接收中断处理程序里的全局变量无法返回接收值
问
我在做AVRMAGE32L与计算机串口通信时,发现接收中断处理程序里的全局变量无法返回接收值,请大虾指点。谢谢!
unsigned char preceive,rec_len,send_ok,psend;
unsigned char received_ok;
unsigned char receivebuf[20];
unsigned char sendbuf[20];
unsigned char send_max,i;
interrupt [USART_RXC] void usart_rx_isr(void)
unsigned char data;
#asm("cli")
if (UCSRA&(1<<RXC))
data=UDR;
receivebuf[preceive]=data;
if(receivebuf[0]==0x02) //字头
preceive++;
if(preceive==3)
rec_len=receivebuf[1];
if((preceive==rec_len) &&preceive>3)) //接收完received_ok=1
if(data==3) //字结束
{ received_ok=1;
send_ok=0;
preceive=0;
rec_len=0;
#asm("sei")
interrupt [USART_TXC] void usart_tx_isr(void)
#asm("cli")
if(send_ok==0)
UDR=sendbuf[psend];
psend++;
if(psend>=send_max)
psend=0;
received_ok=0;
send_ok=1;
#asm("sei")
void main(void)
UCSRA=0x00;
UCSRB=0xD8;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=51;
#asm("sei")
received_ok=0;
preceive = 0;
send_ok=0xff;
while (1)
if(received_ok==1)
//接收中断退出后received_ok又是以前值,所以进不来
data1=1;
data2=2;
data3=0;
data4=0xcc;
send_read(receivebuf[2],0x09);
delay(1000);
答 1: 谁帮帮我,郁闷!!!我在做AVRMAGE32L与计算机串口通信时,发现接收中断处理程序里的全局变量无法返回接收值,请大虾指点。谢谢!
unsigned char data;
#asm("cli")
if (UCSRA&(1<<RXC))
data=UDR;
preceive++;
if(preceive==3)
if(data==3) //字结束
received_ok=1;
send_ok=0;
preceive=0;
rec_len=0;
#asm("sei")
#asm("cli")
if(send_ok==0)
UDR=sendbuf[psend];
psend++;
if(psend>=send_max)
psend=0;
received_ok=0;
send_ok=1;
#asm("sei")
void main(void)
UCSRA=0x00;
UCSRB=0xD8;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=51;
#asm("sei")
received_ok=0;
preceive = 0;
send_ok=0xff;
while (1)
if(received_ok==1)
data1=1;
data2=2;
data3=0;
data4=0xcc;
delay(1000);
答 2: 被编译器优化了吧加关键词 volatile unsigned char received_ok. 答 3: 谢谢hover99
unsigned char data;
#asm("cli")
if (UCSRA&(1<<RXC))
data=UDR;
preceive++;
if(preceive==3)
if(data==3) //字结束
{ received_ok=1;
send_ok=0;
preceive=0;
rec_len=0;
#asm("sei")
#asm("cli")
if(send_ok==0)
UDR=sendbuf[psend];
psend++;
if(psend>=send_max)
psend=0;
received_ok=0;
send_ok=1;
#asm("sei")
void main(void)
UCSRA=0x00;
UCSRB=0xD8;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=51;
#asm("sei")
received_ok=0;
preceive = 0;
send_ok=0xff;
while (1)
if(received_ok==1)
data1=1;
data2=2;
data3=0;
data4=0xcc;
delay(1000);
unsigned char data;
#asm("cli")
if (UCSRA&(1<<RXC))
data=UDR;
preceive++;
if(preceive==3)
if(data==3) //字结束
received_ok=1;
send_ok=0;
preceive=0;
rec_len=0;
#asm("sei")
#asm("cli")
if(send_ok==0)
UDR=sendbuf[psend];
psend++;
if(psend>=send_max)
psend=0;
received_ok=0;
send_ok=1;
#asm("sei")
void main(void)
UCSRA=0x00;
UCSRB=0xD8;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=51;
#asm("sei")
received_ok=0;
preceive = 0;
send_ok=0xff;
while (1)
if(received_ok==1)
data1=1;
data2=2;
data3=0;
data4=0xcc;
delay(1000);
| AG32VH407下光照强度传感器BH1750及其检测被打赏¥22元 | |
| AT32VH407下使用温湿度传感器DHT22进行检测被打赏¥20元 | |
| DIY一个婴儿澡盆温度计被打赏¥34元 | |
| 【FreeRtos】FreeRtos+MPU region 配置规则被打赏¥23元 | |
| 【分享开发笔记,赚取电动螺丝刀】三分钟快速上手驱动墨水屏(ArduinoIDE)被打赏¥28元 | |
