- /*************  功能说明    **************
- 时钟说明:由内部IRC产生24MHz的时钟分频为6M提供给HPLL当作HPLL输入时钟,PLL锁频到246MHz输出作为高速PWM的时钟源,
- PWM高速输出说明:PWMA的CC1通道配置为输出模式,并从P1.0/P1.1口输出频率为2.46MHz,占空比为50%的互补对称带死区的PWM波形
- 下载时, 选择默认IRC时钟 24MHz。
- #include "stc32g.h"
- #define FOSC            24000000UL
- #define HSCK_MCLK       0
- #define HSCK_PLL        1
- #define HSCK_SEL        HSCK_PLL
- #define HSIOCK          0x40
- #define ENHPLL          0x80
- #define HPLLDIV_52      0x00
- #define HPLLDIV_54      0x01
- #define HPLLDIV_56      0x02
- #define HPLLDIV_58      0x03
- #define HPLLDIV_60      0x04
- #define HPLLDIV_62      0x05
- #define HPLLDIV_64      0x06
- #define HPLLDIV_66      0x07
- #define HPLLDIV_68      0x08
- #define HPLLDIV_70      0x09
- #define HPLLDIV_72      0x0A
- #define HPLLDIV_74      0x0B
- #define HPLLDIV_76      0x0C
- #define HPLLDIV_78      0x0D
- #define HPLLDIV_80      0x0E
- #define HPLLDIV_82      0x0F
- #define ENCKM           0x80
- #define PCKI_MSK        0x60
- #define PCKI_D1         0x00
- #define PCKI_D2         0x20
- #define PCKI_D4         0x40
- #define PCKI_D8         0x60
- void delay()
-     int i;
-     for (i=0; i<100; i++);
- char ReadPWMA(char addr)
-     char dat;
-     while (HSPWMA_ADR & 0x80);              //等待前一个异步读写完成
-     HSPWMA_ADR = addr | 0x80;               //设置间接访问地址,只需要设置原XFR地址的低7位
-                                             //HSPWMA_ADDR寄存器的最高位写1,表示读数据
-     while (HSPWMA_ADR & 0x80);              //等待当前异步读取完成
-     dat = HSPWMA_DAT;                       //读取异步数据
-     return dat;
- void WritePWMA(char addr, char dat)
-     HSPWMA_DAT = dat;                       //准备需要写入的数据
-     HSPWMA_ADR = addr & 0x7f;               //设置间接访问地址,只需要设置原XFR地址的低7位
-                                             //HSPWMA_ADDR寄存器的最高位写0,表示写数据
- int main()
-     EAXFR = 1;
-     P0M0 = 0; P0M1 = 0;
-     P1M0 = 0; P1M1 = 0;
-     P2M0 = 0; P2M1 = 0;
-     P3M0 = 0; P3M1 = 0;
-     P4M0 = 0; P4M1 = 0;
-     P5M0 = 0; P5M1 = 0;
-     //选择HPLL输入时钟分频,保证输入时钟为6M
-     USBCLK &= ~PCKI_MSK;
- #if (FOSC == 6000000UL)
-     USBCLK |= PCKI_D1;                      //PLL输入时钟1分频
- #elif (FOSC == 12000000UL)
-     USBCLK |= PCKI_D2;                      //PLL输入时钟2分频
- #elif (FOSC == 24000000UL)
-     USBCLK |= PCKI_D4;                      //PLL输入时钟4分频
- #elif (FOSC == 48000000UL)
-     USBCLK |= PCKI_D8;                      //PLL输入时钟8分频
- #else
-     USBCLK |= PCKI_D4;                      //默认PLL输入时钟4分频
- #endif
-     //设置HPLL的除频系数
- //    HPLLCR = HPLLDIV_52;                  //F_HPLL=6M*52/2=156M
- //    HPLLCR = HPLLDIV_54;                  //F_HPLL=6M*54/2=162M
- //    HPLLCR = HPLLDIV_56;                  //F_HPLL=6M*56/2=168M
- //    HPLLCR = HPLLDIV_58;                  //F_HPLL=6M*58/2=174M
- //    HPLLCR = HPLLDIV_60;                  //F_HPLL=6M*60/2=180M
- //    HPLLCR = HPLLDIV_62;                  //F_HPLL=6M*62/2=186M
- //    HPLLCR = HPLLDIV_64;                  //F_HPLL=6M*64/2=192M
- //    HPLLCR = HPLLDIV_66;                  //F_HPLL=6M*66/2=198M
- //    HPLLCR = HPLLDIV_68;                  //F_HPLL=6M*68/2=204M
- //    HPLLCR = HPLLDIV_70;                  //F_HPLL=6M*70/2=210M
- //    HPLLCR = HPLLDIV_72;                  //F_HPLL=6M*72/2=216M
- //    HPLLCR = HPLLDIV_74;                  //F_HPLL=6M*74/2=222M
- //    HPLLCR = HPLLDIV_76;                  //F_HPLL=6M*76/2=228M
- //    HPLLCR = HPLLDIV_78;                  //F_HPLL=6M*78/2=234M
- //    HPLLCR = HPLLDIV_80;                  //F_HPLL=6M*80/2=240M
-     HPLLCR = HPLLDIV_82;                    //F_HPLL=6M*82/2=246M
-     //启动HPLL
-     HPLLCR |= ENHPLL;                       //使能HPLL
-     delay();                                //等待HPLL时钟稳定
-     //选择HSPWM/HSSPI时钟
- #if (HSCK_SEL == HSCK_MCLK)
-     CLKSEL &= ~HSIOCK;                      //HSPWM/HSSPI选择主时钟为时钟源
- #elif (HSCK_SEL == HSCK_PLL)
-     CLKSEL |= HSIOCK;                       //HSPWM/HSSPI选择PLL输出时钟为时钟源
- #else
-     CLKSEL &= ~HSIOCK;                      //默认HSPWM/HSSPI选择主时钟为时钟源
- #endif
-     HSCLKDIV = 0;                           //HSPWM/HSSPI时钟源不分频
-     HSPWMA_CFG = 0x03;                      //使能PWMA相关寄存器异步访问功能
-     PWMA_PS = 0x00;                         //PWMA_CC1/CC1N高速PWM输出到CC1/CC1N口
-                                             //注意:PWMA_PS属于I/O控制寄存器,不能使用异步方式进行读写
-     //通过异步方式设置PWMA的相关寄存器
-     WritePWMA((char)&PWMA_CCER1, 0x00);
-     WritePWMA((char)&PWMA_CCMR1, 0x00);     //CC1为输出模式
-     WritePWMA((char)&PWMA_CCMR1, 0x60);     //OC1REF输出PWM1(CNT<CCR时输出有效电平1)
-     WritePWMA((char)&PWMA_CCER1, 0x05);     //使能CC1/CC1N上的输出功能
-     WritePWMA((char)&PWMA_ENO, 0x03);       //使能PWM信号输出到端口P1.0/P1.1
-     WritePWMA((char)&PWMA_BKR, 0x80);       //使能主输出
-     WritePWMA((char)&PWMA_CCR1H, 0);        //设置PWM占空比为50个PWM时钟
-     WritePWMA((char)&PWMA_CCR1L, 50);
-     WritePWMA((char)&PWMA_ARRH, 0);         //设置输出PWM的周期为100个PWM时钟
-     WritePWMA((char)&PWMA_ARRL, 99);
-     WritePWMA((char)&PWMA_DTR, 10);         //设置互补对称输出PWM的死区
-     WritePWMA((char)&PWMA_CR1, 0x01);       //开始PWM计数
- //  P2 = ReadPWMA((char)&PWMA_ARRH);        //异步方式读取寄存器
- //  P0 = ReadPWMA((char)&PWMA_ARRL);
-     while (1);
