共3条
问
各位大侠:
我是新手,请多关照!我想用下面的程序测量ICP引脚上的周期,可是好象总存在问题,请高手帮我看看问题出在什么地方?谢谢,比较急!
#include<iom8v.h>
#include<math.h>
#include <macros.h>
#define osccal 0xae//内部RC校正常数
#pragma data:code
const unsigned char table[16]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,
0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
#pragma data:data
unsigned char ledbuff[]={0,0,0,0};
unsigned int oldcount;
unsigned int newcount;
unsigned char counter;
/* 微秒级延时程序 */
void delay_us(int time)
do
time--;
while (time>1);
//动态扫描显示,使用B口传递显示数据
void display(void)
unsigned char i;
DDRB|=0xfe;
PORTB|=0xfe;
DDRD|=0xf0;
PORTD|=0xf0;
for(i=0;i<4;i++)
PORTB=ledbuff[i];
PORTD&=~(1<<(i+4));
delay_us(400);
PORTD|=0xf0;
//将COUNT 十六进制数据转换为LED 七段码
void hextobcd(unsigned int count)
unsigned char i;
for(i=0;i<4;i++)
ledbuff[i]=table[count%10];
count=count/10;
//初始化
void sys_init(void)
DDRB|=0xfe; //PB0不能作为输出,否则会引发中断
PORTB|=0xfe; //端口初始化
DDRD|=0xf0;
PORTD|=0xf0; //片选,低有效
TIMSK=0x20; //使能T1捕捉中断
TCCR1A=0x00;
TCCR1B=0xC2; //CK/8,捕捉周期的单位为1us
ICR1=0;
TCNT1=0;
counter=0;
//捕捉中断处理程序
#pragma interrupt_handler ICP_timer1:iv_TIMER1_CAPT
void ICP_timer1(void)
unsigned int temp;
counter++;
if(counter==2)
newcount=ICR1-temp;
counter=0;
ICR1=0;
temp=0;
//TCCR1B=0xC2;
temp=ICR1;
TCNT1=0;
//测量ICP引脚上的信号的周期
void main()
{ void sys_init(void);
OSCCAL=osccal; //校正振荡频率
sys_init();
SEI(); //使能全局中断
while(1)
if ((newcount&0xfff8)!=(oldcount&0xfff8))
oldcount=newcount;
hextobcd(oldcount);
display();
//周期我用示波器测过,很稳定的,可是测量显示值总在跳,是设置的问题吗?还是别的地方出了问题?
答 1: 使用外部振荡试试,内部rc有误差
#include<iom8v.h>
#include<math.h>
#include <macros.h>
#pragma data:code
#pragma data:data
/* 微秒级延时程序 */
do
time--;
while (time>1);
//动态扫描显示,使用B口传递显示数据
void display(void)
unsigned char i;
DDRB|=0xfe;
PORTB|=0xfe;
DDRD|=0xf0;
PORTD|=0xf0;
for(i=0;i<4;i++)
PORTB=ledbuff[i];
PORTD&=~(1<<(i+4));
delay_us(400);
PORTD|=0xf0;
unsigned char i;
for(i=0;i<4;i++)
count=count/10;
//初始化
void sys_init(void)
DDRD|=0xf0;
TCCR1A=0x00;
ICR1=0;
TCNT1=0;
counter=0;
//捕捉中断处理程序
unsigned int temp;
counter++;
if(counter==2)
newcount=ICR1-temp;
counter=0;
ICR1=0;
temp=0;
//TCCR1B=0xC2;
temp=ICR1;
TCNT1=0;
//测量ICP引脚上的信号的周期
void main()
sys_init();
SEI(); //使能全局中断
while(1)
oldcount=newcount;
hextobcd(oldcount);
display();
共3条
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
