电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » IAR 4.11有哪些版本?
共4条 1/1 1 跳转至页
IAR 4.11有哪些版本?
2005-06-23 17:03:30     打赏
IAR 4.11有哪些版本?有30天试用版的吗?
关键词: 哪些     版本
2005-06-27 16:55:00     打赏
谢谢,楼上
我手里有16K限制版的,不知道哪里有其他两个版本的可以down?
[em01][em01][em01]
2005-07-04 01:13:00     打赏
要钱的啊?俺穷,还是算了
2005-07-04 22:10:00     打赏
IAR EWARM已经推出4.30啦,赶紧升级吧。32K版本仍然是free的!
EWARM 4.30 Highlights
ARM11 Support for code generation and debugging for ARM11 cores. With this new addition, EWARM supports the ARM families ARM7, ARM9, ARM9E, ARM10 and ARM11 (ARM instruction set v4, v5 and v6). The Intel XScale architecture (excluding co-processors) is also supported.
Speed optimizations The compiler speed optimizations have been improved. In addition, the floating point library have been rewritten and is about twice as fast as the previous version.
Multi-file compilation Several source files can be combined and compiled at the same time by the compiler. This allows the optimizer to operate on a larger set of code and can result in smaller code.
OSEK Run Time Interface (ORTI) support The ORTI Interface specifies a way to inform the debugger about all the internals of an OSEK OS. Based on this interface, C-SPY now provides sophisticated debug awareness for any ORTI-compliant OS.
OSE Epsilon RTOS plugin The OSE Epsilon Kernel Awareness plugin is delivered and installed as a part of the IAR Embedded Workbench® IDE. For more information, read the OSE Epsilon C-SPY plugin introduction.
Multiple flash loaders Multiple flash loaders can be configured to support systems with more than one flash memory.
Generic flash loader The generic flash loader mechanism was introduced in version 4.10. The document IAR Embedded Workbench flash loader developer guide describes the flash loader functionality, the API and how to develop a flash loader. The source code for supported flash loaders can be found in the ...\arm\src\flashloader directory.
Flash loaders Flash loaders for the following devices are included in the installation Analog Devices ADuC7020, ADuC7021, ADuC7022, ADuC7024, ADuC7025, ADuC7026, ADuC7027 Atmel AT91SAM7S32, AT91SAM7S64, AT91SAM7S128, AT91SAM7S256, AT91SAM7A3, AT91EB40A, AT91EB42, AT91EB55, AT91EB63 Freescale MAC7101, MAC7106, MAC7111, MAC7112, MAC7121, MAC7122, MAC7126, MAC7131, MAC7136, MAC7141, MAC7142 OKI ML67Q4050, ML67Q4051, ML67Q4060, ML67Q4061 Philips LPC2104, LPC2105, LPC2106, LPC2114, LPC2124, LPC2131, LPC2132, LPC2134, LPC2136, LPC2138, LPC2142, LPC2148, LPC2212, LPC2214, LPC2119, LPC2129, LPC2194, LPC2292, LPC2294 ST STR710, STR711, STR712, STR715, STR730 Texas Instruments TMS470R1A128, TMS470R1A256, TMS470R1A384, TMS470R1A1M
I/O register definition files I/O register definition files for symbolic access to registers are used both when programming (C and assembler header files) and during debugging. New additions in this release are: Atmel AT91SAM7S128, AT91SAM7S256, AT91SAM7A3, AT91RM3400 Cirrus EP9302, EP9307 Freescale MAC7106, MAC7126, MAC7136, MAC7202, MAC7212, MAC7222, MAC7242, MAC7252 NetSilicon NS9360 OKI ML67Q4050, ML67Q4051, ML67Q4060, ML67Q4061 Philips LPC2131, LPC2134, LPC2136, LPC2142, LPC2148 Samsung S3C2410, S3C2440A, S3C2440X, S3F445HX ST STR715, STR730 Texas Instruments TMS470R1A1M
Example projects Example projects for various evaluation boards, including evaluation boards from IAR Systems, Analog Devices, Aiji Systems, ARM, Atmel, Cirrus Logic, Freescale, Keil, OKI, Olimex, Pasat, Philips, Phytec, ST and Texas Instruments, are included in the installation, see the ...\arm\src\examples directory.
Editor features - Code templates in the editor allow for quick insertion of commonly used code constructs. You can add your own customized code templates. - Include files can be conveniently accessed via a context menu. - Automatic parenthesis matching.
Trace New trace handling. In addition to hardware trace, the new trace mechanism is also available in the simulator.
J-Link TCP/IP server The debugger can connect remotely to a J-Link JTAG interface on another PC running the J-Link TCP/IP server.
共4条 1/1 1 跳转至页
