Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 60
60 00000028 MSREQ SPSR,r12 ; restore the SPSR
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 86
86 00000044 MSR CPSR,r1 ; and change to that mode
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 94
94 00000058 MSR CPSR,r0 ; return to IRQ mode
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 97
97 0000005c MSR SPSR,r12 ; restore SPSR_irq ready for return
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 107
107 0000007c MSR SPSR,lr ; recover the SPSR when the thread
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 110
110 00000084 MSR CPSR,lr ; recover the CPSR when the thread
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 124
124 00000094 MSR CPSR, r12
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 131
131 000000a4 MSR CPSR, r12
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 176
176 000000f0 MSR SPSR, r4 ; YYY+
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 178
178 000000f8 MSR CPSR, r4 ; YYY+
Error : A1450W: Deprecated form of PSR field specifier used (use _cxsf for future compatibility) OS_CPU_A.S line 199
199 0000011c MSR CPSR, r4 ; CPSR should be SVC32Mode
11 Errors, 0 Warnings
