On-die termination (ODT) promises higher signaling rates for printed circuit board (PCB) inter-chip interfaces through improved signal integrity. However, when using ODT, there is sometimes an associated power penalty. This application note explains the reason for the power penalty and suggests a simulation technique for comparing the signal integrity and power dissipation of internally and externally terminated versions of an interface.
xapp863.pdf
共1条
利用数控阻抗:信号完整性和功耗的考虑
关键词: 利用 数控 阻抗 信号 完整性 功耗 考虑
共1条
| PCF8574功能模块及其使用被打赏¥20元 | |
| LPS25HB气压传感器及其检测被打赏¥18元 | |
| HTS221温湿度传感器及其检测被打赏¥18元 | |
