Has anybody ever developed AMD nor flash boot for EP93xx? The Cirrus Logic EDB board uses Intel flash. Also we want to use RTL8201 to replace the CS89xx on original board, anybody has the driver? Thanks.
My email: rxia@oplinx.com
[align=right][color=#000066][此贴子已经被作者于2005-8-14 16:01:29编辑过][/color][/align]
介绍一款最新ADI公司集成ARM7的微处理器
ADUC7020 - Precision Analog Microcontroller: 45MIPS ARM7 Flash MCU + 5-Ch 12-Bit ADC + Quad 12-Bit DAC。
The ADuC7020 precision analog microcontroller is a fully integrated 12-bit data acquisition system-on-a-chip, featuring an ARM7TDMI MCU core and 12-bit 1MSPS ADC. Like all of ADI's MicroConverter products, it features precision A/D & D/A conversion and a Flash microcontroller on a single chip.
1、5-Channel, 1 MSPS, 12-Bit ADC
2、Four 12-Bit Rail-to-Rail Voltage Output DACs
3、Precision Voltage Reference (10 ppm)
4、45MIPS ARM7TDMI MCU Core
5、62K-Byte In-Circuit Re-Programmable Flash Program/Data Memory
8K-Byte SRAM
6、Serial Interface Ports (UART, SPI, and dual I2C)
7、Comparator, Programmable Logic Array (PLA), Power Supply Monitor (PSM), Power-On Reset (POR), Flexible Core Clocking Options, Flexible Power-Down Modes
8、In-System Serial Programming
9、In-System JTAG Emulation
| 【FreeRtos】FreeRtos + MPU模块的配置使用被打赏¥32元 | |
| 【分享开发笔记,赚取电动螺丝刀】墨水屏文本显示器被打赏¥25元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取磁力计iis2mdc被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取LPS22HH气压、温度被打赏¥19元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX读取STTS751温度被打赏¥17元 | |
| 【STEVAL-STWINKT1B】:结合STMcubeMX软件读取HTS221温湿度被打赏¥22元 | |
| M5PAPERESP32EINKDEVKIT评测|使用MicroPython开发M5Paper被打赏¥15元 | |
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
