44B0,320,240LCD 关于44B0驱动单色320 240LCD的问题
问
答 1:
关于44B0驱动单色320 240LCD的问题现在在做44B0驱动单色320 240LCD
开发板自带的是彩色256色的程序,如下
LCD。H中的内容
#ifndef __LCD_H__
#define __LCD_H__
#include "def.h"
#define SCR_XSIZE (320)
#define SCR_YSIZE (240)
#define COLOR_NUMBER 256
#define LCD_XSIZE (320)
#define LCD_YSIZE (240)
#define M5D(n) ((n) & 0x1fffff)
#define ARRAY_SIZE_COLOR (SCR_XSIZE/1*SCR_YSIZE)
#define HOZVAL (LCD_XSIZE/4-1)
#define HOZVAL_COLOR (LCD_XSIZE*3/8-1)
#define LINEVAL (LCD_YSIZE-1)
#define MVAL (13)
#define CLKVAL_COLOR (4) //60Mhz
#define MVAL_USED 0
#define LCD_BUF_SIZE (SCR_XSIZE * SCR_YSIZE)
extern INT32U aLcdActiveBuffer[LCD_YSIZE][LCD_XSIZE/4];
#define LCD_PutPixel(x, y, c)\
aLcdActiveBuffer[(y)][(x)/4]=(( aLcdActiveBuffer[(y)][(x)/4] & (~(0xff000000>>((x)%4)*8)) ) | ( (c)<<((4-1-((x)%4))*8) ));
#define LCD_ActivePutPixel(x, y, c)\
aLcdActiveBuffer[(y)][(x)/4]=(( aLcdActiveBuffer[(y)][(x)/4] & (~(0xff000000>>((x)%4)*8)) )\
#define GUISWAP(a, b) {a^=b; b^=a; a^=b;}
void Lcd_Init(void);
void Lcd_Clr(void);
void Lcd_Draw_Box (INT16 usLeft, INT16 usTop, INT16 usRight, INT16 USBottom, INT8U ucColor);
void Lcd_Draw_Line (INT16 usX0, INT16 usY0, INT16 usX1, INT16 usY1, INT8U ucColor, INT16U usWidth);
void Lcd_Draw_HLine (INT16 usX0, INT16 usX1, INT16 usY0, INT8U ucColor, INT16U usWidth);
void Lcd_Draw_VLine (INT16 usY0, INT16 usY1, INT16 usX0, INT8U ucColor, INT16U usWidth);
void Lcd_Fill_Box (INT16U usX0, INT16U usY0, INT16U usX1, INT16U usY1, INT8U ucColor);
#endif
初始化部分
void Lcd_Init (void)
//int i, j;
//int time = 10000*2;
rLCDCON1=(0x0)|(2<<5)|(MVAL_USED<<7)|(0x3<<8)|(0x3<<10)| (CLKVAL_COLOR<<12);//0x4f40
// disable,8B_SNGL_SCAN,WDLY=8clk,WLH=8clk,
rLCDCON2=(119)|(HOZVAL_COLOR<<10)|(10<<21);
//LINEBLANK=10 (without any calculation)
rLCDSADDR1= (0x3<<27) | ( ((unsigned int) aLcdActiveBuffer>>22)<<21 ) | M5D((unsigned int)aLcdActiveBuffer>>1);
// 256-color, LCDBANK, LCDBASEU
rLCDSADDR2= M5D((((unsigned int)aLcdActiveBuffer+ (SCR_XSIZE*LCD_YSIZE)/2)>>1)) | (MVAL<<21);
rLCDSADDR3= (LCD_XSIZE/2) | ( ((SCR_XSIZE-LCD_XSIZE)/2)<<9 );
//The following value has to be changed for better display.
rREDLUT =0xfdb96420;
rGREENLUT=0xfdb96420;
rBLUELUT =0xfb40;
//rDITHMODE=0x0;
rDITHMODE = 0x12210;
rDP1_2 =0xa5a5;
rDP4_7 =0xba5da65;
rDP3_5 =0xa5a5f;
rDP2_3 =0xd6b;
rDP5_7 =0xeb7b5ed;
rDP3_4 =0x7dbe;
rDP4_5 =0x7ebdf;
rDP6_7 =0x7fdfbfe;
rLCDCON1=(0x1)|(2<<5)|(MVAL_USED<<7)|(0x3<<8)|(0x3<<10)|(CLKVAL_COLOR<<12); //enable
//rLCDCON1=(0x1)|(2<<5)|(MVAL_USED<<7)|(0x1<<8)|(0x1<<10)|(CLKVAL_COLOR<<12); //enable
rPDATE=0x1fe;
Lcd_Clr();
疑问
1:原来的是用INT32U aLcdActiveBuffer[LCD_YSIZE][LCD_XSIZE/4];
LCD BUFFER SIZE是如何计算得到的,如换单色或其他色的如何改?#define LCD_BUF_SIZE (SCR_XSIZE * SCR_YSIZE)这个大小为什么与上面的不同?
2:#define M5D(n) ((n) & 0x1fffff) M5D做何用?
3:#define LCD_PutPixel(x, y, c)\
这两个画点函数/4 *8 %4 怎么得来的?如为其他色应该如何修改?
问题有点多,不过还是希望哪位老兄给解答一下,先谢了!!
开发板自带的是彩色256色的程序,如下
LCD。H中的内容
#ifndef __LCD_H__
#define __LCD_H__
#include "def.h"
#define MVAL (13)
#define MVAL_USED 0
void Lcd_Clr(void);
#endif
初始化部分
//int i, j;
rBLUELUT =0xfb40;
//rDITHMODE=0x0;
rDP1_2 =0xa5a5;
rDP4_7 =0xba5da65;
rDP3_5 =0xa5a5f;
rDP2_3 =0xd6b;
rDP5_7 =0xeb7b5ed;
rDP3_4 =0x7dbe;
rDP4_5 =0x7ebdf;
rDP6_7 =0x7fdfbfe;
rPDATE=0x1fe;
Lcd_Clr();
疑问
| OK1126B-S开发板下以导航按键控制云台/机械臂姿态调整被打赏¥29元 | |
| 【树莓派5】便携热成像仪被打赏¥36元 | |
| 【树莓派5】环境监测仪被打赏¥35元 | |
| OK1126B-S开发板下多时段语音提示型电子时钟被打赏¥27元 | |
| OK1126B-S开发板下函数构建及步进电机驱动控制被打赏¥25元 | |
| 【S32K3XX】LPI2C 参数配置说明被打赏¥20元 | |
| OK1126B-S开发板的脚本编程及应用设计被打赏¥27元 | |
| 5v升压8.4v两节锂电池充电芯片,针对同步和异步的IC测试被打赏¥35元 | |
| 【S32K3XX】S32DS LPI2C 配置失败问题解决被打赏¥22元 | |
| 【S32K3XX】FLASH 的 DID 保护机制被打赏¥19元 | |
