The Virtex®-II FPGA series provides dedicated on-chip blocks of 18 Kbit True Dual-Port synchronous RAM for use in FIFO applications. This application note describes a way to create a common-clock (synchronous) version and an independent-clock (asynchronous) version of a 511 to 36 FIFO, with the depth and width being adjustable within the Verilog or VHDL code. This document is obsolete/under obsolescence.
xapp258.pdf
共1条
FIFOs Using Virtex-II Block RAM - Obsolete
关键词: FIFOs Using Virtex-II Blo
共1条
| OrangePiZero2W系统被打赏¥33元 | |
