共3条
GCC,AMEG8 用GCC编译的AMEG8中的休眠指令是?
问
用GCC编译的AMEG8中的休眠指令是什么?我用SLEEP为什么不能通过?
答 1:
看gcc的手册5.5 Power Management and Sleep Modes
5.5.1 Detailed Description
#include <AVR/sleep.h>
Use of the SLEEP instruction CAN allow your application to reduce it’s power com-sumption
considerably. AVR devices CAN be put into different sleep modes by chang-ing
the SMn bits of the MCU Control Register ( MCUCR ). Refer to the datasheet for the
details relating to the device you are using.
Sleep Modes
Note:
Some of these modes are not available on all devices. See the datasheet for target
device for the available sleep modes.
• #define SLEEP MODE IDLE 0
• #define SLEEP MODE ADC BV(SM0)
• #define SLEEP MODE PWR DOWN BV(SM1)
• #define SLEEP MODE PWR SAVE ( BV(SM0) | BV(SM1))
• #define SLEEP MODE STANDBY ( BV(SM1) | BV(SM2))
• #define SLEEP MODE EXT STANDBY ( BV(SM0) | BV(SM1) | BV(SM2))
Sleep Functions
• void set sleep mode (uint8 t mode)
• void sleep mode (void)
答 2: 是啊,要用setsleepmode()和sleepmode()才行或者这样也可以:
asm volatile("sleep"::);
注意这之前要先设置睡眠模式。
Sleep Modes
Note:
Sleep Functions
注意这之前要先设置睡眠模式。
共3条
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
| OK1126B-S开发板下多时段语音提示型电子时钟被打赏¥27元 | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
| OK1126B-S开发板的脚本编程及应用设计被打赏¥27元 | |
| 5v升压8.4v两节锂电池充电芯片,针对同步和异步的IC测试被打赏¥35元 | |
| 【S32K3XX】S32DS LPI2C 配置失败问题解决被打赏¥22元 | |
| 【S32K3XX】FLASH 的 DID 保护机制被打赏¥19元 | |
