Has anybody ever developed AMD nor flash boot for EP93xx? The Cirrus Logic EDB board uses Intel flash. Also we want to use RTL8201 to replace the CS89xx on original board, anybody has the driver? Thanks.
My email: rxia@oplinx.com
[align=right][color=#000066][此贴子已经被作者于2005-8-14 16:01:29编辑过][/color][/align]
介绍一款最新ADI公司集成ARM7的微处理器
ADUC7020 - Precision Analog Microcontroller: 45MIPS ARM7 Flash MCU + 5-Ch 12-Bit ADC + Quad 12-Bit DAC。
The ADuC7020 precision analog microcontroller is a fully integrated 12-bit data acquisition system-on-a-chip, featuring an ARM7TDMI MCU core and 12-bit 1MSPS ADC. Like all of ADI's MicroConverter products, it features precision A/D & D/A conversion and a Flash microcontroller on a single chip.
1、5-Channel, 1 MSPS, 12-Bit ADC
2、Four 12-Bit Rail-to-Rail Voltage Output DACs
3、Precision Voltage Reference (10 ppm)
4、45MIPS ARM7TDMI MCU Core
5、62K-Byte In-Circuit Re-Programmable Flash Program/Data Memory
8K-Byte SRAM
6、Serial Interface Ports (UART, SPI, and dual I2C)
7、Comparator, Programmable Logic Array (PLA), Power Supply Monitor (PSM), Power-On Reset (POR), Flexible Core Clocking Options, Flexible Power-Down Modes
8、In-System Serial Programming
9、In-System JTAG Emulation
打赏帖 | |
嵌入式LinuxC语言程序调试和宏使用技巧被打赏50分 | |
让代码中包含最新的编译时间信息被打赏50分 | |
rtthread硬件加密--2crc加密分析被打赏10分 | |
【分享开发笔记,赚取电动螺丝刀】mcxa156使用低功耗定时器适配硬件RTC框架被打赏26分 | |
【STM32F769】AI之与本地deepseek对接被打赏50分 | |
Buck电路工作在CCM模式下电感电流的计算公式是什么?被打赏5分 | |
buck电路工作原理被打赏5分 | |
基于MSPM0L1306的MODBUS-RTU协议通讯实验被打赏100分 | |
我想要一部加热台+多合一调试工具被打赏18分 | |
每周了解几个硬件知识+485硬件知识分享被打赏10分 |
