电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » Verilog HDL 程序举例--状态机举例:
2007-03-29 20:29:20     打赏
// State Machine
// download from: www.pld.com.cn & www.fpga.com.cn
module statmach(clk, in, reset, out);
   input clk, in, reset;
   output out;
   reg out;
   reg state;
   parameter s0 = 0, s1 = 1;
   always @(state)
   begin
	case (state)
		s0:
			out = 0;
		s1:
			out = 1;
		default:
			out = 0;
	endcase
   end
   always @(posedge clk or posedge reset)
   begin
	if (reset)
		state = s0;
	else
		case (state)
			s0:
				state = s1;
			s1:
				if (in)
					state = s0;
				else
					state = s1;
		endcase
   end
endmodule
一个同步状态机
Verilog HDL: Synchronous State Machine
This is a Verilog example that shows the implementation of a state machine.
The first CASE statement defines the outputs that are dependent on the value of the state machine variable state.
The second CASE statement defines the transitions of state machine and the conditions that control them.
download from: http://www.fpga.com.cn
statem.v
module statem(clk, in, reset, out);
output [3:0] out;
reg [3:0] out;
reg [1:0] state;
parameter zero=0, one=1, two=2, three=3;
always @(state)
     begin
          case (state)
               zero:
                    out = 4'b0000;
               one:
                    out = 4'b0001;
               two:
                    out = 4'b0010;
               three:
                    out = 4'b0100;
               default:
                    out = 4'b0000;
          endcase
     end
     begin
          if (reset)
               state = zero;
          else
               case (state)
                    zero:
                         state = one;
                    one:
                         if (in)
                              state = zero;
                         else
                              state = two;
                    two:
                         state = three;
                    three:
                         state = zero;
               endcase
     end
endmodule
用状态机设计的交通灯控制器
// Copyright (c) 2000 Exemplar Logic Inc. All rights reserved.
// This is a typical example of a state machine description
// in Verilog HDL.
//   Two always statements, one to update the state on a clock plus
//   or reset, and one to calculate the next state and
//   the outputs in a case statement
// This description implements a traffic light controller
// download from: www.fpga.com.cn & www.pld.com.cn
module traffic (clock, reset, sensor1, sensor2,
	  red1, yellow1, green1, red2, yellow2, green2);
input clock, reset, sensor1, sensor2;
output  red1, yellow1, green1, red2, yellow2, green2;
// Define the states. Enumerated type pragma allows Spectrum to chose encoding.
parameter /*exemplar enum ee1 */ st0 = 0, st1 = 1, st2 = 2, st3 = 3,
	  st4 = 4, st5 = 5, st6 = 6, st7 = 7;
reg [2:0] /* exemplar enum ee1 */ state, nxstate ;
reg red1, yellow1, green1, red2, yellow2, green2;
// Update the state with the next state on the clock edge
// or reset value.
always @(posedge clock or posedge reset)
begin
    if (reset)
	state = st0 ;
    else
	state = nxstate;
end
// Calculate the next state and the outputs,
// based on the present state and the inputs
always @(state or sensor1 or sensor2)
begin
     // Default values for the outputs
    red1 = 1'b0; yellow1 = 1'b0; green1 = 1'b0;
    red2 = 1'b0; yellow2 = 1'b0; green2 = 1'b0;
    case (state) /* exemplar full_case */ /* exemplar parallel_case */
	st0: begin
	    green1 = 1'b1;
	    red2 = 1'b1;
	    if (sensor2 == sensor1)
		nxstate = st1;
	    else if (~sensor1 & sensor2)
		nxstate = st2;
            else
                nxstate = st0;
        end
	st1: begin
	    green1 = 1'b1;
	    red2 = 1'b1;
	    nxstate = st2;
        end
	st2: begin
	    green1 = 1'b1;
	    red2 = 1'b1;
	    nxstate = st3;
        end
	st3: begin
	    yellow1 = 1'b1;
	    red2 = 1'b1;
	    nxstate = st4;
        end
	st4: begin
	    red1 = 1'b1;
	    green2 = 1'b1;
	    if (~sensor1 & ~sensor2)
		nxstate = st5;
	    else if (sensor1 & ~sensor2)
		nxstate = st6;
            else
                nxstate = st4;
        end
	st5: begin
	    red1 = 1'b1;
	    green2 = 1'b1;
	    nxstate = st6;
        end
	st6: begin
	    red1 = 1'b1;
	    green2 = 1'b1;
	    nxstate = st7;
        end
	st7: begin
	    red1 = 1'b1;
	    yellow2 = 1'b1;
	    nxstate = st0;
        end
    endcase
end
endmodule
关键词: Verilog     程序     举例     状态机     reset     s
2007-03-29 20:40:00     打赏
顶
