Has anybody ever developed AMD nor flash boot for EP93xx? The Cirrus Logic EDB board uses Intel flash. Also we want to use RTL8201 to replace the CS89xx on original board, anybody has the driver? Thanks.
My email: rxia@oplinx.com
[align=right][color=#000066][此贴子已经被作者于2005-8-14 16:01:29编辑过][/color][/align]
介绍一款最新ADI公司集成ARM7的微处理器
ADUC7020 - Precision Analog Microcontroller: 45MIPS ARM7 Flash MCU + 5-Ch 12-Bit ADC + Quad 12-Bit DAC。
The ADuC7020 precision analog microcontroller is a fully integrated 12-bit data acquisition system-on-a-chip, featuring an ARM7TDMI MCU core and 12-bit 1MSPS ADC. Like all of ADI's MicroConverter products, it features precision A/D & D/A conversion and a Flash microcontroller on a single chip.
1、5-Channel, 1 MSPS, 12-Bit ADC
2、Four 12-Bit Rail-to-Rail Voltage Output DACs
3、Precision Voltage Reference (10 ppm)
4、45MIPS ARM7TDMI MCU Core
5、62K-Byte In-Circuit Re-Programmable Flash Program/Data Memory
8K-Byte SRAM
6、Serial Interface Ports (UART, SPI, and dual I2C)
7、Comparator, Programmable Logic Array (PLA), Power Supply Monitor (PSM), Power-On Reset (POR), Flexible Core Clocking Options, Flexible Power-Down Modes
8、In-System Serial Programming
9、In-System JTAG Emulation
