共5条
好东西,网络摄像机电路图和外观。
Specifications:
Chipset DMP M6117D (386SX-40MHz)
RAM 4MB onboard
I/O Communication
interface RJ-45 / 10Base-T Ethernet
RJ-11 / V.90 56K Modem
Performance Ethernet: Frame updated from 0.1 sec. to 10 min. (static)
Modem: Frame updated from 1 sec. to 10 min. (static)
Protocol TCP/IP
PPP
HTTP
Application
Support NTSC / PAL supported
Connector 10Base- T RJ-45 connector
RS-232 D-type 9-pin connector
Video-in by 4 BNC connector
Display NTSC / PAL supported
Video input for 4 independent channels
Separated view windows supported from full screen / 4
windows / 16 windows
Resolution Full
screen: 720 x 480
CIF: 352 x 240
QCIF: 176 x 112
共5条
| OrangePiZero2W系统被打赏¥33元 | |
