电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » a question of UDP!!!
2006-08-09 04:44:40     打赏
My broad is embedded linux and cpu is arm. I have a question of UDP. My broad want to pass cdrouter test. But when cdrouter create many UDP connections to my broad. Every 10~12 UDP connections are created, the broad will stop a while then cdrouter test failure(it might be timeout or something else...). TCP does not have this problem. Could someone can help me? I have no idea what the problem is.
why my broad will "stop a while" when it has 10~12 UDP connections at continue time?
关键词: question
2006-08-09 19:45:00     打赏
Check what did the CPU do at the time "stop a while"! And try the same programe in your Linux Host!
