电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » dosFS+TFFS安全掉电补丁
共4条 1/1 1 跳转至页
dosFS+TFFS安全掉电补丁
2008-01-02 09:47:34     打赏
在vxWorks下,经常会遇到突然掉电后,文件系统被破坏,文件不能使用的情况。前几天我做了一个reboot的hook,使用rebootHookAdd增加到reboot函数中后,可以在系统复位前中止正在做写操作的任务,然后关闭文件和文件系统,同步cache,做到安全掉电。代码如下:
#include "vxWorks.h"
#include "private/dosFsVerP.h"
#include "private/dosFsLibP.h"
#include "private/iosLibP.h"
#include "taskLib.h"
#include "intLib.h"
#define DOSFS_REBOOT_HOOK_DEBUG     1
#if DOSFS_REBOOT_HOOK_DEBUG
char *g_pszDbgDosfsHookBuf = 0x6000;
#endif
extern int dosFsDrvNum;
extern int maxDrivers;
extern int maxFiles;
extern DRV_ENTRY *drvTable;
void usrDosfsShutdown()
    int iLoop, fdNum, iCount = 0, iStatus = 0;
    DEV_HDR *pDev = NULL;
    DOS_VOLUME_DESC_ID pVolDesc;
    DOS_FILE_DESC_ID pFd = pVolDesc->pFdList;
    int  iCloseFlag = 0;
    char szTmpBuf[1024];
    int  curTick = tickGet();
    *(unsigned long *)g_pszDbgDosfsHookBuf = 0;
#endif
    if ((drvTable != NULL)
      &&(dosFsDrvNum != ERROR)&&(dosFsDrvNum < maxDrivers)
      &&(drvTable[dosFsDrvNum].de_inuse == TRUE))
        for (iLoop = 0; iLoop < maxDrivers; iLoop++)
            pDev = iosNextDevGet(pDev);
            if (pDev == NULL)
                break;
            /* All used dosfs function group is dosfs vol */
            if (pDev->drvNum == dosFsDrvNum)
                pVolDesc = (DOS_VOLUME_DESC_ID)pDev;
                sprintf(g_pszDbgDosfsHookBuf + strlen(g_pszDbgDosfsHookBuf),
                        "Start check volume %s, can open max %d files, have used %d fds.\r\n",
                        pDev->name, pVolDesc->maxFiles, pVolDesc->nBusyFd);
#endif
                iCount = 0;
                for (pFd = pVolDesc->pFdList;
                     pFd < pVolDesc->pFdList + pVolDesc->maxFiles; pFd++)
                    if (pFd->busy == TRUE)
                        iCloseFlag = 0;
#endif
                        /* Force dosfs make a mistake, the operating will exit. */
                        pFd->fatHdl.errCode = TRUE;
                        for (fdNum = 0; fdNum < maxFiles; fdNum++)
                            if ((DOS_FILE_DESC_ID)iosFdValue(fdNum) == pFd)
                                strcpy(szTmpBuf, fdTable[STD_MAP(fdNum)].name);
#endif
                                if (close(fdNum) == OK)
                                            "  Closed %s success(fd==%d).\r\n",
                                            szTmpBuf, fdNum);
#endif
                                    iCount++;
                                    iCloseFlag = TRUE;
                                else
                                            "  Close %s failed(fd==%d).\r\n",
                                            szTmpBuf, fdNum);
#endif
                        if (iCloseFlag == 0)
                                    "  Find a file openned, but can't find its fd.");
#endif
                iStatus = dosFsVolUnmount(pVolDesc);
                        "Check volume %s over, closed %d files, unmount volume %s.\r\n",
                        pDev->name,iCount,((iStatus==OK)?"success":"failed"));
#endif
    else
                "Can't find dosfs volume!\r\n");
#endif
            "Check all dosfs volume, cost %d ticks.!\r\n", tickGet() - curTick);
#endif
关键词: dosFS+TFFS     安全     掉电     补丁     DOSFS
2008-01-02 17:50:13     打赏
当然不是掉电之后运行,是在准备掉电之前,在reboot函数里面增加的一个钩子。使用这个钩子以后可以避免由于掉电时正在做文件写操作突然掉电引起的文件系统异常。这些异常经常是无法恢复的。
2008-01-04 15:40:36     打赏
楼上正解,我正在想办法让冷启动也能用,初步想法是让硬件做一个电平预警,当发生低电平中断的时候,一般距离cpu不能工作会有1秒左右的时间,在这段时间内,让文件系统写完一个扇区或一个簇正常退出。还在考虑中。
2008-01-15 21:16:23     打赏
你说的带掉电崩溃的文件系统名字是什么?
共4条 1/1 1 跳转至页
