交叉编译环境:Ubuntu12.04 (32位)
FFMPEG版本:ffmpeg-2.8.1.tar.bz2
Android NDK开发包:android-ndk32-r10b-linux-x86.tar.bz2
- </pre><pre name="code" class="plain">#!/bin/bash
- # FFmpeg-Android, a bash script to build FFmpeg for Android.
- # Copyright (c) 2012 Cedric Fung <root@vec.io>
- # FFmpeg-Android will build FFmpeg for Android automatically,
- # with patches from VPlayer's Android version <https://vplayer.net/>.
- # FFmpeg-Android is free software; you can redistribute it and/or
- # modify it under the terms of the GNU Lesser General Public
- # License as published by the Free Software Foundation; either
- # version 3 of the License, or (at your option) any later version.
- # FFmpeg-Android is distributed in the hope that it will be useful,
- # but WITHOUT ANY WARRANTY; without even the implied warranty of
- # MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
- # Lesser General Public License for more details.
- # You should have received a copy of the GNU Lesser General Public
- # License along with FFmpeg-Android; if not, write to the Free Software
- # Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301 USA
- # Instruction:
- # 0. Install git and Android ndk
- # 1. $ export ANDROID_NDK=/path/to/your/android-ndk
- # 2. $ ./FFmpeg-Android.sh
- # 3. libffmpeg.so will be built to build/ffmpeg/{neon,armv7,vfp,armv6}/
- DEST=`pwd`/build/ffmpeg && rm -rf $DEST
- SOURCE=`pwd`/ffmpeg
- ANDROID_NDK=/work/FFMPEG/android-ndk-r10b
- TOOLCHAIN=/work/FFMPEG/toolchain
- SYSROOT=$TOOLCHAIN/sysroot/
- #$ANDROID_NDK/build/tools/make-standalone-toolchain.sh --platform=android-14 --install-dir=$TOOLCHAIN
- export PATH=$TOOLCHAIN/bin:$PATH
- export CC="ccache arm-linux-androideabi-gcc"
- export LD=arm-linux-androideabi-ld
- export AR=arm-linux-androideabi-ar
- CFLAGS="-O3 -Wall -mthumb -pipe -fpic -fasm \
- -finline-limit=300 -ffast-math \
- -fstrict-aliasing -Werror=strict-aliasing \
- -fmodulo-sched -fmodulo-sched-allow-regmoves \
- -Wno-psabi -Wa,--noexecstack \
- -D__ARM_ARCH_5__ -D__ARM_ARCH_5E__ -D__ARM_ARCH_5T__ -D__ARM_ARCH_5TE__ \
- -DANDROID -DNDEBUG"
- FFMPEG_FLAGS="--prefix=/work/FFMPEG/ffmpeg_android/ \
- --target-os=android \
- --arch=arm \
- --enable-cross-compile \
- --cross-prefix=arm-linux-androideabi- \
- --enable-shared \
- --disable-symver \
- --disable-doc \
- --disable-ffplay \
- --disable-ffmpeg \
- --disable-ffprobe \
- --disable-ffserver \
- --disable-avdevice \
- --disable-avfilter \
- --disable-encoders \
- --disable-muxers \
- --disable-bsfs \
- --disable-filters \
- --disable-devices \
- --disable-everything \
- --enable-protocols \
- --enable-parsers \
- --enable-demuxers \
- --disable-demuxer=sbg \
- --enable-decoders \
- --enable-network \
- --enable-swscale \
- --enable-version3 \
- --disable-inline-asm \
- --disable-yasm \
- --disable-mips32r2 \
- --disable-mipsdspr1 \
- --disable-mipsdspr2 \
- --disable-mipsfpu \
- --disable-fast-unaligned \
- --disable-debug \
- --disable-xmm-clobber-test \
- --enable-decoder=h264 \
- --enable-decoder=mpeg4 \
- --enable-decoder=mjpeg \
- --enable-demuxer=h264 \
- --enable-demuxer=mpeg4 \
- --enable-demuxer=mjpeg \
- --enable-parser=h264 \
- --enable-memalign-hack \
- --disable-asm \
- --disable-altivec \
- --disable-amd3dnow \
- --disable-amd3dnowext \
- --enable-mmx \
- --enable-mmxext \
- --disable-sse \
- --disable-sse2 \
- --disable-sse3 \
- --disable-ssse3 \
- --disable-sse4 \
- --disable-fma4"
- for version in neon armv7 vfp armv6; do
- cd $SOURCE
- case $version in
- neon)
- EXTRA_CFLAGS="-march=armv7-a -mfpu=neon -mfloat-abi=softfp -mvectorize-with-neon-quad"
- EXTRA_LDFLAGS="-Wl,--fix-cortex-a8"
- armv7)
- EXTRA_CFLAGS="-march=armv7-a -mfpu=vfpv3-d16 -mfloat-abi=softfp"
- vfp)
- EXTRA_CFLAGS="-march=armv6 -mfpu=vfp -mfloat-abi=softfp"
- EXTRA_LDFLAGS=""
- armv6)
- EXTRA_CFLAGS="-march=armv6"
- EXTRA_LDFLAGS=""
- EXTRA_CFLAGS=""
- EXTRA_LDFLAGS=""
- esac
- PREFIX="$DEST/$version" && mkdir -p $PREFIX
- FFMPEG_FLAGS="$FFMPEG_FLAGS --prefix=$PREFIX"
- ./configure $FFMPEG_FLAGS --extra-cflags="$CFLAGS $EXTRA_CFLAGS" --extra-ldflags="$EXTRA_LDFLAGS" | tee $PREFIX/configuration.txt
- cp config.* $PREFIX
- [ $PIPESTATUS == 0 ] || exit 1
- make clean
- make -j4 || exit 1
- make install || exit 1
- rm libavcodec/inverse.o
- $CC -lm -lz -shared --sysroot=$SYSROOT -Wl,--no-undefined -Wl,-z,noexecstack $EXTRA_LDFLAGS libavutil/*.o libavutil/arm/*.o libavcodec/*.o libavcodec/arm/*.o libavformat/*.o libswresample/*.o libswscale/*.o -o $PREFIX/libffmpeg.so
- cp $PREFIX/libffmpeg.so $PREFIX/libffmpeg-debug.so
- arm-linux-androideabi-strip --strip-unneeded $PREFIX/libffmpeg.so
- done
注意:
1、直接运行上面的脚本会出错,提示如下:
arm-linux-androideabi-gcc is unable to create an executable file.
C compiler test failed.
解决办法:
执行以上脚本前,先在命令行上执行以下命令把对NDK包中的交叉编译工具链独立提取出来到指定的目录:
/work/FFMPEG/android-ndk-r10b/build/tools/make-standalone-toolchain.sh --platform=android-14 --install-dir=/work/FFMPEG/toolchain/
2、target-os=android,此处不要再用linux了。
3、注意NDK的版本,如果应用代码中使用的是32位系统库,则交叉编译的时候就应该用32位的NDK开发包。
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
