共1条
每月固定干货,ADI 3月中文资料
ADI 最新中文资料新鲜上线,需要的坛友快来下载啦~原贴链接:https://ez.analog.com/cn/other/f/forum/108472/adi-2019-3系统方案精选ADI公司低压断路器应用中的电子脱扣器(ETU)解决方案 (https://www.analog.com/cn/design-center/landing-pages/002/apm/etu-solution-for-low-voltage-circuit-breakers.html )在线研讨会· 基于ADPD188BI烟雾探测器设计要求和集成解决方案(https://www.analog.com/cn/education/education-library/Webcasts/the-evolving-requirements-of-smoke-detection.html )客户成功案例· 助力客户迈向5G未来—ADI公司为Rohde & Schwarz两款新产品提供支持(https://www.analog.com/media/cn/technical-documentation/customer-case-studies/helping-customers-move-toward-a-5g-future_cn.pdf )技术文章· 通信设备制造商需要高功率输出和小尺寸解决方案(https://www.analog.com/media/cn/technical-documentation/tech-articles/Communications-Equipment-Makers-Demand-High-Power-Outputs-and-Small-Solution-Footprints_cn.pdf )· 现代IGBT/MOSFET栅极驱动器提供隔离功能的最大功率限制(https://www.analog.com/media/cn/technical-documentation/tech-articles/Maximum-Power-Limit-for-Withstanding-Insulation-Capabilities-of-Modern-IGBT-MOSFET-Gate-Drivers_cn.pdf )· 一款 IC 适用于多种DC-DC 拓扑:双输出降压型 IC 也可用于 SEPIC 和升压应用(https://www.analog.com/media/cn/technical-documentation/tech-articles/One-IC-for-Multiple-DC-to-DC-Topologies-Dual-Output-Step-Down-IC-Can-Also-Be-Used-in-SEPIC-and-Boost-Applications_cn.pdf )· 带有分布式锁相环的相控阵的系统级LO相位噪声模型(https://www.analog.com/media/cn/technical-documentation/tech-articles/System-Level-LO-Phase-Noise-Model-for-Phased-Arrays-with-Distributed-Phase-Locked-Loops_cn.pdf )· 速度至关重要:ADI公司如何助力DAMSON GLOBAL开创性的全新无线环绕声系统快速上市(https://www.analog.com/media/cn/technical-documentation/tech-articles/Speed-of-the-Essence-How-Analog-Devices-Helped-Damson-Global-Get-to-Market-Quickly-with-a-Pioneering-New-Wireless-Surround-Sound-System_cn.pdf )· 单片式全桥AutoResonant发送器IC简化了无线电池充电器设计(https://www.analog.com/media/cn/technical-documentation/tech-articles/Monolithic-Full-Bridge-AutoResonant-Transmitter%20IC%20Simplifies-Wireless-Battery-Charger-Design_cn.pdf )· 两级方式实现高电压(https://www.analog.com/media/cn/technical-documentation/tech-articles/Two-Steps-to-High-Voltages_cn.pdf )· 新一代军用通信系统挑战(https://www.analog.com/media/cn/technical-documentation/tech-articles/Next-Generation-Military-Communications-Challenges_cn.pdf )· 精准、低功耗的远程检测理念(https://www.analog.com/media/cn/technical-documentation/tech-articles/Accurate-Low-Power-Remote-Sensing-Ideas_cn.pdf )应用笔记与相关视频,戳这个:https://ez.analog.com/cn/other/f/forum/108472/adi-2019-3
共1条
| 为遥控小车巧添功能被打赏¥26元 | |
