void * muxBind
char * pName, /* interface name, for example, ln, ei,... */
int unit, /* unit number */
BOOL (* stackRcvRtn) (void* , long, M_BLK_ID, LL_HDR_INFO * , void* ),
/* receive function to be called. */
STATUS (* stackShutdownRtn) (void* , void* ),
/* routine to call to shutdown the stack */
STATUS (* stackTxRestartRtn) (void* , void* ),
/* routine to tell the stack it can transmit */
void (* stackErrorRtn) (END_OBJ* , END_ERR* , void* ),
/* routine to call on an error. */
long type, /* protocol type from RFC1700 and many */
/* other sources (for example, 0x800 is IP) */
char * pProtoName, /* string name for protocol */
void * pSpare /* per protocol spare pointer */
stackRcvRtn,stackShutdownRtn,stackTxRestartRtn,stackErrorRtn函数该怎样写啊? 共1条
muxBind的输入参数中的函数该怎样写啊?
关键词: muxBind 输入 参数 中的 函数 怎样 写啊
共1条
