IRQHandler
; Enhanced Interrupt Controller. EIC_base_addr     EQU    0xFFFFF800;
LDR r0, =EIC_base_addr
;IVR_off_addr        EQU    0x18      ; Interrupt Vector Register offset
        LDR    r1, =IVR_off_addr
        ADD    pc,r0,r1                  ; Branch to the IRQ handler.
比如Timer0产生了中断, 程序是如何跳到Timer0的ISR的?
