电子产品世界 » 论坛首页 » 活动中心 » 合作大赛 » 关于SUPPORT_BG的定义问题
关于SUPPORT_BG的定义问题
2010-11-07 20:00:15     打赏
请问定义SUPPORT_BG有什么作用,比不定义SUPPORT_BG有什么功能不能实现吗?新建工程默认是定义SUPPORT_BG的,可为什么定义了SUPPORT_BG后,发送SMS消息或Start call后屏幕不能正常显示,而是出现“please delete layer”(如图)?
代码如下:
#include "vmsys.h"
#include "vmio.h"
#include "vmgraph.h"
#include "vmchset.h"
#include "vmstdlib.h"
 * global variables
#define  SUPPORT_BG
VMINT  layer_hdl[1];    // layer handle array.
 * local variables
 * system events
void handle_sysevt(VMINT message, VMINT param);
 * key events
void handle_keyevt(VMINT event, VMINT keycode);
 * pen events
void handle_penevt(VMINT event, VMINT x, VMINT y);
 * demo
static void draw_hello(void);
 * entry
void vm_main(void)
 layer_hdl[0] = -1;
 vm_reg_sysevt_callback(handle_sysevt);
 vm_reg_keyboard_callback(handle_keyevt);
 vm_reg_pen_callback(handle_penevt);
#ifdef  SUPPORT_BG
 /* The application updates the screen when receiving the message VM_MSG_PAINT
 *  what is sent after the application is activated. The application can skip
 *  the process on screen when the VM_MSG_ACTIVE or VM_MSG_INACTIVE is received.
 switch (message)
  case VM_MSG_CREATE:
   /* the GDI operation is not recommended as the response of the message*/
   break;
  case VM_MSG_PAINT:
   /* cerate base layer that has same size as the screen*/
            /*If rotating screen is needed, and it rotates successful,
            the application will receive the VM_MSG_PAINT event, then,
            the application needs to delete the level and recreate it. */
   if( layer_hdl[0] != -1 )
    vm_graphic_delete_layer(layer_hdl[0]);
    layer_hdl[0] = -1;
   if( layer_hdl[0] == -1 )
    layer_hdl[0] = vm_graphic_create_layer(0, 0,
     vm_graphic_get_screen_width(),
     vm_graphic_get_screen_height(), -1);
   /* set clip area */
   vm_graphic_set_clip(0, 0,
    vm_graphic_get_screen_height());
   draw_hello();
   break;
  case VM_MSG_SCREEN_ROTATE:
   /*The application can rotate the screen*/
   break;
  case VM_MSG_HIDE:
                layer_hdl[0] = -1;
            break;
  case VM_MSG_QUIT:
    layer_hdl[0] = -1;
            vm_exit_app();
   break;
#else
 switch (message)
  case VM_MSG_CREATE:
  case VM_MSG_ACTIVE:
   /*cerate base layer that has same size as the screen*/
   /* set clip area*/
   break;
  case VM_MSG_PAINT:
   draw_hello();
   break;
   break;
  case VM_MSG_INACTIVE:
                layer_hdl[0] = -1;
            break;
  case VM_MSG_QUIT:
    layer_hdl[0] = -1;
            vm_exit_app();
   break;
#endif
 /* press any key and return*/
  layer_hdl[0] = -1;
 vm_exit_app();
 /* touch and return*/
  layer_hdl[0] = -1;
 vm_exit_app();
 VMWCHAR s[50];
 VMUINT8* buf;
 int x, y, w;
 vm_gb2312_to_ucs2(s, 50, "Hello, world!");
 w = vm_graphic_get_string_width(s);
 x = (vm_graphic_get_screen_width() - w) / 2;
 y = (vm_graphic_get_screen_height() - vm_graphic_get_character_height()) / 2;
 /* get the target buffer*/
 buf = vm_graphic_get_layer_buffer(layer_hdl[0]);
 /* fill the screen*/
 vm_graphic_fill_rect(buf, 0, 0, vm_graphic_get_screen_width(),
  vm_graphic_get_screen_height(), VM_COLOR_WHITE, VM_COLOR_BLACK);
 /* draw text */
 vm_graphic_textout(buf, x, y, s, wstrlen(s), VM_COLOR_BLUE);
 /* flush the screen with data in the buffer*/
 vm_graphic_flush_layer(layer_hdl, 1);
关键词: 关于     SUPPORT     定义     问题     delete     l
