共1条
VxWorks该怎么收发Ethernet和HDLC的数据包(老站转)
小华
高级工程师
来自:
发表总数:102
查看 短消息 电子邮件
In BSP, there are Ethernet and HDLC driver.
But Boss let me do Tx/Rx without TCP/IP stack.
Please help me?
By the way, Amine, I have fix the Flash R/W problem. Thank you anyway.
编辑 发表於:2002-01-18 - 10:33:19 IP: 202.119.*.*
bridge
来自:
发表总数:31
查看 短消息 电子邮件
你好像没有说清楚你的问题,能再仔细说说?
编辑 发表於:2002-01-18 - 14:47:59 IP: 61.157.*.*
小华
高级工程师
来自:
发表总数:102
查看 短消息 电子邮件
I want to build a module so that can tranfer the ethernet frame to HDLC frame and in verse.
So I was told that I must learn the way to get and send the ethernet frame and HDLC frame .And all these must be done without the high layer support(TCP/IP).
That is I must do this under the IP layer.
Does someone can give me some advice?
Thanks!
编辑 发表於:2002-01-18 - 16:19:46 IP: 61.177.*.*
superme
来自:
发表总数:40
查看 短消息 电子邮件
If it must be done without TCP/IP stack, you should modify the interface routine in Ethernet and HDLC device driver and add a new routine to transfer frame between Ethernet and HDLC.
关键词: VxWorks 怎么 收发 Ethernet 数据
共1条
