r1 ; Zero init STRCC r2, [r3], #4 BCC %B2
[ :LNOT:THUMBCODE BL Main ;Don't use main() because ...... B . ]
[ THUMBCODE ;for start-up code for Thumb mode orr lr,pc,#1 bx lr CODE16 bl Main ;Don't use main() because ...... b . CODE32 ]
;**************************************************** ;* The function for initializing stack * ;**************************************************** InitStacks ;Don't use DRAM,such as stmfd,ldmfd...... ;SVCstack is initialized before ;Under toolkit ver 2.50, 'msr cpsr,r1' can be used instead of 'msr cpsr_cxsf,r1'
mrs r0,cpsr bic r0,r0,#MODEMASK orr r1,r0,#UNDEFMODE|NOINT msr cpsr_cxsf,r1 ;UndefMode ldr sp,=UndefStack orr r1,r0,#ABORTMODE|NOINT msr cpsr_cxsf,r1 ;AbortMode ldr sp,=AbortStack
orr r1,r0,#IRQMODE|NOINT msr cpsr_cxsf,r1 ;IRQMode ldr sp,=IRQStack orr r1,r0,#FIQMODE|NOINT msr cpsr_cxsf,r1 ;FIQMode ldr sp,=FIQStack
bic r0,r0,#MODEMASK|NOINT orr r1,r0,#SVCMODE msr cpsr_cxsf,r1 ;SVCMode ldr sp,=SVCStack
;USER mode is not initialized. mov pc,lr ;The LR register may be not valid for the mode changes.
;**************************************************** ;* The function for entering power down mode * ;**************************************************** ;void EnterPWDN(int CLKCON); EnterPWDN mov r2,r0 ;r0=CLKCON ldr r0,=REFRESH ldr r3,[r0] mov r1, r3 orr r1, r1, #0x400000 ;self-refresh enable str r1, [r0]
nop ;Wait until self-refresh is issued. May not be needed. nop ;If the other bus master holds the bus, ... nop ; mov r0, r0 nop nop nop nop
;enter POWERDN mode ldr r0,=CLKCON str r2,[r0]
;wait until enter SL_IDLE,STOP mode and until wake-up ldr r0,=0x10 0 subs r0,r0,#1 bne %B0
;exit from DRAM/SDRAM self refresh mode. ldr r0,=REFRESH str r3,[r0] mov pc,lr
LTORG
SMRDATA DATA ;***************************************************************** ;* Memory configuration has to be optimized for best performance * ;* The following parameter is not optimized. * ;*****************************************************************
;*** memory access cycle parameter strategy *** ; 1) Even FP-DRAM, EDO setting has more late fetch point by half-clock ; 2) The memory settings,here, are made the safe parameters even at 66Mhz. ; 3) FP-DRAM Parameters:tRCD=3 for tRAC, tcas=2 for pad delay, tcp=2 for bus load. ; 4) DRAM refresh rate is for 40Mhz.
;bank0 16bit BOOT ROM ;bank1 8bit NandFlash ;bank2 16bit IDE ;bank3 8bit UDB ;bank4 rtl8019 ;bank5 ext ;bank6 16bit SDRAM ;bank7 16bit SDRAM [ BUSWIDTH=16 DCD 0x11110101 ;Bank0=16bit BootRom(AT29C010A*2) :0x0 | ;BUSWIDTH=32 DCD 0x22222220 ;Bank0=OM[1:0], Bank1~Bank7=32bit ] DCD ((B0_Tacs<<13)+(B0_Tcos<<11)+(B0_Tacc<<8)+(B0_Tcoh<<6)+(B0_Tah<<4)+(B0_Tacp<<2)+(B0_PMC)) ;GCS0 DCD ((B1_Tacs<<13)+(B1_Tcos<<11)+(B1_Tacc<<8)+(B1_Tcoh<<6)+(B1_Tah<<4)+(B1_Tacp<<2)+(B1_PMC)) ;GCS1 DCD ((B2_Tacs<<13)+(B2_Tcos<<11)+(B2_Tacc<<8)+(B2_Tcoh<<6)+(B2_Tah<<4)+(B2_Tacp<<2)+(B2_PMC)) ;GCS2 DCD ((B3_Tacs<<13)+(B3_Tcos<<11)+(B3_Tacc<<8)+(B3_Tcoh<<6)+(B3_Tah<<4)+(B3_Tacp<<2)+(B3_PMC)) ;GCS3 DCD ((B4_Tacs<<13)+(B4_Tcos<<11)+(B4_Tacc<<8)+(B4_Tcoh<<6)+(B4_Tah<<4)+(B4_Tacp<<2)+(B4_PMC)) ;GCS4 DCD ((B5_Tacs<<13)+(B5_Tcos<<11)+(B5_Tacc<<8)+(B5_Tcoh<<6)+(B5_Tah<<4)+(B5_Tacp<<2)+(B5_PMC)) ;GCS5 [ BDRAMTYPE="DRAM" DCD ((B6_MT<<15)+(B6_Trcd<<4)+(B6_Tcas<<3)+(B6_Tcp<<2)+(B6_CAN)) ;GCS6 check the MT value in parameter.a DCD ((B7_MT<<15)+(B7_Trcd<<4)+(B7_Tcas<<3)+(B7_Tcp<<2)+(B7_CAN)) ;GCS7 | ;"SDRAM" DCD ((B6_MT<<15)+(B6_Trcd<<2)+(B6_SCAN)) ;GCS6 DCD ((B7_MT<<15)+(B7_Trcd<<2)+(B7_SCAN)) ;GCS7 ] DCD ((REFEN<<23)+(TREFMD<<22)+(Trp<<20)+(Trc<<18)+(Tchr<<16)+REFCNT) ;REFRESH RFEN=1, TREFMD=0, trp=3clk, trc=5clk, tchr=3clk,count=1019 DCD 0x10 ;SCLK power down mode, BANKSIZE 32M/32M DCD 0x20 ;MRSR6 CL=2clk DCD 0x20 ;MRSR7
ALIGN
AREA RamData, DATA, READWRITE
^ (_ISR_STARTADDRESS-0x500) UserStack # 256 ;c1(c7)ffa00 SVCStack # 256 ;c1(c7)ffb00 UndefStack # 256 ;c1(c7)ffc00 AbortStack # 256 ;c1(c7)ffd00 IRQStack # 256 ;c1(c7)ffe00 FIQStack # 0 ;c1(c7)fff00
^ _ISR_STARTADDRESS HandleReset # 4 HandleUndef # 4 HandleSWI # 4 HandlePabort # 4 HandleDabort # 4 HandleReserved # 4 HandleIRQ # 4 HandleFIQ # 4
;Don't use the label 'IntVectorTable', ;because armasm.exe cann't recognize this label correctly. ;the value is different with an address you think it may be. ;IntVectorTable HandleADC # 4 HandleRTC # 4 HandleUTXD1 # 4 HandleUTXD0 # 4 HandleSIO # 4 HandleIIC # 4 HandleURXD1 # 4 HandleURXD0 # 4 HandleTIMER5 # 4 HandleTIMER4 # 4 HandleTIMER3 # 4 HandleTIMER2 # 4 HandleTIMER1 # 4 HandleTIMER0 # 4 HandleUERR01 # 4 HandleWDT # 4 HandleBDMA1 # 4 HandleBDMA0 # 4 HandleZDMA1 # 4 HandleZDMA0 # 4 HandleTICK # 4 HandleEINT4567 # 4 HandleEINT3 # 4 HandleEINT2 # 4 HandleEINT1 # 4 HandleEINT0 # 4 ;0xc1(c7)fff84
END
高手告诉我这段代码的意义啊!尤其是红色的意义,怎么执行的
不清楚44b0中断的工作原理,我的理解:对于vectored interrupt是如果有中断发生,则由系统跳到一段统一的isr,在这段isr中可以根据软件查询顺序的方式决定优先级,如果查询的改位有中断发生也就是相应的寄存器位被置位,则到改中断源对应的isr中 对于non-vectored interrupt,如果有中断发生,则根据硬件,pc指针直接指向该中断源的isr
但是在这段初始化代码中是怎么体现的?
关键词: 求助     HANDLER
2005-05-12 01:41:00     打赏
如果我要将非向量中断改为向量中断,需要修改这一段代码中的那些东西?
2005-05-26 19:46:00     打赏
红色的是三星公司特有的向量中断表,整个是一个启动代码
共3条 1/1 1 跳转至页
