电子产品世界 » 论坛首页 » 休闲专区 » 我爱生活 » 标准行cp功能
标准行cp功能
2018-05-02 12:22:00     打赏
#include<stdio.h>int main(int argc,char *argv[])
    FILE *src_fp,*des_fp;    char buf[128]={0};    if(argc != 3)
        printf("please input parameter\n");        return -1;
    //打开源文件
    src_fp = fopen(argv[1],"r");    if(src_fp == NULL)
        printf("open the file %s is failure\n",argv[1]);        return -1;
    printf("open the file %s is success\n",argv[1]);    //打开目的文件
    des_fp = fopen(argv[2],"w");    if(des_fp == NULL)
        printf("open the file %s is failure\n",argv[2]);        return -2;
    printf("open the file %s is success\n",argv[2]);    //将源文件拷到目的文件中
    while(1)
        fgets(buf,128,src_fp);        if(feof(src_fp))
            printf("the file is end\n");            break;
        fputs(buf,des_fp);
    }    //关闭文件流    fclose(src_fp);
    fclose(des_fp);    return 0;
复制代码
