电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » vxWorks下pppoe
共8条 1/1 1 跳转至页
vxWorks下pppoe
2005-09-28 03:01:30     打赏
-> i
NAME ENTRY TID PRI STATUS PC SP ERRNO DELAY
tExcTask excTask fd37b8 0 PEND ed13c fd36d8 0 0
tLogTask logTask fd0e30 0 PEND ed13c fd0d58 0 0
tShell shell f2ddf8 1 READY 80530 f2da70 2b0001 0
tWdbTask 72958 f30020 3 PEND 7b824 f2fe78 0 0
tNetTask netTask f8dd30 50 PEND 7b824 f8dc78 0 0
SYS_PPP_C_1a3488 f42550 80 PEND 7b824 f42460 3d0001 0
SYS_PPP_D_1a33dc f46f90 85 PEND 7b824 f46ea8 0 0
value = 0 = 0x0
-> pfwStackAdd(pppOeSysProfile, &applCallbacks,&myHandle)
value = 15969912 = 0xf3ae78
-> Stack 0xf3ae78 is ready
Opening PPP connection on stack 0xf3ae78
Stack 1 is Deleted.
觉得调试信息太少,增加了
#ifndef PPP_DEBUG
#define PPP_DEBUG
#endif
还是这样少的信息,希望得到gem2000斑竹的帮助!
关键词: vxWorks     pppoe
2005-09-28 18:36:00     打赏
顶
2005-09-28 18:42:00     打赏
pppoe是什么,是不是网卡的驱动设计呢?
2005-09-28 19:05:00     打赏
ppp over Ethernet,在以太网上传送PPP数据包的协议
我们可以通过PPPOE拨号上网,现在装了电信的ADSL宽带,
想在vxworks下拨号上网。
2005-09-29 21:00:00     打赏
搞定,谢谢!
-> Stack 0xf398d8 is ready
Opening PPP connection on stack 0xf398d8
pppConnectionOpen OK!
Time in seconds for establishing connection is 0.400000
Opened PPP connection on stack ID 1
2005-09-29 21:02:00     打赏
-> pppOESessionListShow(pppSysFramework)
Session ID Stack ID
3294 1
value = 19 = 0x13
2005-09-29 22:06:00     打赏
fShow("ppp")
ppp (unit number 1):
Flags: (0xf1) UP POINT-TO-POINT RUNNING
Type: PPP
Internet address: 219.137.107.245
Destination Internet address: 218.19.168.1
Netmask 0xffffff00 Subnetmask 0xffffffff
Metric is 0
Maximum Transfer Unit size is 1492
10265 octets received
0 octets sent
176 packets received
0 packets sent
176 unicast packets received
0 unicast packets sent
0 non-unicast packets received
0 non-unicast packets sent
0 input discards
0 input unknown protocols
0 input errors
0 output errors
value = 21 = 0x15
2005-09-29 22:08:00     打赏
终于搞定ADSL上网!
共8条 1/1 1 跳转至页
