电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » TCP IP 源代码,请排队!!
共48条 1/5 1 2 3 4 5 › ›| 跳转至页
TCP IP 源代码,请排队!!
2002-06-28 19:21:17     打赏
TinyTcp Public Domain Release The files in this release contain a simple implementation of TCP & FTP, suitable for burning into ROM. It is, in effect, a big hack put together in two or three days. It works for us, though, and you might like it, too. We use it to boot our image processor by retrieving a load file using the standard FTP server. The code is intended to use the buffers from the Ethernet interface, although shadow buffers could be hidden in the driver with no problem. On one home-brew board here and didn't support byte-mode access to it. Hence, the code takes pains to fool our local compiler into never generating byte- or bit-mode instructions. Since we have already burned the TCP into ROM, it is unlikely that any further development will take place at IMAGEN. I would be willing to act as a clearinghouse for future improvements to the code. Warning: the code was intended for a 68000, and doesn't have any byte swapping support in it. Shouldn't be too hard to add if you want to run it on a little-endian machine. Please note (and honor) the copyright on each file: Copyright (C) 1986, IMAGEN Corporation "This code may be duplicated in whole or in part provided that [1] there is no commercial gain involved in the duplication, and [2] that this copyright notice is preserved on all copies. Any other duplication requires written notice of the author (Geoffrey H. Cooper)." ...in other words, do what you want with the code, but don't sell it and give IMAGEN and me credit on whatever you produce. If you develop a product based on this code and want to sell it, give me a call and I'll be reasonable. This code is distributed "as is." Neither the author nor IMAGEN Corporation guarantees that it works or meets any particular specifications. The act of distributing this software does not represent a commitment by either the author nor IMAGEN Corporation to provide maintenance or consulting services related to this software. But feel free to ask me any questions that you can't answer for yourself. - Geof Cooper Imagen Corporation (408)986 9400 [imagen!geof@decwrl.dec.com, {decwrl,saber}!imagen!geof] April 16, 1986 The package requires some system support: clock_ValueRough() - should be a procedure that returns the current value of a millisecond clock. The procedure is called frequently, so that interrupts are not needed to service the clock. Our implementation polls the real time timer and assumes that it is called frequently enough so that it doesn't miss clock ticks (Since the timer is only used for network timeouts, it doesn't really matter if it does miss clock ticks, of course). Systems without a clock could probably get by with a procedure that increments a static variable and returns it, by adjusting the timeout constants in the program. Network driver - some network interface driver is needed. A driver for a 3Com multibus (ethernet) board is included; this board isn't made anymore (at least not by 3Com, there are still compatible boards being made, but I don't know of any being popularly distributed), so you'll probably need to write a driver for the board in your system. Guide to source files: sed.c - Simple Ethernet Driver - Driver for 3Com multibus card. If you have another type of Ethernet board, you can use this driver as a template. sed.h - header file for the above. arp.c - Implementation of Address Resolution Protocol. Note that there is no arp "mapping" per se. The higher level code (tcp, in this case) is required to keep track of internet and ethernet addresses. tinytcp.c - Implementation of TCP. tinytcp.h - Header file for above, and for everything else. tinyftp.c - Implementation of FTP, only allows files to be retrieved, not sent. [em27]
关键词: 源代码     排队
2002-12-18 17:24:00     打赏
时间太久了,忘记了放在什么地方,我再好好找找!真对不起各位!
2002-12-23 18:18:00     打赏
我以前也有,但要找一下,找到放到gao那里。 ftp://ftp.edw.com.cn u=gao p=123456789 不要再留email了。
2003-01-10 16:55:00     打赏
楼上的各位,看看第39层
楼上的各位,看看第39层
2003-01-18 00:34:00     打赏
那么多人?
2003-02-28 01:49:00     打赏
不要排队了,23号以前的票都卖完了,只有站票。
2004-07-13 17:15:00     打赏
请给我一份,谢谢! njhelong@163.com 或者 njhelong@tom.com
2004-07-15 17:34:00     打赏
给我一份好吗? whqlongs@163.com
2004-07-19 03:17:00     打赏
请给我一份 lgh992@126.com[em09]
