电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【LP-MSPM0L1306】TI System Configuration T
【LP-MSPM0L1306】TI System Configuration Tool 配置工具配置UART
2025-06-06 11:35:55     打赏
【简介】
现在接触的主流的MCU 都会支持图形化的配置工具,同样TI 的MSPM0L1306 也是支持的,我们可以使用TI System Configuration Tool 工具来配置clock/pin/及外设参数的配置。
【时钟配置】
MSPM0L1306 没有外接晶振,使用内部SYSOSC作为时钟源,内部配置为32M的时钟,配置如下
【UART配置】
从框图上可以看出MSPM0L1306 的一路串口通过调试器的虚拟串口连接到USB,我们可以使用该路UART来调试从而不需要外接USB串口来调试。
对应的引脚为PA8/A9
使用配置工具配置uart 参数
配置pinmux
配置后会生成如下的配置代码
ti_msp_dl_config.c
 * Copyright (c) 2023, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * *  Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 *    its contributors may be used to endorse or promote products derived
 *    from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ============ ti_msp_dl_config.c =============
 *  Configured MSPM0 DriverLib module definitions
 *  DO NOT EDIT - This file is generated for the LP_MSPM0L1306
 *  by the SysConfig tool.
#include "ti_msp_dl_config.h"
 *  ======== SYSCFG_DL_init ========
 *  Perform any initialization needed before using any board APIs
SYSCONFIG_WEAK void SYSCFG_DL_init(void)
    SYSCFG_DL_initPower();
    SYSCFG_DL_GPIO_init();
    /* Module-Specific Initializations*/
    SYSCFG_DL_SYSCTL_init();
    SYSCFG_DL_UART_0_init();
SYSCONFIG_WEAK void SYSCFG_DL_initPower(void)
    DL_GPIO_reset(GPIOA);
    DL_UART_Main_reset(UART_0_INST);
    DL_GPIO_enablePower(GPIOA);
    DL_UART_Main_enablePower(UART_0_INST);
    delay_cycles(POWER_STARTUP_DELAY);
SYSCONFIG_WEAK void SYSCFG_DL_GPIO_init(void)
    DL_GPIO_initPeripheralOutputFunction(
        GPIO_UART_0_IOMUX_TX, GPIO_UART_0_IOMUX_TX_FUNC);
    DL_GPIO_initPeripheralInputFunction(
        GPIO_UART_0_IOMUX_RX, GPIO_UART_0_IOMUX_RX_FUNC);
SYSCONFIG_WEAK void SYSCFG_DL_SYSCTL_init(void)
	//Low Power Mode is configured to be SLEEP0
    DL_SYSCTL_setBORThreshold(DL_SYSCTL_BOR_THRESHOLD_LEVEL_0);
    DL_SYSCTL_setSYSOSCFreq(DL_SYSCTL_SYSOSC_FREQ_BASE);
    DL_SYSCTL_setMCLKDivider(DL_SYSCTL_MCLK_DIVIDER_DISABLE);
static const DL_UART_Main_ClockConfig gUART_0ClockConfig = {
    .clockSel    = DL_UART_MAIN_CLOCK_BUSCLK,
    .divideRatio = DL_UART_MAIN_CLOCK_DIVIDE_RATIO_1
static const DL_UART_Main_Config gUART_0Config = {
    .mode        = DL_UART_MAIN_MODE_NORMAL,
    .direction   = DL_UART_MAIN_DIRECTION_TX_RX,
    .flowControl = DL_UART_MAIN_FLOW_CONTROL_NONE,
    .parity      = DL_UART_MAIN_PARITY_NONE,
    .wordLength  = DL_UART_MAIN_WORD_LENGTH_8_BITS,
    .stopBits    = DL_UART_MAIN_STOP_BITS_ONE
SYSCONFIG_WEAK void SYSCFG_DL_UART_0_init(void)
    DL_UART_Main_setClockConfig(UART_0_INST, (DL_UART_Main_ClockConfig *) &gUART_0ClockConfig);
    DL_UART_Main_init(UART_0_INST, (DL_UART_Main_Config *) &gUART_0Config);
     * Configure baud rate by setting oversampling and baud rate divisors.
     *  Target baud rate: 115200
     *  Actual baud rate: 115211.52
    DL_UART_Main_setOversampling(UART_0_INST, DL_UART_OVERSAMPLING_RATE_16X);
    DL_UART_Main_setBaudRateDivisor(UART_0_INST, UART_0_IBRD_32_MHZ_115200_BAUD, UART_0_FBRD_32_MHZ_115200_BAUD);
    DL_UART_Main_enable(UART_0_INST);
ti_msp_dl_config.h
 * Copyright (c) 2023, Texas Instruments Incorporated - http://www.ti.com
 * are met:
 *  ============ ti_msp_dl_config.h =============
 *  Configured MSPM0 DriverLib module declarations
#ifndef ti_msp_dl_config_h
#define ti_msp_dl_config_h
#define CONFIG_LP_MSPM0L1306
#define CONFIG_MSPM0L1306
#if defined(__ti_version__) || defined(__TI_COMPILER_VERSION__)
#define SYSCONFIG_WEAK __attribute__((weak))
#elif defined(__IAR_SYSTEMS_ICC__)
#define SYSCONFIG_WEAK __weak
#elif defined(__GNUC__)
#endif
#include <ti/devices/msp/msp.h>
#include <ti/driverlib/driverlib.h>
#include <ti/driverlib/m0p/dl_core.h>
#ifdef __cplusplus
extern "C" {
#endif
 *  Perform all required MSP DL initialization
 *  This function should be called once at a point before any use of
 *  MSP DL.
/* clang-format off */
#define POWER_STARTUP_DELAY                                                (16)
#define CPUCLK_FREQ                                                     32000000
/* Defines for UART_0 */
#define UART_0_INST                                                        UART0
#define UART_0_INST_FREQUENCY                                           32000000
#define UART_0_INST_IRQHandler                                  UART0_IRQHandler
#define UART_0_INST_INT_IRQN                                      UART0_INT_IRQn
#define GPIO_UART_0_RX_PORT                                                GPIOA
#define GPIO_UART_0_TX_PORT                                                GPIOA
#define GPIO_UART_0_RX_PIN                                         DL_GPIO_PIN_9
#define GPIO_UART_0_TX_PIN                                         DL_GPIO_PIN_8
#define GPIO_UART_0_IOMUX_RX                                     (IOMUX_PINCM10)
#define GPIO_UART_0_IOMUX_TX                                      (IOMUX_PINCM9)
#define GPIO_UART_0_IOMUX_RX_FUNC                      IOMUX_PINCM10_PF_UART0_RX
#define GPIO_UART_0_IOMUX_TX_FUNC                       IOMUX_PINCM9_PF_UART0_TX
#define UART_0_BAUD_RATE                                                (115200)
#define UART_0_IBRD_32_MHZ_115200_BAUD                                      (17)
#define UART_0_FBRD_32_MHZ_115200_BAUD                                      (23)
/* clang-format on */
void SYSCFG_DL_init(void);
void SYSCFG_DL_initPower(void);
void SYSCFG_DL_GPIO_init(void);
void SYSCFG_DL_SYSCTL_init(void);
void SYSCFG_DL_UART_0_init(void);
#ifdef __cplusplus
#endif
#endif /* ti_msp_dl_config_h */
【测试验证】
我们在main 函数内添加如下测试代码回显接收到的串口数据
int main(void)
    SYSCFG_DL_init();
    uint8_t data;
    while (1) {
        /* Wait to receive UART_PACKET_SIZE bytes of data */
        data = DL_UART_Extend_receiveDataBlocking(UART_0_INST);
        /* Echo back the received data */
        DL_UART_Extend_transmitDataBlocking(UART_0_INST,data);
    return 0;
下载运行后跟预期的一致对输入的数据进行回显显示
