有没有烧写bin文件到flash的工具(比较快的)
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 2 disk images:
0: BE4B8-15B4B7 [VIRTUAL BE4B8-15B4B7] (RO)
1: 1000000-100A3FF [VIRTUAL 1000000-100A3FF] (RO)
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
Samsung S3C4510 Ethernet driver version 0.1 (2002-02-20) <mac@os.nctu.edu.tw>
eth0: 00:40:95:36:35:34
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 1024 bind 1024)
VFS: Mounted root (romfs filesystem) readonly.
Freeing init memory: 40K
BINFMT_FLAT: reloc outside program 0x38201be5 (0 - 0x5b34/0x3f80), killing init!
Kernel panic: No init found. Try passing init= option to kernel.
启动uclinux出现上述信息,会不会是rom太大(bin文件668k,转s19后2003k,2Mflash)
