电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【MAX78000FEATHER】AES安全模块使用
2025-10-05 11:10:32     打赏
【简介】
从MAX78000 的功能框图可知芯片是支持SECURITY 模块。
对应的加密算法硬件上支持了AES-128/192/256 的算法,按照芯片手册上的说明对应AES 算法的KEY 是内置在芯片内部的用户无法进行设置这部分对用户为透明的。
对于AES 算法的使用我们使用以下测试代码来验证AES-128/192/256 功能。
 * Copyright (C) 2022-2023 Maxim Integrated Products, Inc. (now owned by
 * Analog Devices, Inc.),
 * Copyright (C) 2023-2024 Analog Devices, Inc.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
 * @file        main.c
 * @brief       AES Example
 * @details     Encryption and decryption of AES on different modes (ECB and OFB) with different bit sizes (128, 192, and 256)
/***** Includes *****/
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "mxc_device.h"
#include "board.h"
#include "dma.h"
#include "aes.h"
/***** Definitions *****/
#define MXC_AES_DATA_LENGTH 8 //4 words
#define MXC_AES_ENC_DATA_LENGTH 8 //Always multiple of 4
//(equal to or greater than MXC_AES_DATA_LENGTH)
/***** Globals *****/
uint32_t inputData[MXC_AES_DATA_LENGTH] = { 0x873AC125, 0x2F45A7C8, 0x3EB7190,  0x486FA931,
                                            0x94AE56F2, 0x89B4D0C1, 0x2F45A7C8, 0x3EB7190 };
uint32_t encryptedData[MXC_AES_ENC_DATA_LENGTH] = { 0 };
uint32_t decryptedData[MXC_AES_DATA_LENGTH] = { 0 };
//AES request
mxc_aes_req_t req;
volatile int dma_flag = 0;
/***** Functions *****/
void DMA0_IRQHandler(void)
    MXC_DMA_Handler();
    dma_flag++;
int AES_encrypt(int asynchronous, mxc_aes_keys_t key)
    req.length = MXC_AES_DATA_LENGTH;
    req.inputData = inputData;
    req.resultData = encryptedData;
    req.keySize = key;
    req.encryption = MXC_AES_ENCRYPT_EXT_KEY;
    MXC_AES_Init();
    if (asynchronous) {
        MXC_AES_EncryptAsync(&req);
        while (dma_flag == 0) {}
        dma_flag = 0;
    } else {
        MXC_AES_Encrypt(&req);
    return E_NO_ERROR;
int AES_decrypt(int asynchronous, mxc_aes_keys_t key)
    req.inputData = encryptedData;
    req.resultData = decryptedData;
    req.keySize = key;
    req.encryption = MXC_AES_DECRYPT_INT_KEY;
    if (asynchronous) {
        MXC_AES_DecryptAsync(&req);
        dma_flag = 0;
    } else {
        MXC_AES_Decrypt(&req);
    MXC_AES_Shutdown();
    if (memcmp(inputData, decryptedData, MXC_AES_DATA_LENGTH) != 0) {
        printf("\nData Mismatch");
        return 1;
    printf("\nData Verified");
    return E_NO_ERROR;
int main(void)
    printf("\n***** AES Example *****\n");
    int fail = 0;
    MXC_DMA_ReleaseChannel(0);
    NVIC_EnableIRQ(DMA0_IRQn);
    //ECB
    printf("\nAES 128 bits Key Test");
    AES_encrypt(0, MXC_AES_128BITS);
    fail += AES_decrypt(0, MXC_AES_128BITS);
    printf("\n\nAES 192 bits Key Test");
    AES_encrypt(0, MXC_AES_192BITS);
    fail += AES_decrypt(0, MXC_AES_192BITS);
    printf("\n\nAES 256 bits Key Test");
    AES_encrypt(0, MXC_AES_256BITS);
    fail += AES_decrypt(0, MXC_AES_256BITS);
    if (fail != 0) {
        printf("\nExample Failed\n");
        return E_FAIL;
    printf("\nExample Succeeded\n");
    return E_NO_ERROR;
  代码运行输出如下AES 算法的验证ok
