电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 请高手指点(关于语音网关内DSP抓取的信息)
2006-09-03 08:35:49     打赏
请高手指点一下,下面是语音中继网关内的DSP信息,哪位高手请帮我看看下面这些大概是什么意思,DSP运转是否正常,请高手指点,谢谢 >DUMPVIEW v5.15l (09 May 2003) //Loaded configuration file: "dumpview.cfg" #field_size nai 2 //Changing size of "struct msg_audit.nai" to 2 //Changing size of "struct message.nai" to 2 #field_size add 2 //Changing size of "struct msg_audit.add" to 2 //Changing size of "struct message.add" to 2 #prim_list SDL { } #entity SDL 'j' alias MT1 #entity SL '~' alias MT2 #entity TSL '+' #entity SCD 'K' #entity SCT '2' #entity SAP '1' #entity DSP 'o' #entity HST '?' #entity SS7 's' #entity DSP 'o' #entity API 'A' alias CC #entity RST 't' #entity M2T '4' alias SL #entity MUA 'F' alias UAL #prim_list RST { SM_STOP_RQ 'F' SM_STOP_CO 'f' SM_RST_CFG_RQ 'D' SM_RST_CFG_RQ 'd' SM_CONFIG_RQ 'C' SM_CONFIG_CO 'c' } #prim_list SS7 { DSP_SET_CNFG_RQ 'W' DSP_SET_CNFG_CO 'w' CNFG_RQ 'C' CNFG_CO 'c' } #prim_list DSP { D_AermNormalRQ 'F' D_AermEmrgncyRQ 'G' D_StartAERM_RQ 'H' D_STOP_AERM_RQ 'I' D_StartSuermRQ 'J' D_STOP_SUERM_RQ 'K' D_TX_START_RQ 'L' D_TX_STOP_RQ 'M' D_RX_START_RQ 'N' D_RX_STOP_RQ 'O' D_SU_IN 'c' D_LinkFailureIN 'f' D_AbortPrvng_IN 'g' D_TX_REQUEST_IN 'h' D_STOP_IN 'i' D_FORCE_RX_RQ 'k' D_SU_RQ 'C' D_CLEAR_RQ 'E' SDL_RESET_IN 'r' SDL_CC_BUSY_RQ 'b' D_CC_NORMAL_RQ 'B' DSP_SET_CnfgRQ 'W' DSP_STOP_RQ 'X' DSP_INFO_RQ 'Z' D_ResetCnfg_RQ 'Y' DBG_DSP_SndSTRT 'd' D_SetCnfgCO 'w' D_STOP_CO 'x' D_RESET_Cnfg_CO 'y' DSP_INFO_CO 'z' } #prim_list A2P { A2PE_ERROR_IN '*' A2PE_EST_RQ 'A' A2PE_EST_IN 'a' A2PE_EST_RS 'B' A2PE_EST_CO 'b' A2PE_REL_RQ 'C' A2PE_REL_IN 'c' A2PE_REL_RS 'D' A2PE_REL_CO 'd' A2PE_BLOCK_RQ 'E' A2PE_BLOCK_IN 'e' A2PE_BLOCK_RS 'F' A2PE_BLOCK_CO 'f' A2PE_UNBLOCK_RQ 'G' A2PE_UNBLOCK_IN 'g' A2PE_UNBLOCK_RS 'H' A2PE_UNBLOCK_CO 'h' A2PE_RESET_RQ 'I' A2PE_RESET_IN 'i' A2PE_RESET_RS 'J' A2PE_RESET_CO 'j' A2PE_CONFUSION_RQ 'K' A2PE_CONFUSION_IN 'k' A2PE_TERMINATE_RQ 'L' A2PE_M_TERMINATE_RQ 'M' A2PE_STC_OOS_IN 'l' A2PE_STC_IS_IN 'm' A2PE_STC_CONGESTION_IN 'q' A2PE_MODIFY_RQ 'N' A2PE_MODIFY_IN 'n' A2PE_MODIFY_RS 'O' A2PE_MODIFY_CO 'o' A2PE_MODIFY_REJ_RQ 'P' A2PE_MODIFY_REJ_CO 'p' } #prim_list MA2 { MA2PE_ERROR_IN '?' MA2PE_SET_CONFIG_RQ 'A' MA2PE_SET_CONFIG_CO 'a' MA2PE_RESET_CONFIG_RQ 'B' MA2PE_RESET_CONFIG_CO 'b' MA2PE_NA_POWER_ON_RQ 'C' MA2PE_NA_POWER_OFF_RQ 'D' MA2PE_STC_OOS_IN 'c' MA2PE_STC_IS_IN 'd' } !!! WARNING: primitive text "SDL_CC_NORMAL_RQ" is too long (max. 15 chars) in the table for "MT1" entity !!! WARNING: primitive text "SOCK_INT_SYNC_CO" is too long (max. 15 chars) in the table for "IP" entity !!! WARNING: primitive text "SOCK_INT_SYNC_RQ" is too long (max. 15 chars) in the table for "IP" entity !!! WARNING: primitive text "MA2PE_SET_CONFIG_RQ" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "MA2PE_SET_CONFIG_CO" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "MA2PE_RESET_CONFIG_RQ" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "MA2PE_RESET_CONFIG_CO" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "MA2PE_NA_POWER_ON_RQ" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "MA2PE_NA_POWER_OFF_RQ" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "MA2PE_STC_OOS_IN" is too long (max. 15 chars) in the table for "MA2" entity !!! WARNING: primitive text "A2PE_CONFUSION_RQ" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "A2PE_CONFUSION_IN" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "A2PE_TERMINATE_RQ" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "A2PE_M_TERMINATE_RQ" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "A2PE_STC_CONGESTION_IN" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "A2PE_MODIFY_REJ_RQ" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "A2PE_MODIFY_REJ_CO" is too long (max. 15 chars) in the table for "A2P" entity !!! WARNING: primitive text "SDL_CC_NORMAL_RQ" is too long (max. 15 chars) in the table for "SDL" entity //Reading raw dump //Dumpview options: #binary_file ON //-R #system_info ON //-N- #motorola //-M #msg_audit_element_size 208 #alignment 4 #display_delta OFF //-D- #fixed_length_display ON //-F #graphic_characters ON //-G #message_audit_data_only ON //-O #q931_detail_level 2 //-Q2 #system_tick 25 //-T25 #debug ON //-! M - B - TC| iM- iB| p_msg -p_buffer| s.ms -D|from-to| code | nai:sp: add|size: =========================================================================================================== 1- 5-624|120-120|02b6f080-0297cc00|12130.875-R|nil-API|ACU_CONN_RQ | 0:61: 1a#130:(Unknown service:0) 00 00 00 00 02 97 cc 90 00 00 4d 00 01 00 00 00 00 00 00 00 01 01 00 00 13 00 00 00 00 00 00 00 00 00 00 00 00 0d 00 04 01 00 00 ff 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 30 31 33 35 35 34 37 36 33 37 31 37 7c 00 32 38 39 34 30 38 32 7c 00 00 00 45 20 55 70 54 1- 5-624|120-120|02b6f080-0297cc00|12130.875-I|API-CC |ACU_CONN_RQ | 0:61: 1a#130:(Unknown service:0) 00 00 00 00 02 97 cc 90 00 00 4d 00 01 00 00 00 00 00 00 00 01 01 00 00 13 00 00 00 00 00 00 00 00 00 00 00 00 0d 00 04 01 00 00 ff 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 30 31 33 35 35 34 37 36 33 37 31 37 7c 00 32 38 39 34 30 38 32 7c 00 00 00 45 20 55 70 54 1- 5-624|120-120|02b6f280-0297ba00|12130.875-I|CC -NS |NS_CONN_RQ | 0: 0: 1a#112: 00 3c 00 4c 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 3c 00 00 00 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0d 30 31 33 35 35 34 37 36 33 37 31 37 00 00 00 00 00 04 01 00 00 08 32 38 39 34 30 38 32 00 00 00 00 00 10 00 10 00 10 03 00 ff 00 00 00 00 00 00 00 00 00 ff ff ff ff 00 00 01 01 00 01 00 03 00 02 13 00 1- 5-629|120-120|02b6f080- |12130.875-R|NS -DLD|DL_DA_RQ | 0: 0: 1|41: Q.931: PD=8 CR=785(0x311,Orig) SETUP(05): Bc(04): 3.1kHz-Audio/64k/A-law 90 90 a3 ChanId(18): B19/excl(PRI) a9 83 93 CallingNb(6c): type:subscr,plan:ISDN "2894082" c1 32 38 39 34 30 38 32 CalledNb(70): type:unknown,plan:unknown "013554763717" 80 30 31 33 35 35 34 37 36 33 37 31 37... Hex dump: 08 02 03 11 05 04 03 90 90 a3 18 03 a9 83 93 6c 08 c1 32 38 39 34 30 38 32 70 0d 80 30 31 33 35 35 34 37 36 33 37 31 37 a1 1- 5-629|120-120|02b6f080- |12130.875-I|DLD-PHD|PH_DA_RQ | 0: 0: 0|45:I[2,70]p0 tei=0 00 01 04 8c 08 02 03 11 05 04 03 90 90 a3 18 03 a9 83 93 6c 08 c1 32 38 39 34 30 38 32 70 0d 80 30 31 33 35 35 34 37 36 33 37 31 37 a1 2- 5-629|119-120|02b6f400- |12130.875-R|DIT-PHD|PH_IT_XMIT_IN | 0: 0: 0|0: 2- 6-629|119-119|02b6f400-0297e000|12130.900-R|DIT-PHD|PH_IT_RCV_IN | 0: 0: 0#4: 00 01 01 06 2- 5-629|119-120|02b6f400- |12130.900-I|PHD-DLD|PH_DA_IN | 0: 0: 0|4:RR[3] p0 tei=0. 00 01 01 06 1- 6-629|119-119|02b6f400-0297c600|12130.925-R|DIT-PHD|PH_IT_RCV_IN | 0: 0: 0#14: 02 01 8c 06 08 02 83 11 02 18 03 a9 83 93 1- 5-629|119-120|02b6f400- |12130.925-I|PHD-DLD|PH_DA_IN | 0: 0: 0|14:I[70,3]p0 tei=0 02 01 8c 06 08 02 83 11 02 18 03 a9 83 93 2- 5-629|119-120|02b6f080- |12130.925-I|DLD-DLD|WAIT_ACK | 0: 0: 1|0: 2- 5-629|120-120|02b6f280- |12130.925-I|DLD-PHD|PH_DA_RQ | 0: 0: 0|4:RR[71] p0 tei=0. 02 01 01 8e 2- 5-629|120-120|02b6f400- |12130.925-R|DLD-NS |DL_DA_IN | 0: 0: 1|10: Q.931: PD=8 CR=785(0x311,Dest) CALL-PROC(02): ChanId(18): B19/excl(PRI) a9 83 93 Hex dump: 08 02 83 11 02 18 03 a9 83 93 2- 6-629|120-120|02b6e680-0297cc00|12130.925-I|NS -CC |NS_CALL_PROC_IN| 0: 0: 1a#28: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 01 00 03 00 02 13 00 3- 6-629|120-120|02b6f400-0297d000|12130.925-I|CC -API|ACU_PROGRESS_IN| 0:61: 1a#48: 00 00 00 00 00 00 00 00 43 10 00 ff ff 00 00 00 ff 00 00 00 ff 00 01 01 00 00 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2- 4-629|120-120|02b6ea00- |12130.925-R|CC -MPH|MPH_B_SWITCH_RQ| 0: 1:ffff|36:B19,Audio 41 13 00 30 01 13 8e 10 5a 04 03 90 90 a3 18 03 a9 83 91 6c 08 c1 32 38 39 34 30 37 30 70 0d 80 30 31 33 37 1- 4-629|120-120|02b6f280- |12130.925-R|DIT-PHD|PH_IT_XMIT_IN | 0: 0: 0|4: 02 01 01 8e 1- 5-629|120-120|02b6f280-0297ba00|12131.425-R|nil-API|ACU_CONN_RQ | 0:61: 1b#130:(Unknown service:0) 00 00 00 00 02 97 ba 90 00 00 4d 00 01 00 00 00 00 00 00 00 01 01 00 00 15 00 00 00 00 00 00 00 00 00 00 00 00 0d 00 04 01 00 00 ff 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 30 31 33 32 38 36 34 31 32 37 37 37 7c 00 32 38 39 34 30 38 31 7c 00 00 63 68 6e 6f 6c 6f 1- 5-629|120-120|02b6f280-0297ba00|12131.425-I|API-CC |ACU_CONN_RQ | 0:61: 1b#130:(Unknown service:0) 00 00 00 00 02 97 ba 90 00 00 4d 00 01 00 00 00 00 00 00 00 01 01 00 00 15 00 00 00 00 00 00 00 00 00 00 00 00 0d 00 04 01 00 00 ff 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ff 00 30 31 33 32 38 36 34 31 32 37 37 37 7c 00 32 38 39 34 30 38 31 7c 00 00 63 68 6e 6f 6c 6f 1- 5-629|120-120|02b6ea00-0297d000|12131.425-I|CC -NS |NS_CONN_RQ | 0: 0: 1b#112: 00 3c 00 4c 00 64 00 00 00 00 00 00 00 00 00 00 00 00 00 3c 00 00 00 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0d 30 31 33 32 38 36 34 31 32 37 37 37 00 00 00 00 00 04 01 00 00 08 32 38 39 34 30 38 31 00 00 00 00 00 10 00 10 00 10 03 00 ff 00 00 00 00 00 00 00 00 00 ff ff ff ff 00 00 01 01 00 01 00 03 00 02 15 00 1- 5-634|120-120|02b6f280- |12131.425-R|NS -DLD|DL_DA_RQ | 0: 0: 1|41: Q.931: PD=8 CR=1041(0x411,Orig) SETUP(05): Bc(04): 3.1kHz-Audio/64k/A-law 90 90 a3 ChanId(18): B21/excl(PRI) a9 83 95 CallingNb(6c): type:subscr,plan:ISDN "2894081" c1 32 38 39 34 30 38 31 CalledNb(70): type:unknown,plan:unknown "013286412777" 80 30 31 33 32 38 36 34 31 32 37 37 37... Hex dump: 08 02 04 11 05 04 03 90 90 a3 18 03 a9 83 95 6c 08 c1 32 38 39 34 30 38 31 70 0d 80 30 31 33 32 38 36 34 31 32 37 37 37 a1 1- 5-634|120-120|02b6f280- |12131.425-I|DLD-PHD|PH_DA_RQ | 0: 0: 0|45:I[3,71]p0 tei=0 00 01 06 8e 08 02 04 11 05 04 03 90 90 a3 18 03 a9 83 95 6c 08 c1 32 38 39 34 30 38 31 70 0d 80 30 31 33 32 38 36 34 31 32 37 37 37 a1 2- 5-634|119-120|02b6f080- |12131.425-R|DIT-PHD|PH_IT_XMIT_IN | 0: 0: 0|0: 2- 5-634|119-120|02b6f080- |12131.450-I|PHD-DLD|PH_DA_IN | 0: 0: 0|4:RR[4] p0 tei=0. 00 01 01 08 1- 6-634|119-119|02b6f080-0297c600|12131.475-R|DIT-PHD|PH_IT_RCV_IN | 0: 0: 0#14: 02 01 8e 08 08 02 84 11 02 18 03 a9 83 95 1- 5-634|119-120|02b6f080- |12131.475-I|PHD-DLD|PH_DA_IN | 0: 0: 0|14:I[71,4]p0 tei=0 02 01 8e 08 08 02 84 11 02 18 03 a9 83 95 2- 5-634|119-120|02b6f280- |12131.475-I|DLD-DLD|WAIT_ACK | 0: 0: 1|0: 2- 5-634|120-120|02b6ea00- |12131.475-I|DLD-PHD|PH_DA_RQ | 0: 0: 0|4:RR[72] p0 tei=0. 02 01 01 90 2- 5-634|120-120|02b6f080- |12131.475-R|DLD-NS |DL_DA_IN | 0: 0: 1|10: Q.931: PD=8 CR=1041(0x411,Dest) CALL-PROC(02): ChanId(18): B21/excl(PRI) a9 83 95 Hex dump: 08 02 84 11 02 18 03 a9 83 95 2- 6-634|120-120|02b6f400-0297ba00|12131.475-I|NS -CC |NS_CALL_PROC_IN| 0: 0: 1b#28: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 01 00 01 00 03 00 02 15 00 3- 6-634|120-120|02b6f080-0297cc00|12131.475-I|CC -API|ACU_PROGRESS_IN| 0:61: 1b#48: 00 00 00 00 00 00 00 00 43 10 00 ff ff 00 00 00 ff 00 00 00 ff 00 01 01 00 00 15 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2- 4-634|120-120|02b6e680- |12131.475-R|CC -MPH|MPH_B_SWITCH_RQ| 0: 1:ffff|36:B21,Audio 41 15 00 30 01 15 00 00 6e 6e 00 00 00 00 10 20 00 45 01 13 09 02 17 30 25 34 30 39 38 70 0d 80 30 31 33 34 1- 4-634|120-120|02b6ea00- |12131.475-R|DIT-PHD|PH_IT_XMIT_IN | 0: 0: 0|4: 02 01 01 90 1- 4-634|119-120|02b6f280- |12132.025-R|TI -DLD|TI_203 | 1: 0: 1|10:Seq nb = 42 00 2a 06 8e 08 02 04 11 05 04 1- 5-629|119-119|02b6e680-0297e000|12132.350-R|DIT-PHD|PH_IT_RCV_IN | 0: 0: 0#21: 02 01 90 08 08 02 ff 10 01 1e 02 82 81 1e 02 82 88 1e 02 82 88 1- 4-629|119-120|02b6e680- |12132.350-I|PHD-DLD|PH_DA_IN | 0: 0: 0|21:I[72,4]p0 tei=0 02 01 90 08 08 02 ff 10 01 1e 02 82 81 1e 02 82 88 1e 02 82 88 2- 4-629|119-120|02b6f280- |12132.350-I|DLD-DLD|WAIT_ACK | 0: 0: 1|0: 2- 4-629|120-120|02b6e280- |12132.350-I|DLD-PHD|PH_DA_RQ | 0: 0: 0|4:RR[73] p0 tei=0. 02 01 01 92 2- 4-629|120-120|02b6e680- |12132.350-R|DLD-NS |DL_DA_IN | 0: 0: 1|17:
关键词: 高手     指点     关于     语音     关内     取的     信息     #ent
