那位老大知道PNE平台到底怎么配置呀,有没有详细点的说明?
多谢!!!
I just use the PNE source code. And I know that after installation, you can make successfully. It will replace the makefile after installation.
If have new project build selection such as DeviceNet, that means you installation includes the PCD or PID. I think if you do not need to use the DeviceNet or etherIp, you will not concer this selection.
