我在做powerpc 603e的bsp调试,编译生成VxWorks.res_rom,发现数据段全是0xFF,bootInit.c中的copylongs()函数将数据段copy到RAM中,RAM中的数据段全是0xFF,
copyLongs ((UINT *)etext, (UINT *) RESIDENT_DATA,
((UINT) wrs_kernel_data_end - (UINT) RESIDENT_DATA) / sizeof (long));
其中etext=0xfff233b0, 0xfff233b0之后全是0xFF
wrs_kernel_data_end =0x14130
RESIDENT_DATA=0x10000 ,0x10000~0x14130之间全为0xFF,0x14130之后为0
