电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » 【STM32WBA55CG开发板】过程帖:spi驱动LCD
2024-12-08 21:58:41     打赏
项目用到LCD显示信息,使用的屏幕是微雪电子的1.69寸IPS彩色LCD显示屏,分辨率是240×280分辨率,采用SPI接口驱动。驱动芯片是ST7789V2,模块使用到6个控制管脚:
LCD_DINLCD_CLKLCD_CSLCD_DCLCD_RSTLCD_BL
SPI 通信 MOSI 引脚
SPI 通信 CLK引脚
LCD 的片选引脚,低电平有效
LCD 的数据/命令引脚,低电平表示命令,高电平表示数据
LCD 的复位引脚,低电平有效
LCD 的背光引脚
根据开发板的原理图,选择合适的管脚:
使用STM32CubeMX配置SPI驱动过程如下:
背光管脚配置PWM输出,PA2定时器3通道1:
11.png内部时钟,分频系数99,计数值999,则PWM频率为:100MHz/(99+1)/(999+1)=1KHz,
输出占空比百分值为:Pulse值/(999+1)
测试代码:
#include "image.h"
#include "LCD_Test.h"
#include "LCD_1in69.h"
#include "Touch_Driver.h"
#include "DEV_Config.h"
Touch_1IN69_XY XY;
UBYTE flag = 0,flgh = 0;
UWORD x,y,l = 0;
void LCD_1in69_test()
	printf("LCD_1IN28_test Demo\r\n");
	DEV_Module_Init();
  printf("LCD_1IN28_ Init and Clear...\r\n");
	LCD_1IN69_SetBackLight(1000);
	LCD_1IN69_Init(VERTICAL);
	LCD_1IN69_Clear(WHITE);
	XY.mode = 0;
	//if(Touch_1IN69_init(XY.mode) == true)
   //     printf("OK!\r\n");
   // else
   //     printf("NO!\r\n");
	printf("Paint_NewImage\r\n");
	Paint_NewImage(LCD_1IN69_WIDTH, LCD_1IN69_HEIGHT, 0, WHITE);
	printf("Set Clear and Display Funtion\r\n");
	Paint_SetClearFuntion(LCD_1IN69_Clear);
	Paint_SetDisplayFuntion(LCD_1IN69_DrawPoint);
  printf("Paint_Clear\r\n");
	Paint_Clear(BLACK);
	Paint_Clear(RED);
	Paint_Clear(GREEN);
	Paint_Clear(BLUE);
  Paint_Clear(BLACK);
	Paint_DrawString_EN(0, 90, "stm32wba55cg", &Font24, BLACK, RED);
  Paint_DrawString_EN(0, 120, "eepw bbs", &Font20, BLACK, GREEN);
	while(1);
	Paint_ClearWindows(10,90,230,137,WHITE);
  Paint_DrawString_EN(105, 100, "Up", &Font24, 0X647C, WHITE);
  /*while(XY.Gesture != UP)
		 if (flag == TOUCH_IRQ)
				XY.Gesture = I2C_Read_Byte(0x01);
				flag = TOUCH_DRAW;
		DEV_Delay_ms(10);
	Paint_ClearWindows(105,100,160,155,WHITE);
	Paint_DrawString_EN(85, 100, "Down", &Font24, 0X647C, WHITE);
	/*while(XY.Gesture != Down)
					flag = TOUCH_DRAW;
			DEV_Delay_ms(10);
	Paint_ClearWindows(85, 100,160,155,WHITE);
	Paint_DrawString_EN(85, 100, "Left", &Font24, 0X647C, WHITE);
	/*while(XY.Gesture != LEFT)
					flag = TOUCH_DRAW;
			DEV_Delay_ms(10);
	Paint_DrawString_EN(80, 100, "Right", &Font24, 0X647C, WHITE);
	/*while(XY.Gesture != RIGHT)
					flag = TOUCH_DRAW;
			DEV_Delay_ms(10);
	Paint_ClearWindows(80, 100,165,160,WHITE);
	Paint_DrawString_EN(47, 100, "Long Press", &Font20, 0X647C, WHITE);
	/*while(XY.Gesture != LONG_PRESS)
					flag = TOUCH_DRAW;
			DEV_Delay_ms(10);
	Paint_ClearWindows(47, 100,200,155,WHITE);
	Paint_DrawString_EN(35, 100, "Double Click", &Font20, 0X647C, WHITE);
	while(XY.Gesture != DOUBLE_CLICK)
					flag = TOUCH_DRAW;
			DEV_Delay_ms(10);
	XY.mode = 1;
	//Touch_1IN69_init(XY.mode);
	Paint_DrawPoint(120, 140, BLACK, DOT_PIXEL_2X2, DOT_FILL_AROUND);
	while (1)
					Paint_DrawPoint(XY.x_point, XY.y_point, XY.color, DOT_PIXEL_2X2, DOT_FILL_AROUND);
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
	//if(GPIO_Pin & TP_INT_Pin)
		if(XY.mode == 1)
			flag = TOUCH_IRQ;
			//XY = Touch_1IN69_Get_Point();
		//else
			flag = TOUCH_IRQ;
效果:
工程源码分享:
stm32wba55cg_test.zip
