需要Cirrus公司所有ARM芯片应用例子的请与我联系
文档包含EP9301、EP9302、EP9307、EP9312、EP9315应用例子:
Fitness Monitor
Automotive GPS Navigation System
POS Terminal (second example)
GSM Modem
Multi Modem Card
Gaming Board
CD Recorder
Audio Jukebox – Linux based (second example)
Medical Appliance
Smart Card Reader
Industrial Panel
Home Automation
Audio Jukebox
POS and Specialty Terminals
Automotive Audio
S3C24A0A支持零售
The S3C24A0A is a 16/32-bit RISC microprocessor, designed to provide a cost-effective, low power, and high performance micro-controller solution for mobile phones and general applications. To provide a sufficient H/W performance for the 2.5G & 3G communication services, the S3C24A0A adopts dual-32-bit bus architecture and includes many powerful hardware accelerators for the motion video processing, serial communications, and etc. For the real time video conferencing, an optimized MPEG4 H/W Encoder/Decoder is integrated.
To reduce total system cost and enhance overall functionality, the S3C24A0A also includes following components: separate 16KB Instruction and 16KB Data Cache, MMU to handle virtual memory management, LCD controller (TFT), Camera Interface, MPEG-4 ME, MC, DCTQ, NAND Flash Boot loader, System Manager (power management & etc.), SDRAM controller, 2-ch UART, 4-ch DMA, 4-ch Timers, General I/O Ports, IICBUS interface, USB Host, SD Host & Multi-Media Card Interface, Memory Stick Interface, PLL for clock generation & etc. The S3C24A0A can be used as a most powerful Application Processor for mobiles phones. For this application, the S3C24A0A has a Modem Interface to communicate with various Modem Chips.
Davicom以太网芯片
1、10/100/1000M 超高速乙太網路晶片
DM9702 - 超高速乙太網路三合一單晶片. (Coming Soon)
2、10/100M 高速乙太網路晶片
DM9000A - DM9000A Ethernet Controller With General Processor Interface
DM9000E - (SMSC LAN91C111 Equivalent)ISA介面高速乙太網路三合一單晶片(含 MII / RMII 介面).
DM9000K - 研發套件
DM9601 - USB介面高速乙太網路三合一單晶片.
DM9102D - PCI 介面高速乙太網路三合一單晶片(Auto-MDIX). 0.25um New
DM9102A - PCI 介面高速乙太網路三合一單晶片. 0.35um
3、10/100M 高速乙太網路實體層收發器
DM9161 - 低功率, 高速乙太網路實體層收發器. 48-pin 0.35um.
DM9161A - 低功率, 高速乙太網路實體層收發器. Auto-MDIX. 48-pin 0.25um.
DM9331 - 100M高速乙太網路光纖實體層媒體轉換器. 48-pin.
DM9301 - 100M高速乙太網路光纖實體層媒體轉換器.
4、10M 乙太網路晶片
DM9008 - ISA介面乙太網路三合一單晶片.
DM9009 - 最經濟, 最有效率PCI 介面乙太網路三合一單晶片 (含MII/RMII/7-wired GPSI介面).
DM9081 - 最經濟, 最有效率乙太網路 (8+2) 集線器晶片.
