电子产品世界 » 论坛首页 » 企业专区 » Renesas » 小庄稼人的Sakura学习笔记四:串口篇
共12条 1/2 1 2 › 跳转至页
2012-11-24 14:55:18     打赏
小庄稼人的Sakura进程贴
组名:小庄稼人
组员:啸风、billy556、月嘉愚生
时间
进程名
位置
 2012-11-23  小庄稼人的申请贴                                      http://forum.eepw.com.cn/thread/222789/1
 2012-11-23  申请被被老王批准  http://forum.eepw.com.cn/thread/222789/1/#4
 2012-11-24  Sakura开发板相关信息                                          2楼
 2012-11-24  软件学习                                          3楼
 2012-11-29  收到Sakura板                                        10楼
 2012-12-01  Sakura学习笔记一:数字I/O篇                                        11 楼
 2012-12-01  Sakura学习笔记二:模拟IO篇                                        12楼
 2012-12-01  Sakura学习笔记三:高级IO口篇(tone)                                       13楼
 2012-12-03  Sakura学习笔记四:串口篇(发送数据)                                       14 楼
Sakura板靓照:
关键词: 庄稼     人的     Sakura     学习     笔记     串口
2012-11-24 14:55:54     打赏
Sakura开发板相关信息
转自官网
Hardware specification
Is the spec information of GR-SAKURA and GR-SAKURA-FULL.
    On-board MCU 32-bit high performance CPU
    ( R5F563NBDDFP ) RX63N 100-pin
    ▶ Operating frequency: 96 MHz (single precision FPU, on-chip multiplication/division)
    ▶ Flash ROM: 1M Bytes, RAM:128K bytes,
    ▶ Data flash:32K bytes
    ▶ Communication features: USB (host/function), Ether-MAC, I2C, SPI, CAN, IEBus
    ▶ Timers 16-bit (MTU, TPU, CMT), 8-bit TMR, WDT, independent WDT, PPG
    ▶ 12 / 10-bit ADC, temperature sensor, data transfer (DMAC, DTC)
    Board features ▶ USB function pins (mini-B): Download by USB mass storage (write)
    ▶ EtherNet (RJ45) pins : LAN such as Web server and remote download available
    ▶ USB host pins (A): applicable to Android-ADB-ADK
    ▶ MicroSD jacket: possible to share data with PC
    ▶ XBee ready pins: mount XBee module for wireless remote download
    ▶ Additional service pins for advanced timer input/outputs
    ▶ JTAG pins: E1 emulator debugging is possible
    Initial firmware Flash write downloader firmware based on USB mass storage
    Power supply 5V (USB bus-powered operation or AC adapter) (RX63N operates in 3.3V)
    (1) USB function connector - Connect to PC and Android phone (limited to the USB mass storage compatible devices)
    - USB bus-powered
    - Transfer rate 12Mbit / sec (bulk, interrupt, and control).
    Transfer user program in the RX63N built-in Flash memory
    (2) DC power jack (5 V) Use when the USB bus power is not enough
    (RX63N operates at 3.3V, which voltage generated by the on-board regulator IC)
    (3) USB host connector (type A) Solder the bundled connector on the back side of mini USB connector when needed. You can use it for the Android ADK.
    Please note that USB host and USB function can not be used simultaneously.
    (4) EtherNet (RJ45) connector 100 / 10 Mbps, internal pulse transformer
    (5) JTAG connector JTAG debugger (ready for Renesas-E1)
    (6) Arduino-compatible pins Pin and footprint compatible with commonly available Arduino shields. (Please note 3.3V and 5V tolerant pins)
    (7) Expansion pin In addition to pins in (6), the board offers auxiliary pins covering most of valid pins on the RX63N 100-pin package .
    (8) XBee ready pattern Xbee module can be mounted on this spot, which enables the board to communicate via Zigbee and Wi-Fi.
    (9) Micro SD card slot Access in SPI mode
    (10) Switch (Red or Brown) SW1 -- reset
    (Blue) SW2 – available for user
    (Slide) SW3 – change the RX63N operation mode
    (11) LED 4 pieces
    Use freely in the user program.
    On-board Jumper Setting Description (For more detail, refer to the GR-SAKURA circuit diagram)
    Grsakurajumpertop
    Grsakurajumperbot
    • J1: Bypass the reserve current protection diode when using USB  5V supply.
        (It avoids diode’s voltage drop. But it may cause a reverse current problem.
    • J2: V50 in Arduino is connected to 5V output of the regulator. GR-SAKURA has jumper J2 for isolation.
    • J3: VIN in Arduino is connected to DC input. GR-SAKURA has jumper J3 for isolation in case of supplying 5V.
    • J4: Cut J4 to disconnect AVCC (analog power supply) from VCC (digital power supply).
    • J5: During the boot mode,
      - USB boot when J5 is set to open
      - SCI boot when J5 is set to short-circuited
    • J6: Short-circuit this jumper when you want to use boot mode.
        (You don’t use this jumper since slide switch SW3 does the same setting.)
    • J7: Connect DOUT of the XBee module to P52/RXD2 of RX63N
    • J8: DIN of the XBee module to P50/TXD of RX63N
    • J9: RESET of the XBee module to P51 of RX63N
    • J10: RTS of the XBee module to P54 of RX63N
    • J11: CTS of the XBee module to PP55 of RX63N
    • J12: Connect J12 to have RX63N control the USB-host pull-down registers
    • J13: Connect the USB-host pull-down registers to the ground (permanent pull-down)
    • J14: Connect J14 to have RX63N control the USB-host pull-down registers
    • J15: Connect the USB-host pull-down registers to the ground (permanent pull-down)
       (Jumpers J12 – J15 can be set to open in normal use)
    • J16: Connect Vcc of the XBee module to the 3.3V supply of the GR-SAKURA board.
       (The XBee module consumes a large amount of current during it’s reset, causing the GR-SAKURA board being in an unstable operation. This jumper is useful for using an external 3.3V supply dedicated for the XBee module)
    • J17: This jumper connects RESET of Arduino connector CN14 to the system reset. When a connected Arduino shield outputs the 5V reset signal, it may damage the GR-SAKURA board. Therefore this jumper is set to open in default. Connect this jumper when the connecting shield will output the 3.3V reset signal or the open drain reset signal.
    When you start using GR-SAKURA with no shield, you don’t need to modify any jumper setting.
    The jumper setting is required in the following situations:
    ・When you use the XBee module, short-circuit J7,J8,J9,J10,J11, and J16
    ・When you use USB OTG, short-circuit J12 and J14.
    ・When you use USB-host mode, short-circuit J13 and J15(USB-function mode is also OK)
    ・When you use a Arduino shield operating in 5V supply, short-circuit J2.
2012-11-24 14:56:38     打赏
Arduino的语法学习
 昨个前期的准备,先学习下语法,熟悉一下。在网上找到了一些Arduino的教程,觉得挺不错的。
相关教程:
Arduino教程.doc
Arduino最全的中文教程.pdf
动手玩转Arduino.zip
Arduino程序代码从结构上可以分为三个主要部分:结构、值(变量与常量)与功能。
setup()
程序刚启动时,调用setup()函数.用于初始化变量,设置针脚的输出/输入类型,配置串口,引入库文件等等. 每次Arduino上电或重启后,setup函数只运行一次.
loop()
在setup()函数中初始化和定义了变量之后,loop()函数,顾名思义,不停的循环,根据程序中的内容,根据一些反馈,响应改变执行情况。我们就用loop中的代码控制Arduino板。
void setup()
void loop()
2012-11-24 14:57:03     打赏
再占~~~~~~~~~~~~~·
2012-11-25 12:47:33     打赏
到时一起讨论噢
2012-12-03 17:34:32     打赏
Sakura板子已到,开始初步的学习
这里给大家分享两个Arduino的语法网站:
1、极客工坊整理的Arduino语法
http://wiki.geek-workshop.com/doku.php?id=arduino:arduino_language_reference
2、瑞萨官网的樱花Arduino语法
http://tool-cloud.renesas.com/Renesas/ref/library.html
板子靓照:
2012-12-03 17:36:05     打赏
Sakura学习笔记一:数字I/O篇
【语法学习】
【程序结构】
setup()
loop()
【数字I/O】
pinMode()
描述
将指定的引脚配置成输出或输入。详情请见digital pins。
语法
pinMode(pin, mode)
参数
pin:要设置模式的引脚
mode:INPUT或OUTPUT
返回:无
digitalWrite()
描述
给一个数字引脚写入HIGH或者LOW。
如果一个引脚已经使用pinMode()配置为OUTPUT模式,其电压将被设置为相应的值,HIGH为5V(3.3V控制板上为3.3V),LOW为0V。
如果引脚配置为INPUT模式,使用digitalWrite()写入HIGH值,将使内部20K上拉电阻(详见数字引脚教程)。写入LOW将会禁用上拉。上拉电阻可以点亮一个LED让其微微亮,如果LED工作,但是亮度很低,可能是因为这个原因引起的。补救的办法是 使用pinMode()函数设置为输出引脚。
语法
digitalWrite(pin, value)
参数
pin: 引脚编号(如1,5,10,A0,A3)
value: HIGH or LOW
返回:无
digitalRead()
描述
读取指定引脚的值,HIGH或LOW。
语法
digitalRead(PIN)
参数
pin:你想读取的引脚号(int)
返回
HIGH 或 LOW
【实验一】数字输出
本实验是对Sakura的数字I/O口的输出操作,LED流水灯。程序官网中已给出:
/*GR-SAKURA Sketch Template Version: V1.02*/
#include <rxduino.h>
#define INTERVAL 500
void setup()
    pinMode(PIN_LED0,OUTPUT);
    pinMode(PIN_LED1,OUTPUT);
    pinMode(PIN_LED2,OUTPUT);
    pinMode(PIN_LED3,OUTPUT);
void loop()
    digitalWrite(PIN_LED0, 1);
    delay(INTERVAL);
    digitalWrite(PIN_LED1, 1);
    delay(INTERVAL);
    digitalWrite(PIN_LED2, 1);
    delay(INTERVAL);
    digitalWrite(PIN_LED3, 1);
    delay(INTERVAL);
    digitalWrite(PIN_LED0, 0);
    delay(INTERVAL);
    digitalWrite(PIN_LED1, 0);
    delay(INTERVAL);
    digitalWrite(PIN_LED2, 0);
    delay(INTERVAL);
    digitalWrite(PIN_LED3, 0);
    delay(INTERVAL);
【实验二】数字输入
  本实验是检测Sakura的数字I/O口的输入,并且用板上的LED的亮灭显示输入的值。
Sakura板LED原理图
    由于板上LED是给高电平点亮的,按键板上的按键在松开的时候是连接VCC,这样在没有全按下的时候,LED接高电平,全部点亮。为了方便实验的观察,将读入的按键进行取非操作。具体程序如下:
//定义变量存储按键值
int val_0 = 0;
int val_1 = 0;
int val_2 = 0;
int val_3 = 0;
void setup()
    pinMode(PIN_LED0,OUTPUT); //将4位LED设置为输出
    pinMode(0, INPUT);      // 将0脚设置为输入
    pinMode(1, INPUT);      // 将1脚设置为输入
    pinMode(2, INPUT);      // 将2脚设置为输入
    pinMode(3, INPUT);      // 将3脚设置为输入
void loop()
    val_0 = digitalRead(0);   // 读取按键值
    val_1 = digitalRead(1);
    val_2 = digitalRead(2);
    val_3 = digitalRead(3);
    digitalWrite(PIN_LED0, !val_0);    //将按键值进行取非操作 并写给LED
    digitalWrite(PIN_LED1, !val_1);
    digitalWrite(PIN_LED2, !val_2);
    digitalWrite(PIN_LED3, !val_3);
视频:
2012-12-03 18:01:07     打赏
Sakura学习笔记二:模拟I/O篇
【语法学习】
analogReference(type)
analogRead()
analogWrite()
【试验一】呼吸灯
本实验通过控制PWM脉宽的调制来控制LED的点亮的程度,实验中使用了板上的四位LED灯。
void setup()
void loop()
     for (int a=0; a<=255;a++)                //循环语句,控制PWM亮度的增加
             analogWrite(PIN_LED0,a);
             analogWrite(PIN_LED1,a);
             analogWrite(PIN_LED2,a);
             analogWrite(PIN_LED3,a);
             delay(10);                      //当前亮度的维持的时间,单位毫秒
     for (int a=255; a>=0;a--)                //循环语句,控制PWM亮度的减少
      delay(1000);                             //完成一个循环后等待的时间,单位毫秒
【实验二】模拟I/O输入
void setup()
void loop()
    int n = analogRead(A0);            //读取A0模拟口的数值(0-5V 对应 0-1204取值)
    analogWrite(PIN_LED0,n/4);         //PWM最大取值255  所以将模拟口的取值n除以4
    analogWrite(PIN_LED1,n/4);
    analogWrite(PIN_LED2,n/4);
    analogWrite(PIN_LED3,n/4);
2012-12-03 18:02:23     打赏
Sakura学习笔记三:高级I/O篇
【实验一】防空警报实验
void setup()
  //  pinMode(0,OUTPUT);//设置蜂鸣器的pin为输出模式
void loop()
    for(int i=200;i<=800;i++)                    //用循环的方式将频率从200HZ 增加到800HZ
        pinMode(0,OUTPUT);
        tone(0,i);                            //在一号端口输出频率
        delay(5);                              //该频率维持5毫秒
    delay(4000);                            //最高频率下维持4秒钟
    for(int i=800;i>=200;i--)
        pinMode(0,OUTPUT);
        tone(0,i);
        delay(10);
试试了咱的低音炮音响,效果跟是上次918时候拉的防空警报一样!!
2012-12-03 18:48:52     打赏
Sakura学习笔记四:串口篇
分享一个挺好用的串口:sscom32.zip
【实验一】简单的串口实验 (发送数据)
void setup()
    Serial.begin( 38400 );
void loop()
    Serial.print( "Welcome to EEPW, I am XiaoFeng!");
    Serial.println( " " );
实验实现效果图:
共12条 1/2 1 2 › 跳转至页
